    AssassiN's Avatar
    Deinze
    VB.net console: sql probleem
    yu
    Ik heb dus een console application aangemaakt met deze code:
    Code:
    Option Explicit On
    Option Strict On
    Module module1
        Sub main()
            Dim Request As System.Net.HttpWebRequest
            Dim Response As System.Net.HttpWebResponse
            Dim MyCredentialCache As System.Net.CredentialCache
            Dim strPassword As String
            Dim strDomain As String
            Dim strUserName As String
            Dim strCalendarURI As String
            Dim strQuery As String
            Dim bytes() As Byte
            Dim RequestStream As System.IO.Stream
            Dim ResponseStream As System.IO.Stream
            Dim ResponseXmlDoc As System.Xml.XmlDocument
            Dim HrefNodes As System.Xml.XmlNodeList
            Dim SubjectNodeList As System.Xml.XmlNodeList
            Dim LocationNodeList As System.Xml.XmlNodeList
            Dim StartTimeNodeList As System.Xml.XmlNodeList
            Dim EndTimeNodeList As System.Xml.XmlNodeList
            Dim BusyStatusNodeList As System.Xml.XmlNodeList
            Dim InstanceTypeNodeList As System.Xml.XmlNodeList
            Dim OrganizerNodeList As System.Xml.XmlNodeList
            Try
                strUserName = !user!
                strPassword = !pass!
                strDomain = !domein!
                strCalendarURI = "http://!domein!/exchange/!virtual_user!/calendar/"
                strQuery = "<?xml version=""1.0""?>" & _
                           "<a:searchrequest xmlns:a=""DAV:"">" & _
                           "<a:sql>SELECT ""urn:schemas:calendar:location"", ""urn:schemas:httpmail:subject"", " & _
                           """urn:schemas:calendar:dtstart"", ""urn:schemas:calendar:dtend"", " & _
                           """urn:schemas:calendar:busystatus"", ""urn:schemas:calendar:instancetype"",  ""urn:schemas:calendar:organizer"" " & _
                           "FROM Scope('SHALLOW TRAVERSAL OF """ & strCalendarURI & """') " & _
                           "WHERE NOT ""urn:schemas:calendar:instancetype"" = 1 " & _
                           "AND ""DAV:contentclass"" = 'urn:content-classes:appointment' " & _
                           "AND ""urn:schemas:calendar:dtstart"" > '2003/06/01 00:00:00' " & _
                           "ORDER BY ""urn:schemas:calendar:dtstart"" ASC" & _
                           "</a:sql></a:searchrequest>"
                MyCredentialCache = New System.Net.CredentialCache
                MyCredentialCache.Add(New System.Uri(strCalendarURI), "NTLM", New System.Net.NetworkCredential(strUserName, strPassword, strDomain))
                Request = CType(System.Net.WebRequest.Create(strCalendarURI), System.Net.HttpWebRequest)
                Request.Credentials = MyCredentialCache
                Request.Method = "SEARCH"
                bytes = System.Text.Encoding.UTF8.GetBytes(strQuery)
                Request.ContentLength = bytes.Length
                RequestStream = Request.GetRequestStream()
                RequestStream.Write(bytes, 0, bytes.Length)
                RequestStream.Close()
                Request.ContentType = "text/xml"
                Request.Headers.Add("Translate", "F")
                Response = CType(Request.GetResponse(), System.Net.HttpWebResponse)
                ResponseStream = Response.GetResponseStream()
                ResponseXmlDoc = New System.Xml.XmlDocument
                ResponseXmlDoc.Load(ResponseStream)
                HrefNodes = ResponseXmlDoc.GetElementsByTagName("a:href")
                SubjectNodeList = ResponseXmlDoc.GetElementsByTagName("e:subject")
                LocationNodeList = ResponseXmlDoc.GetElementsByTagName("d:location")
                StartTimeNodeList = ResponseXmlDoc.GetElementsByTagName("d:dtstart")
                EndTimeNodeList = ResponseXmlDoc.GetElementsByTagName("d:dtend")
                BusyStatusNodeList = ResponseXmlDoc.GetElementsByTagName("d:busystatus")
                InstanceTypeNodeList = ResponseXmlDoc.GetElementsByTagName("d:instancetype")
                OrganizerNodeList = ResponseXmlDoc.GetElementsByTagName("d:organizer")
                If SubjectNodeList.Count > 0 Then
                    Console.WriteLine("Calendar items...")
                    Dim i As Integer
                    For i = 0 To SubjectNodeList.Count - 1
                        Console.WriteLine("  Subject:       " + SubjectNodeList(i).InnerText)
                        Console.WriteLine("  Location:      " + LocationNodeList(i).InnerText)
                        Console.WriteLine("  Start time:    " + StartTimeNodeList(i).InnerText)
                        Console.WriteLine("  End time:      " + EndTimeNodeList(i).InnerText)
                        Console.WriteLine("  Busy status:   " + BusyStatusNodeList(i).InnerText)
                        Console.WriteLine("  Organizer:      " + OrganizerNodeList(i).InnerText)
                    Next
                Else
                    Console.WriteLine("No calendar items found ...")
                End If
                ResponseStream.Close()
                Response.Close()
            Catch ex As Exception
                Console.WriteLine(ex.Message)
            End Try
        End Sub
    End Module
    (heb ik gehaald vanuit webdav(linkje)
    Kort gezegd: deze code haalt de nodige informatie uit een meeting(naam, starttijd, eind tijd, locatie) in de agenda van outlook 2003
    Ik moet er nu voor zorgen dat deze zaken in een sql tabel uitgeschreven worden, ze mogen niets overschrijven.
    vraag:
    - Hoe met ik verbinden met deze sql database?(dit programma gaat draaien op de server zelf waarop exchange en deze database staat)
    thanks!
    edit: Probleem opgelost met het splitsen
