    PHP: formulier werkt niet correct
    op een pagina gebruik ik volgend formulier :
    PHP Code:
    <?php
    if( $_POST['send_request'] )
    $regex['first_name'] = "^."#require atleast one charecter
    $regex['last_name'] = "^."#require atleast one charecter
    $regex['email'] = "^[_a-zA-Z0-9-]+(\.[_A-Za-z0-9-]+)*@[A-Za-z0-9-]+(\.[A-Za-z0-9-]+)*(\.[A-Za-z]{2,3})$*"#must be valid email
    $form_errors['first_name'] = "Gelieve een voornaam op te geven";
    $form_errors['last_name'] = "Gelieve een naam op te geven";
    $form_errors['email'] = "Gelieve een correct e-mailadres op te geven";
            foreach(
    $regex as $k => $v
                  if( !
    ereg$v $_POST[$k] ) )
    $errors[$k] = $form_errors[$k];
            if( ! isset(
    $errors ) ) {
    $send_to "sales@staff.be";
    $send_subject "Info request NL";
    $send_from "Info request form";
    $mesg  "The following person has submitted an info request form:\n\n";
    $mesg .= "First Name   : ".$_POST['first_name']."\n";
    $mesg .= "Last Name    : ".$_POST['last_name']."\n";
    $mesg .= "Organization : ".$_POST['company']."\n";
    $mesg .= "Phone        : ".$_POST['phone']."\n";
    $mesg .= "Email        : ".$_POST['email']."\n";
    $mesg .= "Inquiry      :\n\n".$_POST['inquiry']."";
    mail$send_to$send_subject$mesg,
    "From: ".$send_from."\r\n"
    ."Reply-To: ".$send_from."\r\n"
    ."X-Mailer: PHP/" phpversion());
    $thank_you 1;
    $labels['first_name'] = "Voornaam";
    $labels['last_name'] = "Familienaam";
    $labels['email'] = "E-mail";
    $labels['phone'] = "Telefoon";
    $labels['company'] = "Bedrijf";
    $labels['inquiry'] = "Uw vraag/opmerking";
    $labels['thankyou'] = "Bedankt voor uw vraag/opmerking. U krijg zo spoedig mogelijk antwoord.";
    <?php
    if(!  $thank_you ) { ?>
    <form name="form1" method="post" action="">
        <table width="0%"  border="0" cellspacing="0" cellpadding="2">
           <tr>
               <td class="input"><?= $labels['first_name'?>:</td>
               <td>
                    <?php if( isset($errors['first_name'] ) ) { ?>
                    <font size = "1" color="red"><?= $errors['first_name'?></font><br />
                    <?php ?>
                    <input class="inputbox2" name="first_name" type="text" size="30" id="first_name" value="<?= $_POST['first_name'?>"></td>
              </tr>
           <tr>
               <td class="input"><?= $labels['last_name'?>: </td>
               <td>
                    <?php if( isset( $errors['last_name'] ) ) { ?>
                    <font size = "1" color="red"><?= $errors['last_name'?></font><br />
                    <?php ?>
                    <input class="inputbox2" name="last_name" type="text" id="last_name" size="30" value="<?= $_POST['last_name'?>"></td>
              </tr>
           <tr>
               <td class="input"><?= $labels['company'?>: </td>
               <td><input class="inputbox2" name="company" type="text" id="company" size="30" value="<?= $_POST['company'?>"></td>
              </tr>
           <tr>
               <td class="input"><?= $labels['email'?>: </td>
               <td>
                    <?php if( isset( $errors['email'] ) ) { ?>
                    <font size = "1" color="red"><?= $errors['email'?></font><br />
                    <?php ?>
                    <input class="inputbox2" name="email" type="text" id="email" size="30" value="<?= $_POST['email'?>"></td>
              </tr>
           <tr>
               <td class="input"><?= $labels['phone'?>:</td>
               <td><input class="inputbox2" name="phone" type="text" id="phone" size="30" value="<?= $_POST['phone'?>"></td>
              </tr>
           <tr>
               <td valign="top" class="input"><?= $labels['inquiry'?>: </td>
            <td><textarea class="box3" name="inquiry" cols="30" rows="7" id="inquiry"><?= $_POST['inquiry']?></textarea>
            </div></td>
              </tr>
           <tr>
               <td valign="top">&nbsp;</td>
               <td><div align="left"><br><bR>
                   <input type="submit" name="Submit" value="Verzenden">
                  <input name="send_request" type="hidden" id="send_request" value="1">
               </div></td>
              </tr>
           </table>
    </form>
    <?php } else { ?>
    <p><font color="green"><b><?= $labels['thankyou'?></b></font></p>
    <?php ?>
    ziet er iemand de fout?
    bij het openen van de pagina zie ik onmiddellijk de error messages :
    Gelieve een correct e-mail adres op te geven
    euhm, iemand ?
    mars
    if( isset($_POST['send_request'] ) )
    edit: en n/o, maar laat dit script hermaken door iemand die wel php kan. Ik denk dat er geen regel zonder fout is.
    het werkt nog steeds niet
    ok, de error messages komen niet meer tevoorschijn bij het laden van de pagina, maar ze komen ook niet tevoorschijn als men de naam niet invult
    en euhm, wat is er dan zoal allemaal mis? hulp zou leuk zijn
    dan heb ik eens en voor altijd een formulier dat werkt, met alles erop en eraan
    ik denk trouwens dat veel te maken heeft met de php versie
    op een server met PHP4 werkt dit dus perfect, maar helaas moet ik werken met PHP5, en daar krijg ik dus geen enkele error message indien men bv niets invult
    dJeez's Avatar
    Sol System
    Quote Originally Posted by KoenDK View Post
    Ooit al gehoord van de error_reporting functie in PHP?
    En wat je code betreft : het zou misschien wel eens kunnen helpen dat je de $errors array ook op voorhand als array definieert alvorens je er waardes in gaat steken, en vervolgens werkt met empty ipv isset om te testen of er foutmeldingen gezet zijn (als je op die manier wil blijven werken).
    Pastafarian by choice
    mars
    -je gebrukt variabelen zonder dat ze geïntiailiseerd zijn
    -Je gebruikt bestaanscontrole met if($var) ipv if(isset($var))
    -Je gebruikt de te vermijden <?= tag
    Maar ik had blijkbaar overdreven daarstraks.
    Ook raad ik ereg af ten voordele van preg_match.
    en zoals djeez zegt: error_reporting(E_ALL), a debugger's best friend.
    ik heb het idd door iemand anders kunnen laten doen, alles werkt eigenlijk nu
    de check wordt gedaan via een js
    er klopt echter iets niet met mijn php syntax want de mail wordt niet verstuurd
    PHP Code:
    <?php
    if(isset( $_POST['submit'] ))
    $send_to "testertje@gmail.com";
    $sendto "test contact";
    $send_subject "subject";
    $send_from $_POST['email'] . "<" $_POST['email'] . ">";
    $mesg  "Bla :\n\n";
        <p><font color="green"><b>Vriendelijk bedankt voor uw bericht.</p>
    <?php
    else
    <form>
    blablabla
    <input type="submit" name="submit" value="Verzenden" />
    </form>
    iemand enig idee?
    ps : ik heb error_reporting(E_ALL); toegevoegd aan mijn formulier, maar ik krijg niets te zien
    *edit : ik denk dat ik het weet, die 'name' is denk ik niet correct als ID,
    ik ga het eens proberen met een iets specifiekere naam...
