Thread: firmware 4.20 (26 juni)
25-06-2012, 21:06 #1Crew Member
- 15/11/03
- Brugge
- 28,881
- 158 (100%)
- 9 Post(s)
- 1485/1564
- meerdere saves tegelijk kopiëren
- meer instellingen voor automatisch uitschakelen
- officiële stereo headset: nu ook in films in surround; instellingen voor het geluid van je eigen microfoon
Under (Games) > (Saved Data Utility (PS3™), you can now select multiple saved data items, and then either delete or copy them as a group.
• You cannot use [Copy Multiple] to select data that is copy-protected.
• Some saved data cannot be copied.
• The upper right corner of the screen displays:
• the number of saved data items that are selected
• the total number of saved data items
• the total file size of the saved data items that are selected
You can now set the amount of time until the system automatically turns off. Under (Settings) > (Power Save Settings) > [System Auto-Off] you will be able amend the time for [Video/TV/Music/Photo] and for [Game/Other Features]:
• Video/TV/Music/Photo - After 1 Hour, After 2 Hours, After 3 Hours, After 4 Hours, After 5 Hours, OffIf you enabled [System Auto-Off] in system software prior to version 4.20, the selected time will be set for both [Video/TV/Music/Photo] and [Game/Other Features]. The default settings are [After 4 Hours] for [Video/TV/Music/Photo] and [After 1 Hour] for [Game/Other Features].
• Game/Other Features - After 1 Hour, After 2 Hours, After 3 Hours, After 4 Hours, After 5 Hours, Off
When the wireless stereo headset (CECHYA-0080) is connected, you can now adjust the sidetone level for microphone audio. Select [Sidetone] under (Settings) > (Accessory Settings) > [Audio Device Settings].
• Off: Disable microphone audio from the headset
• 1-5: Enable microphone audio from the headset
For those of you who use the Wireless Stereo Headset to watch Blu-ray or DVD movies on your PS3, this system software update will also enable virtual surround sound functionality, giving you a superior audio experience.no votes
25-06-2012, 21:15 #2The King of PlayStation
- 09/09/08
- Kaprijke
- 41,641
- 229 (100%)
- 17 Post(s)
- 873/1122
Heb zo'n headset maar die functie zal ik toch niet gebruiken denk ik, Blu-ray bekijk ik wel met de homecinema.
25-06-2012, 22:21 #3Member
- 06/02/04
- Sfeerland
- 3,525
- 74 (100%)
- 3/3
Niet echt iets dat de gemiddelde gamer zal opvallen, as always.
25-06-2012, 22:51 #4Approved 9-lifer
- 29/08/09
- Neerpelt
- 1,633
- 30 (100%)
Dus nu ga je je PS Plus saves ook allemaal in een keer kunnen selecteren?
GTA V
Xbox Live: Zwiep999
PSN: Zwiep999no votes
26-06-2012, 01:26 #5Platinum Member
- 21/11/11
- Vlaams-Brabant
- 8,762
- 4/51
26-06-2012, 01:31 #6Crew Member
- 15/11/03
- Brugge
- 28,881
- 158 (100%)
- 9 Post(s)
- 1485/1564
Media Server gebruiken. Speelt perfect mkv. En je kan ze kopiëren naar je PS3 in luttele minuten.
