    Velcro's Avatar
    probleem punkbuster
    heb sinds gisteren bf2, maar iedre keer dat ik een server met punkbuster join krijg ik dit: communication fail, PnkBstrA.exe
    HELP!
    Witte8's Avatar
    Lier
    32 (100%)
    Users that are getting kicked for "Service Communication Failure" (including the handshake failure type) have some other software that is blocking the PunkBuster services.
    Some users have previously disabled the PnkBstrA.exe and PnkBsrtB.exe services in the past, and these services are now mandatory.
    If the services are stopped/disabled, then PB will kick from this point forward.
    Sometimes it is an anti-virus program (like an old version of McAfee Security Center), sometimes it is a personal firewall that are blocking the services. Any user who is getting kicked for this will have to stop whatever is blocking PB or configure the program to allow the two services.
    The below link is a tool provided by PunkBuster that will help users who need to reinstall the services:
    http://www.evenbalance.com/downloads/pbsvc/pbsvc.exe
    If the above PBSVC program does not pass all the tests, please ensure that any installed firewalls or other programs are not blocking the PnkBstrA/B services.
    If that still does not do the trick, please open a ticket with PunkBuster here:
    PunkBuster Online Countermeasures and be sure to paste the log from the PBSVC program within the ticket, and EvenBalance support should be able to help you in identifying what programs are blocking the services.
    om problemen op te lossen klik hier
    Intel C2D 8500 EO revision (current OC:9,5*422=4009)|| Asus P5Q Pro|| Corsair Dominator 2*2gig pc8500|| Scythe Mugen|| Antec P182 + 3x Scythe S-flex 120mm fans(1200rpm) + Scythe Kaze Master|| Corsair 620W|| Club 3d Ati 4870 mb OC|| Creative Xfi ExtremeGamer Fatal1ty series|| WD Rapter 150gig + Samsung F1 1T + 2*Maxtor 300gig + Lacie 1T external|| HP L2475w|| Creative Inspire 5.1|| Logitech G9 + G15
    Slabbetje's Avatar
    Nieuwkerken
    Ge moet Dragons Den ies probere, ik heb da probleem ook maar op die server is dat niet.
    Kaaspetetje
