    SANTAX's Avatar
    Zele
    The Elder Scrolls IV: Oblivion
    Joo!
    Kzit me een redelijk irritant probleem in Oblivion:
    Kan iemand mij aub helpen want dit is één van men favo games maar als het zo doorgaat speel ik het nooit meer, puur uit frustratie! Haha.
    Al ne dikke thanks
    Sander
    EvilSwordfish's Avatar
    Keerbergen
    30 (100%)
    Zijn een paar bugs over, op de wiki vindt je eventuele oplossingen;
    - There is a glitch where Hal-Liurz, the Count's Steward, becomes stuck in the Chamber of the Lost. Every time you speak to her she will say "Please, wait here. I shall let the count know you are waiting for him" but will never go anywhere.
    PC Only This bug is fixed by the Unofficial Oblivion Patch.
    If you are on a PC, use the console to and type the following:
    player.moveto 0002EC35 (this will teleport you to Janus Hassildor)
    prid 0002EC2E (this will select Hal-Liurz)
    moveto player (this will teleport her to you)
    ** One possible way to finish the quest is to find the count, hit him, and have him chase you back to where Hal-Liurz is standing (without getting stopped by any guards along the way or by just resisting arrest if they stop you). Hal-Liurz should then go back to the Great Hall, although it may require similar forceful persuasion. You will need to pay the fine for assaulting the count and his steward, but then you can go to the Great Hall, wait for 24 hours, and the Count should show up to give you your reward - Alternatively, yielding to the count eliminates the fines and skips to the reward dialogue.
    Another way to complete this quest is to break into the Castle Hall and speak to the Count by yourself.
    - It is possible that at the end of this quest you can wait more than 24 hours but the Count will still only say "Please, go" when you talk to him. To fix the problem, you need to make Hal-Liurz bring the Count to you (even if you're already standing next to the Count, Hal-Liurz has to act as intermediary for the quest to be updated). Sometimes just talking to Hal-Liurz is sufficient. Otherwise, you can use a Command Humanoid spell to force her to follow you to wherever the Count is standing, at which point talking to Hal-Liurz should work to complete the quest. Sometimes it is possible that neither one will realize that 24 hours has passed. This generally happens when both are in the same room. Just force the two to part (Command Humanoid or just attacking and causing one to follow you) fixes this. Alternatively, you can demoralize either Hal-Liurz or the Count in order to make them leave the area.
    http://www.uesp.net/wiki/Oblivion:Cure_Vampirism#Bugs
    En als dat niet werkt, is er ook nog een console command voor vampirism op of af te zetten.
    http://vgstrategies.about.com/od/obl...ionVampiPC.htm
    --Because I can--
    SANTAX's Avatar
    Zele
    Merci man, da heeft dus wel degelijk geholpen!
