    Affinity's Avatar
    Rarara
    Waarom kan ik WoTLK niet installeren?
    Sorry voor het Engels, ik heb dit op tech. forum gepost en had even geen zin om hem opnieuw te typen. Kdenk dat iedereen er wel aan uit kan.
    Alvast bedankt.
    OK I got a new computer last week. Installed WoW without any problems.
    After a few days I received critical and fatal errors, I couldn't login on my main char but I could on my level 1 alt.
    The errors became unplayable, and I decided to repair my WoW.
    It says to repair my WoW it had to downgrade to a different patch. I said OK.
    Then it said my WoW is damaged, please reinstall.
    So I started:
    - WoW no problems
    - TBC I had a disc error, maybe that was the reason I was getting these critical errors in the beginning. Luckily I had another pack of TBC discs so I used those, no problems.
    - WoTLK, mostly around 20% I crash, the well-known error that says E:\-- disc drive or dvd skratched or whatever, unable to load blablabla.... Once I got till 98% and THEN I received the error....
    What the hell is going on here.
    I tried:
    - chkdsk
    - 6 different WoTLK dvd's
    - new hard drive
    - new dvd player
    - 100 times WoTLK installation
    - Client download from account management, downloaded till 4,3/5,0 gig and then it stopped downloading, I did "Stop" and then started again and I had the same error my CD's gave me .... that the file may be damaged or my hard drive may be skratched :| what the hell?
    (My windows Vista is not legimate yet, I get popups to register but I haven't yet.. I guess this is a minor detail.. It changes my desktop to a black background but I don't think it will prevent me from installing WoTLK since I can install WoW+TBC)
    Please someone help I'm losing my patience .....
    Brasschaat
    copieer uw wotlk dvd naar hdd en installeer zo? (werkte toen mijn originele wow cds errors gaven + 't is sneller dan installeren van cd)
    * 13" MacBook Pro Retina (Late 2013) : Intel Core i5 2.4GHz : 8GB DDR3L : 256GB : Intel Iris.
    * Mac Pro (Mid 2010) : Intel Xeon Quad Core 3.33GHz : 24GB DDR3 ECC : 1TB SSD + 256GB SSD + 2TB HDD : Nvidia GeForce GTX1080.
    Affinity's Avatar
    Rarara
    nja de client van account management werkt ook niet, dus dan denk ik dat de manier die gij zegt ook nie gaat werken.
    hoe kan ik da kopieren naar mijn hdd trouwens? ik heb eens copy paste proberen doen maar da ging nie echt, of moetek daar procedure voor volgen ofzo
    Affinity's Avatar
    Rarara
    Op tech forum zeggen ze dat het aan mn RAM geheugen ligt, maat van mij zegt dat ik moet kijken of mn ram op 2,1v staat...
    Vorda's Avatar
    Kan goed zijn ja, de meeste mobo's geven op default settings 1.7 of 1.8 volt, terwijl het meeste nieuwe snelle ram 2.1 of 2.2 nodig heeft. Kijk dit eerst na op de website van je ram ofc. (de meeste hyperx modules zijn 2.2, de meeste OCZ 2.1 dacht ik)
    Affinity's Avatar
    Rarara
    kzit hier zo al op van de zenuwen, mn hele zondag verkloot, raid gemist, en weten dak vanavond er weer ne hele avond mee ga bezigzitten (weer nen dag verkloot dus).
    + kvind hier overal forums terug met dezelfde error maar NERGENS een oplossing te vinden ...........
    ofwel bel ik naar tech support, wa mij wel ne halven euro per minuut kost .....
    SideShow's Avatar
    Roeselare
    de hardnekkige kritische fouten die ik in het verleden al voorhad, waren ook telkens te wijten aan het ramgeheugen
    Affinity's Avatar
    Rarara
    net tech support gebeld en hij zei dat het wellicht aan mn pc ligt, harde schijf of ram geheugen
    aiice's Avatar
    Schoten
    Ik heb exact hetzelfde probleem, maar bij mij zeiden ze dat het aan mn dvd's lagen (omdat veel WOTLK dvd's met een fout zitten, volgens Blizzard employee).
    Ik heb harde schijf test gedaan (HDTune), ram test (memtest etc...) en geen error gevonden (want bij mij kwam het enkel boven toen ik upgrade van 2 GB naar 4GB RAM, hetzelfde merk en type etc...).
    Ik heb het dan maar geinstalleerd op mn externe harde schijf en dat lukt wel (wel wat problemen met loading times, door de USB 2.0).
    Wat is het eigenlijk met voltage van RAM? (ben niet zo technisch aangelegd om te weten wat het verschil kan geven tussen 1.7V en 2.1V)
    Affinity's Avatar
    Rarara
    hebt gij de client geprobeerd?
    ik heb ook al geinstalleerd op een andere harde schijf en da hielp ook nie.
    nikeb007's Avatar
    Halle
    Ook problemen gehad met de installatie van wow (errors etc)... memtest gedraaid en bleek dat er een ramstaafje kapot was.
    PC :
    Asus P8H67 / Core i5 2300k / GEIL 8 GB DDR3-1333 Kit / MSI GTX 660 / Nine Hundred Ultimate Gamer Case / OCZ Modstream 520 watt / DELL U2412M
    Fonskuh's Avatar
    SDW
    32 (100%)
    Heb je verschillende merken RAM zitten? Ik kon ook niet installeren toen ik extra RAM had gestoken. Heb ze er terug uit gehaald en alles terug perfect.
    N/A
    Herinnert mij aan een probleem dat ik een paar jaar terug tijdens classic WoW ook had. Hier lag het ook aan een defect RAM latje.
    Affinity's Avatar
    Rarara
    ik ga er vanavond eentje uithalen en proberen installeren, en alst nie lukt het andere in plek steken...
    op hoop van zege
    aiice's Avatar
    Schoten
    Quote Originally Posted by Arylia View Post
    op hoop van zege
    Bij mij heeft dat niet geholpen (heb de originele laten steken, aangezien die nooit voor problemen zorgde, maar de nieuwere heb ik eruit gehaald en in andere slot gestoken en het stelde enkel de error maar uit).
    Ik heb zowel met dvd als download geprobeerd, met download moest ik zelfs nog 3 keer proberen eer het lukte op mn externe, laat staan het pachen achteraf (heb ze apart moeten DL'en want kreeg daar dus ook errors af en toe, wat op zich de reden was waarom ik herinstalleerde).
    Laat maar weten hoe het gegaan is, nadat je RAM er opnieuw hebt ingestoken. Als het dan bij u lukt, zal het hopelijk ook bij mij moeten lukken (aangezien er geen errors op zitten ofzo).
