Page 2 of 2 First 12
  1. #16
    Huey's Avatar
    Antwerp City
    Ik heb echt geen idee wat ik moet doen man
    Bestaat hier echt geen ander gratis script voor ofzo?
    tha_rippa1be's Avatar
    Stavanger
    Quote Originally Posted by Huey View Post
    Dit ist geen dat ik ineen had geflanst:
    Kan hoogst waarschijnlijk veel aan verbeterd worden, maar het werkt.
    (een afbeelding inlezen van BMP werkt bvb niet, opslaan als BMP dan weer wel.)
    PHP Code:
    class Image{
            public function
    Image($pathToImage){
    $this->pathToImage $pathToImage;
                list(
    $this->width$this->height) = getimagesize($pathToImage);
    //find the input filetype
    $this->filetype pathinfo($pathToImage);
    $this->filetype $this->filetype['extension'];
    $this->setOutputQuality(100);
    $this->image $this->createImage();
            public function
    setOutputQuality($quality){
    //0 <= quality  <= 100
    if($this->filetype == 'jpg' || $this->filetype == 'jpeg'){
    //its jpeg (quality means: ranges from 0 (worst quality, smaller file) to 100 (best quality, biggest file). The default is the default IJG quality value (about 75).)
    $this->outputQuality $quality;
                }else{
    //its png (quality means: Compression level: from 0 (no compression) to 9.)
    $this->outputQuality = (10-$quality/10 <= 9)?10-$quality/109;
            private function
    createImage(){
                switch(
    $this->filetype){
                    case
    'png':
                        return
    imagecreatefrompng($this->pathToImage);
                    break;
                    case
    'jpg':
                        return
    imagecreatefromjpeg($this->pathToImage);
                    break;
                    case
    'jpeg':
                        return
                    break;
                    case
    'gif':
                        return
    imagecreatefromgif($this->pathToImage);
                    break;
                    case
    'bmp'//errort
    return imagecreatefromwbmp($this->pathToImage);
                    break;
            private function
    saveImage($image$location){
    $filetype pathinfo($location);
    $filetype $filetype['extension'];
                switch(
    $filetype){
                    case
    'png':
    imagepng($image$location$this->outputQuality);
                    break;
                    case
    'jpg':
    imagejpeg($image$location$this->outputQuality);
                    break;
                    case
    'jpeg':
                    break;
                    case
    'gif':
    imagegif($image$location);
                    break;
                    case
    'bmp':
    imagewbmp($image$location);
                    break;
            public function
    saveResizedBySizeCrop($pathToNewImage$newWidth$newHeight){
    $calculatedWidth $newWidth;
    $calculatedHeight $newHeight;
    $xOffset 0;
    $yOffset 0;
                if(
    $this->width/$newWidth $this->height/$newHeight){
    $calculatedHeight $this->height/($this->width/$newWidth);
    $yOffset = ($calculatedHeight-$newHeight)/2;
                }elseif(
    $calculatedWidth $this->width/$this->height*$newHeight;
    $xOffset = ($calculatedWidth-$newWidth)/2;
    //else the ratio is correct, keep the newWidth and newHeight and 0 offset
    $resizedImage imagecreatetruecolor($newWidth$newHeight);
    imagecopyresampled($resizedImage$this->image0-$xOffset0-$yOffset00$calculatedWidth$calculatedHeight$this->width$this->height);
    $this->saveImage($resizedImage$pathToNewImage);
    imagedestroy($resizedImage);
            public function
    saveResizedByWidth($pathToNewImage$newWidth){
    $this->saveResizedBySizeCrop($pathToNewImage$newWidth$this->height/$this->width*$newWidth);
            public function
    saveResizedByHeight($pathToNewImage$newHeight){
    $this->saveResizedBySizeCrop($pathToNewImage$this->width/$this->height*$newHeight$newHeight);
    gebruik:
    PHP Code:
    $imjpg = new Image("in/in.jpg");
    $imjpg->saveResizedByWidth("out.jpg"300);
    $imjpeg= new Image("in/in.jpeg");
    $imjpeg->saveResizedByWidth("out.jpeg"300);
    $imgif = new Image("in/in.gif");
    $imgif->saveResizedByWidth("out.gif"300);
    $impng = new Image("in/in.png");
    $impng->saveResizedByWidth("out.png"300);
    $impng->setOutputQuality(50); //van 0-100 (hoger is beter)
    $impng->saveResizedBySize("smalltobig.png"1000500
    dJeez's Avatar
    Sol System
    Hier is +/- wat ik gebruikte op Vande Moortel :
    PHP Code:
    function generate_thumbnail($source$dest$target_size)
        if (!
    file_exists($source))
            throw new
    Exception("Couldn't locate file '$source'.");
    $info getimagesize($source);
    $newwidth $info[0];
    $newheight $info[1];
    // resize
    if ($newwidth $newheight)
    $xstart 0;
    $ystart round(($newheight-$newwidth)/2);
    $xstop $newwidth;
    $ystop $newwidth;
        else if (
    $xstart round(($newwidth-$newheight)/2);
    $ystart 0;
    $xstop $newheight;
    $ystop $newheight;
        else
    $xstart 0;
    $ystart 0;
    $xstop $newwidth;
    $ystop $newheight;
        switch(
    $info[2])
            case
    IMG_GIF:
    $original imagecreatefromgif($source);
                if (!
    $original)
                    throw new
    Exception("Couldn't open GIF '$source'.");
    $thumbnail imagecreate($target_size$target_size);
    imagecopyresampled($thumbnail$original00$xstart$ystart$target_size$target_size$xstop$ystop);
    imagegif($thumbnail$dest);
                break;
            case
    IMG_JPG:
            case
    IMG_JPEG:
    $original imagecreatefromjpeg($source);
                if (!
    $original)
                    throw new
    Exception("Couldn't open jpeg '$source'.");
    $thumbnail imagecreatetruecolor($target_size$target_size);
    imagejpeg($thumbnail$dest);
                break;
            case
    IMG_PNG:
    $original imagecreatefrompng($source);
                if (!
    $original)
                    throw new
    Exception("Couldn't open PNG '$source'.");
    imagepng($thumbnail$dest);
                break;
        return
    TRUE;
    De parameters zijn respectievelijk de bestandsnaam van het originele bestand, die van de thumbnail en de dimensie van de thumbnail (in dit geval een vierkant, dus ook maar 1 parameter ).
    Misschien kan je best ook een chmod doen van de afbeelding na het wegschrijven zodat die via FTP verwijderbaar is (0644 should do the trick).
    Pastafarian by choice
    FurtiveDuck's Avatar
    Misschien es checken in de broncode van netlog?
