29-07-2010, 14:34 #1Member
- 14/06/03
- Heverlee
- 741
Blizzard bevestigt de Starcraft 2 overheating bug
Ik las ergens in een andere thread iemand die er last van had (samen met een heel aantal koelpasta suggesties). Het ligt dus aan de game zelf;
Anyone else have StarCraft II try to melt their hardware? Blizzard admits that it's a known issue and has a fix for you.
Apparently, the game's menu screens aren't framerate-limited. This means that when there's nothing else going on, your graphics hardware renders the bejeezus out of those screens, causing nasty overheating problems. The fix is easy, requiring players to add the following lines to your "Documents\StarCraft II Beta\variables.txt" "Documents\StarCraft II\variables.txt" file (nice catch, commenter LegolElf):
frameratecapglue=30
frameratecap=60
Good to know. Personally I would have appreciated a heads-up before my video card fried, but maybe this can save someone else from the hassle I've been dealing with since yesterday afternoon.
On a related note, Blizzard explains StarCraft II's system requirements in detail here. If you're curious, you'll get a much better answer there than you would from me directly. So stop asking and read the official post already!
source:
http://gameinformer.com/b/news/archi...ating-bug.aspxProtoss Bar & Grill "Ready to serve"no votes
29-07-2010, 14:38 #2Member
- 20/01/05
- Harelbeke
- 2,816
- 1/108
Oesje, das wel ne minderen oO
Raar dat dat tijdens de beta nooit naar boven is gekomen..Scrubs
29-07-2010, 14:49 #3Member
- 25/09/02
- 7,852
- 5/43
Ik vond al dat men pc de kamer net wat vlugger warm maakte dan in de beta :d
direct is aanpassen se.no votes
29-07-2010, 14:55 #4Member
- 14/06/03
- Heverlee
- 741
StarCraft II - official known technical issues
issues met voicechat zijn ook erkend.
Als je die voze realtek HD controller hebt (ik ook helaas) dan zijde fuxored.Protoss Bar & Grill "Ready to serve"no votes
29-07-2010, 15:06 #5
thanks for the headsup
29-07-2010, 15:20 #6Member
- 10/01/09
- N/A
- 1,219
- 4 (100%)
- 1/9
Miljaar toch. Dan dokt ge 55 euro voor een spel af en dan kunt ge ook nog bijna een nieuwe videokaart steken.
Ik vond ook al dat het warm werd op m'n kamer, ma dat gebeurt wel vaker tijdens het gamen. Temps eens gecheckt en inderdaad, WOW...
En ik heb dus zo'n Realtek HD controller, balen. Dat er maar rap een patch komt dan.
Edit: Nog iemand trouwens die vindt dat performance bij ATI kaarten best slecht te noemen is? Ik heb een HD4870 en kan niet alles op ultra zetten. Niet dat dat een big deal is, maar op de settings die het spel aanbeveelt kan ik nog niet zeggen dat het altijd vlot bolt. Soms fps drops naar de lage 30 regionen. Naar 't schijnt bollen Nvidia kaarten pakken beter, zo ook de GTX260, die eigenlijk ongeveer op gelijke hoogte ligt met de 4870.
ATI users worden nog maar eens in de steek gelaten...Last edited by FleXe; 29-07-2010 at 15:25.
29-07-2010, 15:35 #7Approved 9-lifer
- 13/05/08
- Eeklo
- 4,801
- 34/59
"Rise and shine, Mister Freeman. "
"The right man in the wrong place can make all the difference in the world. So, wake up, Mister Freeman. Wake up and...
*smell the ashes* "no votes
29-07-2010, 15:35 #8"Music can save people, but it can't in the commercial way it's being used. It's just too much. It's pollution!" - Bob Dylanno votes
29-07-2010, 15:35 #9
zal er geen driver uitkomen om beter te presteren op starcraft 2
29-07-2010, 15:36 #10Member
- 28/04/04
- Oostkamp
- 2,601
- 16 (100%)
- 0/2
Heb tijdens een match van 2u+ nog geen 70°c gezien,bizar.
29-07-2010, 15:38 #11Approved 9-lifer
- 30/09/02
- Kasterlee
- 6,160
- 11 (100%)
- 8/25
Apparently, the game's menu screens aren't framerate-limited. This means that when there's nothing else going on, your graphics hardware renders the bejeezus out of those screens, causing nasty overheating problems.PSN: Daedieno votes
29-07-2010, 15:41 #12Member
- 18/03/04
- Colombia
- 2,363
- 1/4
als ge hoort dat de ATI opensource drivers 100x beter zijn dan de officiele van ATI moet ge nie ver zoeken
ATI is dikken brol, gewoon het feit dat ze er hun voeten aan vegen met hun drivers
ver van weg blijvenno votes
29-07-2010, 15:41 #13Member
- 28/04/04
- Oostkamp
- 2,601
- 16 (100%)
- 0/2
29-07-2010, 15:51 #14Member
- 10/01/09
- N/A
- 1,219
- 4 (100%)
- 1/9
Van Nvidia ben ik ook niet zo'n fan hoor. Die Fermi kaarten zuipen stroom en draaien ook serieus warm heb ik al gehoord.
Daarbij blijft ATI prijs/performance gewijs wel nog altijd de koning op de markt. (Hoewel hun kaarten momenteel ook wel pittig geprijsd staan, maar dat komt eerder door de dure grondstofprijzen.)
Feit is wel dat dit niet het eerste spel is waarbij ATI users in de steek worden gelaten. Zo uit mijn hoofd weet ik dat NFS Shift op ATI kaarten ook serieus trager bolde dan op gelijkwaardige Nvidia consoorten.
En dit overheatingsprobleem schijnt ook alleen maar voor ATI kaarten te gelden, al kan ik dat wel moeilijk geloven.
Dat er sowieso maar rap een hotfix uitkomt van ATI hun kant. En dan maar hopen dat dat iets afdoet.no votes
29-07-2010, 16:02 #15Des te beter heOk dan,na 30 min op menu te laten staan heb ik nog geen hogere temps gezien dan normaal.
"gij moet gewoon alles sneller doen"
hey willy.no votes
(wel pas gecheckt na 8uren SC2 spelen ervoor zonder reboot)
