09-09-2004, 14:48 #1
javascript : random gekozen banner
Is het mogelijk om de banner van een site (achtergrond van een tabelcel) random te laten kiezen als de pagina geladen wordt? Mss aan de hand van een javascript dat een random-getal genereert ts. 0 en 50...
De banners zouden in een map /images/banners zitten met filenames zoals: banner1.png, banner2.png,... of gewoon 1.png, 2.png,...
Lukt dit en zoja hoe??
Thxw00t!no votes
09-09-2004, 15:04 #2
http://games.telenet.be/forum/showth...69#post3902018
stukje random image.no votes
09-09-2004, 18:25 #3
OK thanks!
w00t!no votes
09-09-2004, 19:50 #4
Misschien ietwat te vroeg gejuicht..
ziet iemand hierin de fout?Code:<html> <head> <title>Random gekozen banners</title> </head> <body> <table border="1" width="100%"> <tr> <script language="JavaScript" type="text/javascript"> <!-- image = new Array(33); image[0] = "images\elements\banners\0.jpg"; image[1] = "images\elements\banners\1.jpg"; image[2] = "images\elements\banners\2.jpg"; image[3] = "images\elements\banners\3.jpg"; image[4] = "images\elements\banners\4.jpg"; image[5] = "images\elements\banners\5.jpg"; image[6] = "images\elements\banners\6.jpg"; image[7] = "images\elements\banners\7.jpg"; image[8] = "images\elements\banners\8.jpg"; image[9] = "images\elements\banners\9.jpg"; image[10] = "images\elements\banners\10.jpg"; image[11] = "images\elements\banners\11.jpg"; image[12] = "images\elements\banners\12.jpg"; image[13] = "images\elements\banners\13.jpg"; image[14] = "images\elements\banners\14.jpg"; image[15] = "images\elements\banners\15.jpg"; image[16] = "images\elements\banners\16.jpg"; image[17] = "images\elements\banners\17.jpg"; image[18] = "images\elements\banners\18.jpg"; image[19] = "images\elements\banners\19.jpg"; image[20] = "images\elements\banners\20.jpg"; image[21] = "images\elements\banners\21.jpg"; image[22] = "images\elements\banners\22.jpg"; image[23] = "images\elements\banners\23.jpg"; image[24] = "images\elements\banners\24.jpg"; image[25] = "images\elements\banners\25.jpg"; image[26] = "images\elements\banners\26.jpg"; image[27] = "images\elements\banners\27.jpg"; image[28] = "images\elements\banners\28.jpg"; image[29] = "images\elements\banners\29.jpg"; image[30] = "images\elements\banners\30.jpg"; image[31] = "images\elements\banners\31.jpg"; image[32] = "images\elements\banners\32.jpg"; image[33] = "images\elements\banners\33.jpg"; index = Math.floor(Math.random() * image.length); document.write("<tr background='" + image[index] + "' />"); // --> </script> <br> <br> <br> </tr> </table> </body> </html>w00t!no votes
09-09-2004, 20:07 #5Member
- 18/07/02
- Deurne
- 3,854
- 14/14
meerdere, misschien maar eens eerst html leren voor je hiermee begint:
Code:<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html> <head> <meta http-equiv="content-type" content="text/html;charset=UTF-8" /> <title></title> <style type="text/css"><!-- body{background-color:#fff;font-family:tahoma;font-size:12px;} --></style> <script type="text/javascript"><!-- function image(){ image = new Array(2); // aantal aanpassen als je ze terug toevoegt image[0] = "images\elements\banners\0.jpg"; image[1] = "images\elements\banners\1.jpg"; index = Math.floor(Math.random() * image.length); document.write('<img src="'+ image[index] + '" alt="" />'); } --></script> </head> <body> <div> <table><tr><td><script type="text/javascript"><!-- image(); --></script></td></tr></table> </div> </body> </html>no votes
09-09-2004, 20:18 #6
waarom niet gewoon zo?
Zo moet je ze niet in een array steken (de pictures 1.jpg tot en met 50.jpg moeten wel op de webspace staan dan.Code:<script type="text/javascript"> rand1=Math.random()*50; rand=Math.round(rand1); document.write("<img src='images/elements/banners/"+rand+".jpg' alt=''>"); </script>
Disno votes
09-09-2004, 22:23 #7Member
- 27/05/03
- Aarschot
- 2,403
doe je niet best Math.random()*50 + 1 ??
omdat er random getalllen worden gegenereerd van 0 tot 9 ofzo dacht ik en zonder die +1 kom je natuurlijk nooit aan 50no votes
09-09-2004, 22:48 #8
dat is als je gebruikt maakt van Math.floor() anders voldoet het om *50 te gebruiken.
voorbeeldje :
0.991324452 * 50 = 49,5662226
round : 50
floor : 49
0.991324452 * 50 +1 = 50,5662226
round : 51
floor : 50Last edited by servi; 09-09-2004 at 22:50.
09-09-2004, 23:29 #9Member
- 27/05/03
- Aarschot
- 2,403
ok, maar als je bv krijgt 0.00012 ofzo, die kans bestaat ook, dan gaat em die afronden op 0.
en ge hebt geen foto die 0.jpg heet.
ge kunt in de geval wel een if maken die ervoor zorgt da er een neiuw random getal wordt gemaakt als getal 0 moest zijn.no votes
09-09-2004, 23:32 #10
dat is in uw geval het probleem, niet bij de code die is voorgesteld. Hij heeft immers wel een 0.jpg-bestand.
voorbeeld :
0,00998 * 50 = 0,499
afgerond : 0
floor : 0
0,00998 * 50 + 1 = 1,499
afgerond :1
floor : 1Last edited by servi; 09-09-2004 at 23:33.
