Aangezien ik nog geen topic gevonden heb en het een best wel grote patch is, dacht ik even een topic te maken(download link onderaan deze post).
Crysis Wars Patch 1.4 Patch Notes:
General fixes
* Fixed a crash relating to dropped weapons
* Fixed an issue where spectating players could impede other players' movement
* Fixed several memory leaks
* Several optimisations
* Scope position broken when picking up the same weapon type
Updates and improvements
* All graphic settings are now available on DX9 machines
* Improved visibility of mouse cursor on bright backgrounds
* Improved hit feedback when shooting vehicles
* Modding interface is now available
Balance
* Cloaked players are no longer detected by the Radar Kit
* Reduced radius of Radar Kit scan sound
Mod SDK Notes:
Code
* Game Source Code (patched to Crysis Wars v1.4)
Tools
* CryENGINE2 Sandbox2 Editor
* Resource Compiler (32-bit only)
* CryExport plug-in for 3DS Max 9, 10 and 11 (32-bit and 64-bit)
* Polybump plug-in for 3DS Max 9, 10 and 11 (32-bit and 64-bit)
* Polybump application (32-bit and 64-bit)
* CryTIFF plug-in for Adobe Photoshop (32-bit only)
* FMOD Designer Tool (32-bit only)
* Rigging, Artist, Animation Tools for 3DS Max
* CryExport plug-in for XSI
* Engine Settings Manager
Changelog:
* Improved Height-Field Editor:
- Complete overhaul of User Interface
- New options added to show and hide water and map objects
- New tools added to quickly switch to terrain texture layers.
- Modification of Height-Field now translates to editor terrain in real-time
- Added ability to erase current height map
- Added new tool for large preview of height field.
* Improved Terrain Layer Texture Editor:
- New section added “Layer Tasks” for adding layers and assigning surface types to these layers.
- Large preview of current layer texture
- Scale and projection axis now able to be changed more quickly due to new user interface.
* Improved Time Of Day Editor:
- Added automatic scaling of the graphs to suit currently set values for each property.
- Added collapsible sections to each logical property group.
- Record now defaults to ON
* New Visual Flowgraph debugging and features:
- Added debugging to track the logic occurring through the flow graph in realtime.
- Flowgraph viewport can be scrolled with right mouse button while dragging a link.
- "Add selected group" functionality when adding entity in a flowgraph
- Fixed: Incorrect scaling when opening a flowgraph
- Fixed: Flowgraph view moves around when having the save/load dialog box opened
* Track View Editor improvements:
- Added: Copy/Paste nodes in the TrackView editor.
- Fixed: Sequence not reset at a cutscene start with TrackView editor.
- Fixed: Snap key on Trackview to start/end
* Quick search entry inside the CVar dialog window:
- allows quick searching of all cvars
* General Fixes:
- Fixed: Editor windows not always updating after switching windows with alt+tab.
- Fixed: Zoom scaling issues
- Removed several buttons or menu items which were obsolete.
Links
Patch 1.4:
-Worthdownloading
-Fileplanet
-MyCrysis
Mod SDK:
-Worthdownloading
-Fileplanet
-MyCrysis
