    Keerbergen
    Help! Headset problem
    Help!
    I have a problem with my bluetooth headset (the one from Sony, for playstation).
    It doesn't work anymore in Call of Duty Black Opps! It is connected to my playstatin (I can see the blue light next to the headset in "Manage bluetooth devices"-menu.
    So no problem there, but in Call of Duty it doesn't work and there's no little speaker icon next to my nickname ...
    It 's been working for years and in the last 6 months this happened 3 times. The first 2 times I rebooted my PS3, deleted the headset, register again, connected, disconnected, rebooted again, etc. ... after a while it just worked again (after 20 minutes trying :-/), but now it won't work anymore.
    I just went to the store and bought a new one (from Nokia) and I have the same problem with it.
    I don't think it's the headset that causes the problem. They both work fine with my cell phone, no problem at all! But in Call of duty it doesn't work.
    Anyone an idea?
    Thanks
    nTFs's Avatar
    Lommel
    120 (100%)
    1 : Het is hier een Vlaams forum.
    2 : Post het eens in het juiste forum.
    http://www.9lives.be/forum/sony-playstation/
    I5-8600K | Asrock Z370 Extreme 4 | RTX 2070
    Keerbergen
    Ik heb de boodschap op verschillende fora gepost om de kans op een oplossing te vergroten.
    Omdat ik ervan uit ga dat de meeste gamers wel een woordje engels kunnen heb ik me de moeite bespaard om de uitleg in 2 talen te doen.
    Thanks for the tip anyway! ;-)
