Thread: can't connect to localhost
13-09-2004, 19:07 #1
'k heb een probleem, 'k ben aan't mappen voor ET, en als'k mijn map wil testen, blijft hij altijd hangen tijdens het conecten to the local host....2dage geleden luket het nog, heb pb al manueel geupdate, 'k heb ook al alles 2 keer geherinstalleerd, iemand hulp ?????
13-09-2004, 19:58 #2
]\sv_pure 0
]\G_gametype 2
g_gametype will be changed upon restarting.
]\devmap jan
------ Server Initialization ------
Server: jan
RE_Shutdown( 0 )
Hunk_Clear: reset the hunk ok
----- FS_Startup -----
Current search path:
C:\Program Files\Wolfenstein - Enemy Territory\etmain\xposed.pk3 (75 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\www.sieonline.net.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\wbb_opencupcustom.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\VHmapcycle.pk3 (4 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\venice.pk3 (330 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\vengeance_b1.pk3 (84 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\v1_drakir.pk3 (436 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\trial.pk3 (15 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\trainyard.pk3 (56 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\the_town.pk3 (24 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\temple_final.pk3 (57 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\temple3.pk3 (49 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\TeK-cmpgns.campaign.pk3 (3 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\tc_venice_rc2.pk3 (324 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\tc_base.pk3 (63 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\tc_base+6.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\t6.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\svarvadel.pk3 (73 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\supplydepot2.pk3 (46 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\slayers_sept.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\slayers_sept.616f3e46.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\skycust2.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\SG_1945_final.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\SG_1945_final.eb34a306.pk3 (217 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\saberpeak_final.pk3 (243 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\rtcc2.pk3 (41 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\rommel_b1.pk3 (118 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\Riverwar_V2.pk3 (102 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\rhine2.pk3 (117 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pool.pk3 (61 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\password2_final.pk3 (101 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pakbbucket10.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak9725.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak9174.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak9172.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak8790.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak79.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak7238.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak716.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak6780.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak6403.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak6303.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak5985.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak5709.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak1.pk3 (10 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak05.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\pak0.pk3 (3725 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\onecampaign.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\night_crawlers_final.pk3 (110 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\mp_bin.pk3 (4 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\maps6.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\mappak.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\mapmedia.pk3 (10 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\lights.pk3 (51 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\headshot_united.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\germany.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\Gamersarea.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\fun_beach2.pk3 (43 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\fragland10.pk3 (4 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\FF010804.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\fcasr.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\eurotomb13.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\et_ice.pk3 (61 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\etmapcycle.pk3 (3 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\etmapcycle.bbe8686a.pk3 (3 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\etmapcycle.5839a7ff.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\etcampaign.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\egnshrub.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\egnshrub.e186507d.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\egn2.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\daybreak.pk3 (98 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\Complete.pk3 (5 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\common.pk3 (43 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\cmpgn_C42v7b.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\cmpgn_C42v7a.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\cmpgn_C42v6.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\cathedral_b3.pk3 (61 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\caen.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\Brood10.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\beta15.pk3 (2 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\beach.pk3 (5 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\beach.174085d5.pk3 (45 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\bayraid_beta2.pk3 (66 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\axislab_final_sp1.pk3 (3 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\axislab_final.pk3 (172 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\astro-skies.pk3 (11 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\1944_beach.pk3 (60 files)
C:\Program Files\Wolfenstein - Enemy Territory\etmain\10maphb1.pk3 (1 files)
C:\Program Files\Wolfenstein - Enemy Territory/etmain
14622 files in pk3 files
------- Game Initialization -------
gamename: etmain
gamedate: Sep 5 2003
Not logging to disk.
Gametype changed, clearing session data.
Enable spawning!
Disable spawning!
ERROR No 'script_multiplayer' found in map
ERROR No tracemap found for map
0 teams with 0 entities
Setting MOTD...
PunkBuster Client: Connected to Server loopback
PunkBuster Client: Master Query Sent to (MASTER4.EVENBALANCE.COM) 216.40.250.37
Need paks: etmain/trainyard.pk3 (local file exists with wrong checksum)
Need paks: @etmain/trainyard.pk3@etmain/trainyard.00000000.pk3
clientDownload: 0 : beginning "etmain/trainyard.pk3"
'=[TSD]=SCISS0' downloading at sv_dl_maxrate (42000)
PunkBuster Client: Received Master Security Information
Unknown command "+stats"
ERROR: Disconnected from server
----- Server Shutdown -----
==== ShutdownGame ====
RE_Shutdown( 0 )
----- R_Init -----
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce FX 5200/AGP/SSE2
GL_VERSION: 1.4.1
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture
GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_texture_border_clamp
GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos
GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax
GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap
GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object
GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region
GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance
GL_NV_fragment_program GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query
GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners
GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4
GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3
GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2
GL_NVX_ycrcb GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
GL_WIN_swap_hint WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
MODE: 6, 1024 x 768 fullscreen hz:60
GAMMA: hardware w/ 0 overbright bits
CPU: Intel Pentium III
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 32
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
NV distance fog: disabled
Initializing Shaders
----- finished R_Init -----
PunkBuster Client: Not Connected to a Server
]/condump test.txt
Dumped console text to test.txt.
Console DUmp...Er staan 2 errors in ivm multi-player map enzo, maar daar kan't ni aan liggen, 'khad voor te testen gewoon nen box gemaakt met al't nodig erin. Als iemand hier de fout uit kan hale....no votes
14-09-2004, 14:23 #3
ok, 'k heb al de custom-map erafgesmeten...nu een klein vraagje, hoe voorkom ik dit in 't vervolg ??? nu werk't (en zeg niet geen custom-maps downe)
14-09-2004, 16:25 #4
is een bug in de engine, dat als je teveel pk3 files hebt uw et niet kan hosten
Day by day photoblog: http://w.twwwo.be/no votes
14-09-2004, 18:11 #5
en wa is zo't maximum?
15-09-2004, 13:14 #6
Hm, dat probleem hadden we indertijd ook met de TN-rtcw-server.
Dacht dat we toen ongeveer een max van 10 customs hadden staan tussen de off. maps. Als we er meer gebruikten begon de server rare kuren te vertonen (cst. reloaden maps, crashes enz.)
Voor alle veiligheid zou ik niet boven de 20-25 maps gaan. (imo eh, een juist aantal kan ik er niet meer opkleven)Dip me in chocolate and throw me to the lesbians.
♥ Independent ♥ websiteno votes
15-09-2004, 16:01 #7
er is niet echt een maximum denk ik, hangt ook af van het aantal mods dat geinstalleerd is dacht ik
17-09-2004, 13:09 #8
ok, thx guys
