Thread: Patch Notes Patch 11
06-05-2010, 23:31 #1
This.Is.Huge. Gaat waarschijnlijk heel 't spel serieus omgooien. Alstublieft:
Balance Changes
* TERRAN
o Battlecruiser
+ The build time has been decreased from 110 to 90.
o Fusion Core
+ The build time has been decreased from 80 to 65.
o Hellion
+ The range has been increased from 5 to 6.
o Planetary Fortress
+ The splash damage now originates from the center of the target, rather than the impact location near the unit in order to maintain more reliable splash damage.
o Raven
+ Seeker Missile range has been decreased from 9 to 6.
+ Seeker Missile splash radius has been decreased from 2.4 to 2.
+ Seeker Missile upgrade no longer requires Fusion Core.
o Siege Tank
+ Life increased from 150 to 160.
+ Siege Mode splash damage now originates from the center of the target, rather than the impact location near the unit in order to maintain more reliable splash damage.
o Thor
+ Ground damage decreased from 45 to 30.
+ Ground rate of fire improved from 1.93 to 1.28.
+ Air damage changed from 8 (+4 Light) to 6 (+6 Light).
+ 250mm Strike Cannons are now an upgrade at the Factory Tech Lab.
+ 250mm Strike Cannons research now costs 150/150 and 110 seconds.
+ 250mm Strike Cannons energy cost increased from 100 to 150.
+ Anti-Air splash damage now originates from the center of the target, rather than the impact location near the unit in order to maintain more reliable splash damage.
* PROTOSS
o Archon
+ The splash radius has been increased from 0.8 to 1.
+ Splash damage now originates from the center of the target, rather than the impact location near the unit in order to maintain more reliable splash damage.
o Colossus
+ The damage has been decreased from 20 to 15.
+ The rate of fire has been improved from 2.2 to 1.65.
o Phoenix
+ Can now attack while moving.
o Sentry
+ The damage has been decreased from 8 to 6.
* ZERG
o Brood Lord
+ Life has been decreased from 275 to 225.
+ Armor has been decreased from 2 to 1.
o Corruptor
+ Corruptor damage changed from 12 (+10 Massive) to 14 (+6 Massive).
+ Corruptor speed increased from 2.75 to 2.9531
+ Corruption ability redesigned:
# Single target.
# Increases damage taken by 20%.
# Lasts 30 seconds.
# Costs 100 energy.
# Range 6.
# Cannot target structures.
o Infestor
+ Neural Parasite is now an upgrade at the Infestation Pit.
+ Neural Parasite research costs 150/150 and 110 seconds.
+ Neural Parasite can now target Air units.
+ Neural Parasite energy cost increased from 50 to 100.
o Spine Crawler
+ The root time has been increased from 6 to 12.
o Spore Crawler
o Ultralisk
+ Damage has been increased from 18 to 25.
Hotkey Changes
* General
o In order to resolve a conflict with building multiple Forges with the Shift Key we have made the following changes:
+ Changed Center Camera from Shift+F to Ctrl+F.
* Standard
o To prevent the accidental research of Ventral Sacs when trying to train an Overlord with no Larva available, the hotkey has been changed from V to E.
o View Own Health Bars functionality added to the Backslash key
* Standard for Lefties
o Due to a conflict with research Banshee Cloak, research Seeker Missile has been changed from L to K.
o To correct a conflict with the Attack command on Planetary Fortress, train SCV has been changed from K to J.
o In order to prevent the accidental training of Zerglings when using the Select Larva hotkey,train Zergling has been changed from L to J.
o To prevent the accidental training of a Queen, train Ultralisk has been changed from U to T.
o To prevent the accidental research of Pneumatized Carapace when trying to train a corruptor with no Larva available, research Pneumatized Carapace has been changed from P to C.
o View All Status Bars has been changed from Q to the Alt key.
o View own Status Bars functionality has been added to the Q key.
* Grid for Lefties
o Attack Move and all other buttons in the 0,4 position should now function correctly.
o View Own Status Bars functionality added to Q.
o View Enemy Status Bars moved to W.
o View Ally Status Bars moved to E.
* Classic
o Changed build Nydus Canal from P to N.
o Changed Place Nydus Canal ability from P to N.
o Terran Infantry Weapon researches have been changed from E to W.
o Terran Vehicle Weapon researches have been changed from E to W.
o Train Thor hotkey has been changed from O to G.
o Train Viking hotkey has been changed from Y to W.
o View Own Status Bars functionality has been added to the Backslash key.
Icon Position Changes
* To put all race gas extractors in the same icon position, the positions of the Supply Depot/Refinery and Pylon/Assimilator have been swapped.
* In order to make transforming multiple Gateways easier for players using Grid key sets, Transform to Gateway has been moved to a separate icon position (2,1).
Bug Fixes
* Corrected an issue that was causing the Polish language client to crash when receiving the "player is no longer being revealed” message.
* Corrected incorrect battle.net links on multiple language clients pages.
* Corrected an issue where the Zealot was using an US English voice over in the Korean language client.
* Corrected an issue where a player is unable to build any structures that require pylon power when their protoss ally leaves.
* Units can no longer be healed or repaired while in transports.
* Corrected an issue where the Creep Tumor targeting circle was visible to opponents through Fog of War.
* Corrected an issue in which selecting a Starport under construction and a completed Starport would display the select builder command in the Viking slot.
* Corrected the Broodling weapon icon.
StarCraft II Patch Notesno votes
06-05-2010, 23:38 #2Approved 9-lifer
- 30/09/09
- 382
- 1/4
Thanks voor de lijst
06-05-2010, 23:48 #3
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU.. .
06-05-2010, 23:54 #4Approved 9-lifer
- 30/09/02
- Kasterlee
- 6,160
- 11 (100%)
- 8/25
hmm, HSM <3
PSN: Daedieno votes
06-05-2010, 23:55 #5Member
- 29/01/10
- Kalken
- 75
07-05-2010, 01:12 #6Member
- 01/04/09
- gent
- 1,197
- -2 (0%)
- 9/9
StarCraft II Beta - English (NA) Forums -> StarCraft II Situation Report : Patch 11
Lees ook dit ff voor ge een comment maakt
We are buffing the Ultralisk, but we don’t think this buff is sufficient. Expect more changes to the Ultralisk in the next patch.
speciaal voor thayli dit er alvast ervan tussen gehaald#9lives.Scno votes
07-05-2010, 01:57 #7Member
- 10/11/05
- Dublin
- 14,107
- 2/31
Heb net de beta gedownload, maar hij blijft telkens die patch downloaden, keer op keer ?
My Anime List
If a man speaks in the forest and there is no woman there to hear him... Is he still wrong ?no votes
07-05-2010, 02:20 #8Banned
- 21/09/06
- 11,687
- 18 (100%)
- 7/190
De Thor is blijkbaar zwaar generfd
07-05-2010, 02:34 #9
dit is gwn een ander spel imo
i like this one : Seeker Missile upgrade no longer requires Fusion Core.no votes
07-05-2010, 03:21 #10
Hmms, op't eerste zicht (en als zerg speler) niet al te zeer tevreden met die changes.
* Corruption redesign is iig beter dan de vorige (das niet moeilijk ook niet
* Infestor lijkt me nogal hard generfed, ik dacht dat ze die net gingen buffen.
* Die phoenix changes, die zullen nu wel dominaten tegen eender wat in de lucht. De aanpassing is zogezegd tegen mutalisks maar ik denk dat elke air unit veel problemen gaat hebben met de "fly & shoot" phoenixes (terran inclusief).
* Ultralisk is nog steeds een zeer ondermaatse unit in vergelijking met collossus en thor vind ik voor het simpel feit dat het een clumsy melee range unit is die altijd wel staat aan te schuiven tussen de andere units om iets te raken.
* Closing words dat ze zerg in't oog gaan houden en ultralisk nog aanpassingen krijgt klinken wel belovend.
Soit, ik heb nog niet gespeeld sinds de patch, van't weekend de dingen wel eens deftig testen.
Breydel / Zipporah / Breyzipp in many games.
hardware : summer 2010 high-end gaming PC & PS3 Slim 250 GB
PSN ID : Breyzippno votes
07-05-2010, 10:07 #11Approved 9liver
- 22/01/03
- 51LIC0
- 6,848
- 50 (100%)
- 4/10
Ultralisk ondermaats? Die deed al belachelijk veel dmg, en nu nog meer...
Dat ze iets zouden gedaan hebben aan zijn collision zou al genoeg geweest zijn, mr toch geen damage increase zeker?
07-05-2010, 10:20 #12no votes
07-05-2010, 11:01 #13Approved 9liver
- 22/01/03
- 51LIC0
- 6,848
- 50 (100%)
- 4/10
07-05-2010, 11:14 #14Member
- 22/04/03
- Deinze? NEE, Gent!
- 758
Trekt op niet veel imo, maar goed tis nen beta.
WARNING: The above post may contain sex, violence, drugs, sexual violence, violent sex, sexual drugs, violent drugs and violently sexual drugs.
-aka Issh.no votes
07-05-2010, 11:30 #15Banned
- 21/09/06
- 11,687
- 18 (100%)
- 7/190
Look at my horse
