    holycrap007's Avatar
    Hove
    popup naar andere scene
    Hey there, i'm currently working on a little game in flash based on the memory game (where you find 2 identical cards). The memory part works, however i would like to create a popup when the matching cards are found.
    this popup will contain a scene with a certain question and the user has to select the right answer, in order to continue playing the game.
    I will add the .zip file which contains images + the memory code.
    If anyone could help me out, or know anyone else who could, let me know!
    ps: dit is gewoon een copy paste vn mn post op een ander forum/gwn antwoorden in nederlands dus.
    Klik hier voor de source files
    CtrlAshDel's Avatar
    Heb nog nooit voor games geschreven maar kan ge gewoon niet zeggen van if matching cards are found, then gotoandstop(2) ofzo van een movieclip waarvan de eerste frame blank is en die in je scene zette?
    Work: Dual INTEL Xeon E5-2695V2 (24-cores) + Nvidia Quadro K4000 + 64 GB Corsair DDR3 1866 Mhz + 2 x Samsung 840 Pro 256 (Raid 0) + Lian Li PC-V2120A
    Gaming: INTEL Core I7 3930 + GTX 970 + 32 GB Corsair + 180GB Intel SSD Pro
