Thread: JS: show ip
    3020 Herent
    11 (100%)
    JS: show ip
    Bestaat er een javascriptje om je huidige ip te tonen?
    den Acid Burn's Avatar
    Aarschot
    tuurlijk,
    just google it!
    There are only 10 types of people, those who understand binary and those who don't.
    chown -R us ~/base
    aka N`Kr1pt
    [Scratch]'s Avatar
    Peer
    Google doet toch wonderen soms
    Code:
    <!-- ONE STEP TO INSTALL IP ADDRESS:
      1.  Copy the coding into the HEAD of your HTML document  -->
    <!-- STEP ONE: Paste this code into the HEAD of your HTML document  -->
    <HEAD>
    <SCRIPT LANGUAGE="JavaScript">
    <!-- This script and many more are available free online at -->
    <!-- The JavaScript Source!! http://javascript.internet.com -->
    <!-- Begin
    // http://www.kdcgrohl.com
    // Depending on your server set-up,
    // you may need to use the ".shtml"
    // extension [instead of the "html"
    // or "htm"] as the script uses Server
    // Side Includes. To display in the
    // title bar, exclude the
    //"<title></title>" code from the page.
    // This part gets the IP
    var ip = '<!--#echo var="REMOTE_ADDR"-->';
    // This part is for an alert box
    alert("Your IP address is "+ip);
    // This part is for the status bar
    window.defaultStatus = "Your IP address is "+ip;
    // This part is for the title bar
    document.write("<title>Your IP address is "+ip+"</title>");
    //  End -->
    </script>
    Lashknife's Avatar
    Boechout
    dees is eigenlijk wel geen javascript, maar ssi, met plain javascript gaat dit niet
    andere links zeggen iets over java.net.InetAddress.getLocalHost().getHostAddress (); en dat dit enkel werkt in Netscape met java enabled, dus dat is ook al geen javascript
    Visit www.holysh1t.net and http://tv.holysh1t.net and join #qlpickup.eu for Quake Live CTF (and TDM) pickup!
