Pagina 1 van 250 123451151101 ... Laatste
Discussie: Nintendo Switch
    Den_John's schermafbeelding
    8/09/02
    Temse
    3.348
    38 (100%)
    Exclamation Nintendo Switch
    WSJ: Nintendo Begins Distributing Software Kit for NX (Console + Handheld units)
    Nintendo Begins Distributing Software Kit for New NX Platform - WSJ
    The exact shape of the NX hardware isn’t yet clear. People familiar with the development plans said Nintendo would likely include both a console and at least one mobile unit that could either be used in conjunction with the console or taken on the road for separate use. They also said Nintendo would aim to put industry-leading chips in the NX devices, after criticism that the Wii U’s capabilities didn’t match those of competitors.
    From the new Dev portal:
    Our new website makes publishing simple
    This new website had one goal—to make your lives easier. We’re hard at work making more and better tools to help you self-publish, digitally publish, and publish at retail.
    Our plans are big, because yours are
    We’ll soon have advanced project tracking and ROM submission, project-based message boards and more, helping you with every step—from concept, to publish, to counting your accolades. And as always, you’ll have the best global developer support team ever, right from the start, making the Nintendo Developer Portal your go-to resource.
    Nintendo Dev Interface
    Our newest gem in the box is the NDI Client. NDI stands for Nintendo Dev Interface, but it’s really going to be your new best friend. The NDI Client will help make sure you have the optimal development environment on your development system — by downloading and installing it all for you! You can tailor it to the platform you’re developing for, the SDK you want, even the region you’re working in. It allows easy download of all the relevant guidelines and documentation you need to do your work. It even allows you to update the firmware of certain development kits.
    8/09/02
    Temse
    3.348
    38 (100%)
    Wat zijn jullie verwachtingen van Nintendo's next-gen (handheld-)console?
    Xtralecherus's schermafbeelding
    31/07/03
    Geraardsbergen
    6.449
    147 (100%)
    Dat ze er veel te laat met afkomen en dat de Wii-U veel te vroeg is afgeschaft. Ik zie hun alleen maar verder naar beneden gaan mocht het toch niet verkopen zeker als ze weer geen third party support zullen hebben. Daarbij zie ik mijzelf geen nieuwe console meer te kopen heb er vrijwel geen plaats meer voor. De PS3/PS4/Wii/Wii-u/X360 nemen alles al in.. En liever gewoon een console zonder al die gadgets. Een gewone controller en zelf muis of toetsenbord support is al meer dan genoeg. De Wii-U gamepad is mss een tof idee maar dat werkte niet goed uit + je kunt maar op 1 ding kijken ofwel je TV ofwel die gamepad. Leuk concept voor even, maar het is gewoon mislukt. Dus liever een gewone controller is nog altijd het beste dat er is. Voor vernieuwing kun je alleen maar zorgen dat je games leuk en aangenaam zijn. Mensen die constant vernieuwing verwachten moeten hun ogen opendoen want dat is niet meer zo evident voor games..
    1 leden vonden dit bericht nuttig.   Met citaat reageren Met citaat reageren
    ShadowJoker's schermafbeelding
    4/11/03
    Bilzen
    4.360
    98 (100%)
    Wat ik mij echter afvraag is de combinatie van console en handheld... Hoe gaat dat precies werken? Er werd gesproken over smartphones en tablets die zouden samenwerken met de NX, maar hoe gaat dat zitten met de 3DS (die is nog geen 5 jaren oud) en de volgende handheld.
    Op het moment klinkt de NX als een soort van WiiU 2 eigenlijk. Maar in plaats van de GamePad dat je gewoon smartphone/tablet kunt gebruiken als scherm om te spelen.
    zaj's schermafbeelding
    19/06/04
    4.991
    volgens mij gewoon een console zoals de wii u maar dan een standalone wii u pad die fungeert als handheld voor lichtere games
    12/06/05
    gnk
    1.296
    78 (99%)
    Citaat Oorspronkelijk geplaatst door Xtralecherus Bekijk bericht
    Uzelf tegenspreken is anders ook een kunst.
    kimme1975's schermafbeelding
    30/05/09
    Bever
    2.325
    Ik wacht rustig af wat het nieuwe platform gaat brengen. Het is vrij vroeg dat Nintendo met een nieuwe console/handheld op de markt komt... Hopelijk geen paniekreactie door de mindere verkopen van hun WiiU?
    Hack & slash hell yeah!!
    PSN: kimme1975
    Xbox Live: kimme1975
    reborn snake's schermafbeelding
    3/10/05
    963
    21 (100%)
    Volgens "bronnen" is de NX een console waar ze weer voor puur horsepower gaan. Diezelfde bronnen claimen dat de tech demo voor de NX zelfs niet deftig kan draaien op een courante PC (maar kan niet bevestigen of dit met 1 GPU is of in SLI)
    naart schijnt heeft nintendo ook al meerdere 3rd parties die aant werk zijn voor de NX.
    onder meer square enix
    If it's idiotproof we'll just build a better idiot
    50Euro's schermafbeelding
    15/08/03
    Moorsele
    2.552
    Als die nieuwe Zelda enkel uitkomt voor NX ziet Nintendo werkelijk geen € meer van mij. Nintendo is zo aan het prutsen geweest dat dit zeker geen day one aankoop zal zijn.
    En ik vind ook dat de Wii U te vroeg is gedropped.
    Nintendo ID & PSN & Xbox Live & Steam: FiFtyEuro
    19/06/04
    4.991
    Citaat Oorspronkelijk geplaatst door reborn snake Bekijk bericht
    allemaal goed en wel maar tegen 2017 lopen ze weer achter op pc's nuja natuurlijk is 1 jaar oude hardware beter dan de 8jaar oude hardware die nu in de wii u zit
    Nariwari's schermafbeelding
    21/04/07
    Londerzeel
    2.977
    47 (100%)
    Van alle geruchten hoop ik dat deze waar is. Ondanks geweldige art styles in hun games, vind ik toch ook dat ze op technisch vlak wat uit de hoek mogen komen. Het zal hun franchises zeker niet schaden, integendeel.
    3/10/05
    963
    21 (100%)
    Naart schijnt is het waar. Verschillende bronnen geven een dergelijk antwoord, waarond Wall street journal.
    "NX tech demo requires cutting edge chips to run on PC"
    Tis niet de eerste keer.
    Gamecube was ook krachtiger dan de PS2.
    Bernie.be's schermafbeelding
    7/08/11
    Riemst
    683
    19/06/04
    4.991
    en nintendo heeft weer niks geleerd. consoles launchen die net iets beter zijn als de huidige gen( die op zich al achterhaald zijn). ondertussen kan je lekker op 4k gamen aan 60 fps op pc met veel betere graphics terwijl nintendo de specs kopieert van consoles die met moeite 1080p doen.
    3/10/05
    963
    21 (100%)
    Citaat Oorspronkelijk geplaatst door zaj Bekijk bericht
    Lees ik dit goed?
    is deze pipo aan het kreften over fake specs?
    De typische intelligentie van die Pc mustard ricers he.
    Laatst gewijzigd door reborn snake; 29 maart 2016 om 06:33
Inloggen
Inloggen
