06-12-2008, 13:58 #1Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
afbeelding knipperen laten beëindigen
Hallo,
<script type="text/javascript">
function blinkImages() {
blinkArray = new Array();
blinkElements = document.getElementsByTagName('*');
for(x = 0; x < blinkElements.length; x++) {
blinkElement = blinkElements[x];
elementClass = blinkElement.className;
if(elementClass == 'blink') {
if(blinkElement.style.visibility == 'hidden'){
blinkElement.style.visibility = 'visible';
} else {
blinkElement.style.visibility = 'hidden';
setTimeout("blinkImages();", 150);
</script>
Dit script laat je afbeedling knipperen, maar dit gaat continue verder.
Hoe laat ik dit nu bv na 5x knipperen stoppen?
Bedankt,
LPSN: FuaarK
batman comics
06-12-2008, 15:39 #2
Probeer eens 150 lager te zette
06-12-2008, 15:57 #3Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
dat is de timeout tussen visible en hidden, dus de tijd hoe lang het duurt voor er geswitcht moet worden.
Dus hoe lager hoe rapper het knippert, hoger trager.PSN: FuaarK
batman comics
06-12-2008, 16:35 #4Approved 9liver
- 18/01/04
- Melle
- 10,535
- 56 (100%)
- 27/102
Code:<script type="text/javascript"> <!-- function blinkImages() { blinkImages(0); } function blinkImages(int i) { blinkArray = new Array(); blinkElements = document.getElementsByTagName('*'); for(x = 0; x < blinkElements.length; x++) { blinkElement = blinkElements[x]; elementClass = blinkElement.className; if(elementClass == 'blink') { if(blinkElement.style.visibility == 'hidden'){ blinkElement.style.visibility = 'visible'; } else { blinkElement.style.visibility = 'hidden'; } } } if(i<5) { i++; setTimeout("blinkImages(i);", 150); } } // --> </script>// JavaScript Document“In terms of how we evaluate schooling, everything is about working by yourself. If you work with someone else, it’s called cheating. Once you get out in the real world, everything you do involves working with other people.”
PSN: Cycloon - Final Fantasy XIV: A realm reborn characterno votes
06-12-2008, 17:02 #5Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
@cycloon
werkt dit bij u? want bij mij wilt dit spijtig genoeg niet werken :'(PSN: FuaarK
batman comics
06-12-2008, 17:25 #6Approved 9liver
- 18/01/04
- Melle
- 10,535
- 56 (100%)
- 27/102
Kheb het eerlijk gezegd niet getest
Hebt ge een pagina waar dit op draait? Dan kan ik wel ff checken wat er precies fout gaat.
Edit: Ik denk dat ik het probleem weet:
Code:<script type="text/javascript"> <!-- function blinkImages() { blinkImages(0); } function blinkImages(int i) { blinkArray = new Array(); blinkElements = document.getElementsByTagName('*'); for(x = 0; x < blinkElements.length; x++) { blinkElement = blinkElements[x]; elementClass = blinkElement.className; if(elementClass == 'blink') { if(blinkElement.style.visibility == 'hidden'){ blinkElement.style.visibility = 'visible'; } else { blinkElement.style.visibility = 'hidden'; } } } if(i<5) { i++; setTimeout("blinkImages("+i+");", 150); } } // --> </script>// JavaScript DocumentLast edited by Cycloon; 06-12-2008 at 17:31.
06-12-2008, 17:45 #7Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
99 CENT FUIF
aub, erg bedankt trouwens, moest er hier karma bestaan . . .
edit:
index is nu met jouw laatste versie die spijtig genoeg ook niet werktPSN: FuaarK
batman comics
06-12-2008, 18:03 #8Approved 9liver
- 18/01/04
- Melle
- 10,535
- 56 (100%)
- 27/102
Ik heb maar ff zitten google'n, blijkbaar mag de int daar niet staan bij de parameters. function blinkImages(int i) moet dus worden function blinkImages(i).
Ik gebruik JS nauwelijks dus de syntax is me ook weinig bekend, ik hoop dat het deze keer wel werkt
06-12-2008, 18:06 #9Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
nog niet verder gekeken maar nu reageert hij door die foto volledig ongezien te laten, volledig hidden dus
edit:
als ik deze code
er achteraan zit toont hij ook niks, zit ik tussen de haakjes een getal dan toont hij mijn afbeelding wel
edit2:
vergeet mijn 1e edit, wat een onzin
PSN: FuaarK
batman comics
06-12-2008, 19:11 #10Approved 9liver
- 18/01/04
- Melle
- 10,535
- 56 (100%)
- 27/102
Het probleem is zeker dat hij na 5 keer net hidden staat. Je moet die waarde op het einde van de functie zelf maar even aanpassen dan
06-12-2008, 20:15 #11Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
geraak er niet meer aan uit
dit is een simpelere code
dit juist voor /html<script language="javascript">
function blinkId(id) {
var i = document.getElementById(id);
if(i.style.visibility=='hidden') {
i.style.visibility='visible';
} else {
i.style.visibility='hidden';
setTimeout("blinkId('"+id+"')",180);
return true;
</script>
<script type="text/javascript">blinkId('centheader');</script>
maar zoals altijd blijft hij knipperen!PSN: FuaarK
batman comics
06-12-2008, 20:25 #12Approved 9-lifer
- 23/05/03
- Stavanger
- 1,837
- 10 (100%)
- 1/4
?Code:<script language="javascript"> blinki = 0; function blinkId(id) { var i = document.getElementById(id); if(i.style.visibility=='hidden') { i.style.visibility='visible'; } else { i.style.visibility='hidden'; } if(blinki<10){ blinki++; setTimeout("blinkId('"+id+"')",180); } return true; } </script>
edit: ups, 10 keer dus ipv 5
06-12-2008, 20:35 #13Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
lol bedankt het werkt, niet 100% juist blinki<10 dat hij er dan 10 blinkt, maar wat maakt het mij uit
Bedankt 9lives members
voordiegene die het ook mss kunnen gebruiken
dit in de head sectie:
dit vlak voor </html><script language="javascript">
blinki = 0;
} else {
if(blinki<10){
blinki++;
return true;
</script>
<script type="text/javascript">blinkId('div_id');</script>Last edited by Lork; 06-12-2008 at 20:40.
PSN: FuaarK
batman comics
06-12-2008, 21:13 #14Approved 9-lifer
- 23/05/03
- Stavanger
- 1,837
- 10 (100%)
- 1/4
06-12-2008, 23:21 #15Member
- 20/10/04
- Merelbeke
- 1,579
- 29 (97%)
karma!
PSN: FuaarK
batman comics
