    Berchem
    The way i play my elementalist!!
    ll I can offer is how I learned to play this class (and of course I am by no means an expert).
    Disclaimer: *The following information is very high level and clearly there are a lot more details you can learn*
    For starters, use the Staff for group events and encounters. The Staff gives you the best ranged attacks, ranged AE abilities and AE healing. Using Air, you can hit many enemies at once and using water you can heal anyone close to the boss. A staff will usually get you gold in an event. I also use the staff in every story line quest. I just found it the only way to survive.
    For single combat, I personally found a scepter/dagger combo the best. There were many ways to control an enemy and kill them before they got to me.
    Dagger/Dagger is lots of fun but gets me killed the most.
    Using a focus as an offhand has yet to impress me. I kind of keep it in my bag for now.
    Just a few notes to help you along...
    1) Make sure you are dodge/rolling away from big attacks. Trolls can one shot you if you just stand there!
    2) Fire will typically kill things the fastest, but offers little in slowing down your attacker
    3) Water not only heals, but can slow down your attacker.
    4) Earth is a great attunement for kiting.
    5) Cycling between elements becomes a necessity as you get higher in level. I am currently level 13 and go through Air, fire, and water before killing anything.
    I hope this helps!
    Kalken
    euhhh.... que?
    M3nt0z's Avatar
    amaai, zo ne mooie uitleg. Ben echt veel beter er door geworden.
    [Dark-Fury]'s Avatar
    Oost-Vlaanderen
    Allemaal goe en wel maar 9lives is bij mijn weten nog altijd een nederlandstalig forum
    Ik snap da nooit waarom mensen hier in het engels beginnen posten.
    H_ans's Avatar
    Muizen
    211 (100%)
    I am very grateful for this very high level important information. Now I can finally play the game.
    Dropkick's Avatar
    Oostende
    Ah nu niet meer of zo?
    Als je dan toch wil "showen" met je talenkennis, zorg er dan tenminste ook voor dat deze onberispelijk is en dat je geen simpele fouten maakt zoals een verkeerde werkwoordsvervoeging.
    CuRv3's Avatar
    Tremelo
    9 (91%)
    i know from this moment that you have special powers when you click the 1 or 2 or 3 or 4 or 5 or 6 or 7 or 8 or 9 on the keyboard when you fight. It's better.
    diknmuis's Avatar
    STADEN
    29 (100%)
    Quote Originally Posted by CuRv3 View Post
    thx
    PSN:diknmuis
    XBL/steam: diknmuis (GoW4 - Horde)
    Uplay: muisdikn (The Division)
    Norea's Avatar
    Oost_Vlaanderen
    lol. 2xDagger it is for me .
    pfff sommige mensen -.-
    Misterblort's Avatar
    Ternat
    "5) Cycling between elements becomes a necessity as you get higher in level. I am currently level 13 and go through Air, fire, and water before killing anything."
    Zever, gezever ik ben lvl 19 en al wa ge nodig hebt is FIRE! 2->3->autoattack-> eventueel 4om weg te rollen, tegen dan zijn ze wel al dood ze..
    Fdzzaigl's Avatar
    Nogal een basic guide hé Een paar van mijn ervaringen (lvl 45 Elementalist).
    *Staff is inderdaad wel de beste keuze voor group events en tegen zergs in WvW. Het heeft ook veruit de beste healing van alle wapens.
    Niets kan in WvW op tegen de mogelijkheid om op een afstand enorme aoe neer te leggen. Je kan ook heel veel grond "afsluiten" voor enemies door daar muren van crippled / chilled of stunned (static field) te plaatsen.
    Water fields zijn zeer effectief als je ze kunt combineren met blast finishers van andere spelers, op die manier kan je zeer veel AOE healing doen.
    *Voor veel burst in PvP / PvE is staff echter niet het beste. Ik doe het meeste burst als scepter / dagger.
    In sPvP ben je redelijk kwetsbaar (echter wel zeer mobiel), maar kan je hele groups neerleggen in 1 fire burst.
    *Dagger / dagger heeft ook veel burst en is waarschijnlijk het beste om mensen te "chasen", aangezien je verschillende gap closers hebt.
    Hoofdzakelijk melee range is wel een nadeel.
    *Focus gebruik ik bijna nooit. Bijna al de abilities voor de focus zijn puur support. Misschien wel bruikbaar in instance groups of zoiets.
    Qua element switching: elke build heeft wel zijn "main" element waarin je het meeste tijd doorbrengt (in mijn geval: fire voor staff en lightning voor scepter/dagger), het komt erop neer om al je abilities te kennen en te switchen wanneer je er voordeel uit haalt (of wanneer je nog meer aoe's / effecten wil stacken).
    Vb: een ranger zit op u te vuren in WvW = switch naar earth en gebruik Magnetic Aura.
    BlackRose89's Avatar
    Londerzeel
    Quote Originally Posted by Misterblort View Post
    Yep, da's ook mijn tactiek, ik schakel ook wel af en toe is om naar water om te healen (healing rain). Maar meestal is dat zelfs niet nodig.
    Ternat
    Quote Originally Posted by BlackRose89 View Post
    mja ik vind in den tijd daje veranderd zijt en uwe healing rain gecast hebt en den andere dan nog dood doet hebde meer hp verloren dan als ge gewoon fire zou blijven spammen .. bij Veterans moede soms wel kiten
    Fdzzaigl's Avatar
    Zeker in PvP moet je constant switchen, je kunt wel fire blijven spammen maar je team is echt wel beter af als ge eens een healing rain en wat geysers op hun doet (ik gebruik ook altijd water elemental elite, die doet veel healing).
    + earth aoe is ook zeer krachtig.
    Lightning static field kan je gebruiken als de vijand door een kleine doorgang moet, gewoon static field erop en iedereen die door probeert te gaan is gestunned.
    Zeer handig wanneer je op bruggen vecht of wanneer de deur van een keep neergaat.
    VictorVonDoom's Avatar
    Halle
    ik swap verdurend tussen de attunements en ik vind het vreed gemakkelijk
    en de OP heeft gelijk
    Ik ben een ziel geteisterd met autisme. ben het beu dat mensen op mijn kap zitten hoe ik speel
