Page 1 of 4 1234 Last
    tekn0w!z's Avatar
    Getwood
    11 (100%)
    3.0.3 Patchnotes
    3.0.3 gaat live vandaag, hier volgen de patchnotes:
    Wat leesvoer in afwachting van Wrath of the Bitch King?
    *edit* opsommingstekens een beetje bugged.
    General
    • Removed "A Mask for All Occasions" as criteria for the "Hallowed Be thy Name" meta achievement.
    • Replenishment: Players below level 50 can now benefit from this effect.
    • Resilience: The damage reduction component of resilience has been increased from 2 times the critical strike chance reduction to 2.2 times the critical strike chance reduction. In addition, the maximum damage reduction to a critical strike from resilience has been increased from 30% to 33%.
    Racial
    • Blood Fury: No longer triggers global cooldown.
    • Shadowmeld: The cooldown will now start on use instead of on break.
    Druids
    • Druid talents points have been refunded. Players will need to visit a class trainer to relearn spells and abilities.
    • The Swift Flight Form is now available on the trainer at level 71, requiring 300 riding skill, and Flight Form learned.
    • Bash: The interrupt from this ability will now work on targets that are immune to the stun.
    • Berserk: Now clears the cooldown on Mangle Bear.
    • Earth and Moon and Moonfury (Balance) reduced from 5 ranks each to 3 ranks each.
    • Eclipse: Buff duration extended to 15 sec and bonuses doubled. The cooldown has been increased to 40 seconds.
    • Growl: Cooldown changed to 8 sec.
    • Insect Swarm: Tooltip corrected to indicate it does not affect hit chance with spells.
    • Moonkin: Only single target spell critical strikes can trigger the mana gain from this talent.
    • Nature's Swiftness: This ability will no longer give chances to trigger Omen of Clarity.
    • Omen of Clarity: Will no longer be triggered by the Honorless Target buff gained when entering the world.
    • Survival Instincts will no longer be on the Global Cooldown.
    • Swiftmend: now benefits correctly from Genesis talent.
    • Tiger's Fury: Ranks 5 and 6 have had their damage bonus decreased.
    Hunters
    • Aimed Shot: Added to Barrage and Improved Barrage talent.
    • Animal Handler: Now increases your pet's expertise by 5/10. (No longer increases the pet's chance to hit.)
    • Aspects now have a shared cooldown category of 1 sec and no longer have a start cooldown.
    • Aspect of the Dragonhawk: New aspect added that combines the benefit of Aspect of the Monkey and Aspect of the Hawk, available at level 75 and 80.
    • Aspect of the Monkey: The Dodge chance has been increased from 8% to 18%.
    • Aspect of the Viper: The per attack mana regeneration has been reduced by 50% but this ability now generates 4% of maximum mana every 3 sec. In addition, the per attack regeneration now also works on melee attacks.
    • Disengage now fails if you're rooted and is no longer on the global cooldown.Cooldown reduced to 25 seconds and no longer requires a target, though the hunter has to be in combat.
    • Hunter vs. Wild: The attack power bonus from this talent now applies properly to Hunter pets. In addition, the bonus attack power will now be recalculated properly from equipping items.
    • Improved Aspect of the Hawk: This talent no longer causes incorrect mana costs when interacting with the Rapid Recuperation and Improved Steady Shot talents.
    • Mana cost of Disengage has been lowered to 5% of base mana, down from 14%.
    • Pets
      • Rake (Cat), Scorpid Poison (Scorpid): Lowered damage of all ranks.
      • Stampede (Rhino): Lowered the knockback to 10 yards.
      • Raised the damage of exotic attacks: Spirit Strike, Lava Breath, Froststorm Breath, Acid Spit, and Stampede.
      • Lowered the cost of pet specials from 25 to 20.
    • Thrill of the Hunt: The mana gained from using this talent with Explosive Shot is now 1/3 of the normal amount per critical strike (but gets 3 opportunities per cast.)
    • T.N.T.: Explosive Shot can now only trigger this talent when it is initially fired.
    • Windfury Totem and Improved Icy Talons no longer affect ranged haste.
    Mages
    • Arcane Potency: The additional crit bonus is now consumed immediately on cast of a travel time spell, so it is no longer possible to make two spells benefit from one charge. (Ex. Fireball followed by Fireblast.)
    • Blast Wave: no longer receives double the intended critical strike bonus from Combustion.
    • Burnout: Now consumes extra mana as intended when Living Bomb gets a critical strike.
    • Brain Freeze: Now only frost spells that can chill can trigger the mana gain from this talent.
    • Cold as Ice: No longer reduces the cooldown on Deep Freeze.
    • Deep Freeze: Now consumes a charge of Fingers of Frost when used.
    • Focus Magic: Now works properly when mages with this talent use the ability on each other.
    • Frostfire Bolt: The periodic damage effect from Rank 2 of this spell now benefits from spell power gains.
    • Living Bomb: Mana cost reduced to be the same as Arcane Explosion.. It no longer causes the caster to stand up when the final explosion occurs and it is now possible for each mage to have Living Bomb active on a target.
    • Master of Elements: Now works with Living Bomb.
    • Molten Fury: This talent no longer prevents Ice Lance ranks 2 and 3 from dealing triple damage against frozen targets.
    • Reduced the mana cost of Fireball, Frostbolt, Frostfire Bolt, Arcane Blast, Arcane Missiles, and Arcane Explosion.
    • Torment the Weak: Now works correctly when the Mage also knows the Molten Fury Talent.
    Paladins
    • Art of War: No longer increases critical strike damage on Judgements, Crusader Strike, and Divine Storm, instead increases all damage done by those abilities by a smaller amount.
    • The Avenger's Shield bounce distance has been reduced to 10 yards (from 15).
    • The epic ground mount is now available on the trainer at level 61, requiring 150 riding skill, and the non-epic mount learned.
    • Blessing of Might: Rank 8 points increased slightly to prevent from being overwritten by Battle Shout 8 that has a shorter duration (also applies to Greater Blessing of Might 3.)
    • Blessing of Sanctuary: It is no longer possible to have both Blessing of Sanctuary and Greater Blessing of Sanctuary active on a target at the same time.
    • Crusade: No longer applies damage bonus twice to critical strikes.
    • Divine Plea: This spell's duration is no longer affected by haste.
    • Divine Purpose: Rank 1 of this ability will now correctly determine its chance of remove stun.
    • Enlightened Judgments now increases range by 15/30 (was 10/20).
    • Eye for an Eye: No longer breaks crowd control effects.
    • Hammer of Justice: The interrupt from this ability will also be redirected when the stun is redirected. In addition, the interrupt will now work on targets immune to stun.
    • Hammer of the Righteous: Tooltip corrected to indicate it does 4 times weapon dps instead of 3.
    • Hammer of Wrath: Now can't be used until the target is below 20% health.
    • Infusion of Light (Holy) now affects Flash of Light too, reducing its cast time down to zero and can be used while moving.
    • Judgements: The debuffs from Judgement of Light, Judgement of Wisdom, and Judgement of Justice will no longer be applied if the Judgement spell itself misses.
    • Judgements of the Pure: Haste increased to 3/6/9/12/15%.
    • Judgements of the Wise: Mana gained reduced from 33% to 15% of base mana.
    • Judgement of Wisdom: Mana gained reduced to 1% of maximum mana and proc frequency cut by 50%.
    • Repentance PvP duration reduced to 6 sec.
    • Righteous Defense cooldown has been lowered to 8 sec (was 15 sec).
    • Righteous Vengeance: No longer increases critical strike damage on Judgements and Divine Storm, instead applies a DoT effect similar to Deep Wounds.
    • Seal of the Martyr: Tooltip for Judgement damage was incorrect and has been fixed.
    • Sheath of Light: Now correctly benefits Judgements of Command, Blood, and The Martyr.
    • Shield of the Templar now also reduces all damage taken by 1/2/3%.
    Priests
    • Binding Heal: Now only consumes one charge of Holy Concentration per cast.
    • Borrowed Time: Charge no longer consumed by spells with a base cast time that is instant.
    • Devouring Plague: The bonus coefficient has been increased to be on par with other DoT spells. Base damage on ranks 7,8,and 9 decreased to partially compensate for better scaling.
    • Divine Providence: This talent now also reduces the cooldown of your Prayer of Mending spell by 6/12/18/24/30%. With 5 points applied, it takes Prayer of Mending's cooldown from 10 sec to 7 sec.
    • Divine Spirit: Now can be refreshed properly on self after logging in and out or zoning. (Also applies to Prayer of Spirit.)
    • Guardian Spirit: A target may now have only one Guardian Spirit active.
    • Healing Focus: Now works properly with Penance.
    • Improved Divine Spirit: No longer improves Divine Spirit after untalenting sometimes.
    • Inner Focus: Now works properly with Mind Flay, Mind Sear, and Penance.
    • Prayer of Spirit: Will no longer stack with other raid spell power buffs.
    • Shadowform: Devouring Plague, Shadow Word:Pain, and Vampiric Touch cast in Shadowform deal increased damage percentage equal to the player's chance to get a spell crit on their target.
    • Shadow Wordeath: The self-damage from this spell can no longer be reflected or redirected.
    • Vampiric Touch: The Spell power coefficient has been doubled and no longer triggers Replenishment when other priests cast Mind Blast.
    Rogues
    • Combat Potency: Now only works with auto attacks (no more Shiv.)
    • Fan of Knives changed to be castable with no targets, further improved the visual affect and it no longer plays an impact on the caster. Now benefits correctly from the Find Weakness talent.Cooldown reduced to 10 sec.
    • Killing Spree: Instead of making the rogue untargetable, now causes all players to lose targeting on the rogue and the rogue to be unstoppable during its duration.
    • Riposte: Duration of this effect no longer reduced by other effects that reduce disarm duration.
    • Shadow Dance: The cooldowns on Sap, Garrotte, Ambush, Cheap Shot, Premeditation, Pickpocket, and Disarm Trap are no longer increased while this ability is activated.
    Shaman
    • Bloodthirst: Percentage of damage from attack power raised from 45% to 50%.
    • Flurry: Now grants the proper number of charges when it triggers.
    • Improved Fire Nova Totem: Increases the damage done by your Fire Nova Totem by 10/20% and your Fire Nova totem has a 50/100% chance to stun all targets damaged by your Fire nova Totem for 2 sec.
    • Lava Burst: The base damage has been increased by approx. 10%.
    • Maelstrom Weapon: Tooltips corrected to correctly describe the chance for this talent to be triggered.
    • Riptide: The initial heal amount has been increased on ranks 3 and 4 and periodic healing has been increased on all ranks.
    • Stormstrike: Other shamans can no longer consume charges of your Stormstrike, and each shaman can have their own stormstrike on the victim.
    • Storm Reach is now called "Elemental Reach" and now includes Lava Burst.
    • Thunderstorm: Mana gain has been increased to 8%.
    • Tidal Mastery: Now correctly applies its critical strike bonus to Earth Shield.
    • Tidal Waves will now also proc with Riptide.
    Warlocks
    • Demonic Sacrifice: The buffs from this ability will now be retained properly when logging out or zoning.
    • Demonic Empowerment: This talent no longer gives excessive threat to the Warlock's Voidwalker and is no longer on the global cooldown..
    • Demonic Tactics: Increased the critical strike bonus for both the Warlock and pet.
    • Destructive Reach: Now properly reduces threat on Chaos Bolt and Shadowflame.
    • Drain Soul: Rank 6 now properly deals additional damage to targets below 25% health.
    • Emberstorm: Increased the fire damage bonus.
    • Haunt: The cooldown has been changed to 8 sec, and refreshing the Haunt will trigger the heal from the existing Haunt.This ability will no longer heal for incorrect amounts or fail to heal when the Huaunt damage was the killing blow.
    • Inferno: The Infernal is now useable indoors and the tooltip has been updated.
    • Master Demonologist (Felhunter) will now also reduce damage taken by Holy.
    • Ritual of Doom: Now works correctly even when the Warlock already has a pet (dismissed the existing pet.)
    • Shadowflame: Damaged increased approx. 75%. Coefficients unchanged.
    • Shadow Embrace: Now works on ranks 1-4 and stacks properly with multiple applications.
    • Shadow Mastery: Increased the shadow damage bonus.
    • Soul Link (Demonology): Increased from 15% to 20%.
    Warriors
    • Armored to the Teeth: Grants only attack power(as intended) and recalculates the bonus immediately upon learning any rank of the talent.
    • Bladestorm: Now breaks all snares and roots on the warrior when activated.
    • Bloodthirst: Cooldown reduced to 5 sec.Percentage of damage from attack power raised from 45% to 50%.
    • Deep Wounds: Now works properly with Heroic Throw.
    • Heroic Throw: No longer gains increased damage from the warrior's agility.
    • Improved Rend changed to 10/20%.
    • Rampage: Can now be triggered by off-hand Whirlwind damage.
    • Rend: Damage has been adjusted to be less base and more weapon based.
    • Rend: Ranks 9 and 10 now do 35% more damage when the target is above 75% health instead of 4 times damage when the target is enraged. Sudden Death: Now has 3/6/9% chance on hit instead of 10/20/30% chance on crit.
    • Titan's Grip: Changed to 5% penalty.
    • Vigilance: Now properly transfers threat generated by heals.
    Professions
    • The level requirements required to train gathering skills have been removed.
    • Alchemy
      • Reduced the effect of Elixir of Mongoose and Elixir of Major Agility.
    • Inscription
      • Glyph of Crusader Strike: Now reduces mana cost by 20% instead of increase damage on stunned and incapacitated targets.
      • Glyph of Flame Shock: Now extends duration by 6 sec and prevents Flame Shock from being consumed by Lava Burst.
      • Glyph of Lava: Glyph of Earth Elemental removed and replaced with this glyph. This glyph increases coefficient on Lava Burst by 0.1.
      • Glyph of Mind Flay: Now sets snare to 10% instead of removing it.
      • Glyph of Rejuvenation: Now works correctly when the target is not self.
      • Glyph of Shiv: Replaced with Glyph of Vigor, which increases maximum energy by an additional 10 for those with the Vigor talent.
      • Glyph of Shadow: Glyph of Mind Soothe removed and replaced with this glyph. This glyph increases spell power by 10% of spirit for 10 sec after critting while in Shadowform.
      • Glyph of Shadow Word: Pain: Increases damage done by Mind Flay when SW:P is present by 10%.
      • Glyph of Sinister Strike: Chance increased to 50%.
      • Glyph of Souls no longer removes soul shard cost. It instead reduces the mana cost of your Ritual of Souls spell by 70%.
      • Glyph of Spirit of Redemption: Tooltip corrected to 4 sec. extra when the glyph triggers.
      • Glyph of Strength of Earth: Replaced with Glyph of Lava Lash, which increases the bonus from having Flametongue Weapon by 10%.
      • Glyph of Trueshot Aura: Now increases Aimed Shot crit chance instead of increasing attack power bonus.
      • Glyph of Totem of Wrath: Replaced with Glyph of Elemental Mastery, which decreases the cooldown on Elemental Mastery by 30 sec.
    User Interface
    • For additional notes on Lua and XML changes please visit the UI & Macros forum.
    Items
    • The war against spelling errors continues: many items have had typos removed or their functionality clarified.
    • The item quality on several quest rewards was incorrect and has been altered.
    • The phoenix summoned by Ashes of Al'ar has had his flame trails restored.
    • Guardian's Band of Subjugation now correctly grants universal haste.
    • Girdle of the Warrior Magi now has a socket bonus.
    • Some one-hand spell power weapons are now main hand only.
    • Heart of the Dragon should now provide a consistent amount of Ranged Attack Power.
    • Loatheb's Shadow should now provide a consistent amount of Ranged Attack Power.
    • Spirit-World Glass now correctly has a cooldown.
    • Discerning Eye of the Beast procs should now be more obvious.
    • Focusing Lenses now have a cooldown.
    • The Horseman's Reins should again function in Dalaran.
    • Haute Club Membership Card no longer prompts players to open it.
    • The buff granted by Frenzyheart Insignia of Fury now has a correct tooltip.
    • Harness of Carnal Instinct no longer has bonus armor.
    • Boots of the Protector have been brought in line with protection paladin itemization changes.
    • A tooltip error in the Glyph of Sprint has been corrected.
    • Grilled Sculpin now correctly grants Ranged Attack Power.
    • Libram of Souls Redeemed should now only affect Holy Light.
    • Legacy items that had both melee and spell critical strike rating have been integrated to the unified rating.
    • Held in hand books created by Inscription are now Bind on Equip rather than Bind on Pickup.
    Bug Fixes
    • Fixed an issue that was affecting terrain rendering on GeForce 3 and 4 Ti cards. Those that added the command Set fixedfunction 1 to their config.wtf file should remove it to avoid a decrease in performance.
    • Glyph of Rupture: The tooltip has been corrected.
    • Druid: Omen of Clarity now has a reduced chance to be triggered by Hurricane.
    • Hunter: Ferocious Inspiration will now apply raid-wide, as intended.
    • Hunter Pets
      • Sonic Blast (Bat): Will no longer ignore LoS.
      • Bad Attitude (Croc): Will no longer ignore the Longevity buff.
      • Thunderstomp (Gorilla): Will no longer have a physical coefficient instead of a magical one.
      • Gore (Bore): Fixed an issue where a wrong value was being applied.
      • Savage Rend: Corrected typos in the tooltip.
    • Mage: Burning Determination will now work properly.
    • Mage: Living Bomb's "explosion effect" will now be properly classified.
    • Paladin: Judgement of Wisdom: Fixed a bug allowing one copy on target per paladin.
    • Paladin: Judgement of Light: Fixed a bug allowing one copy on target per paladin.
    • Priest: Holy Reach (Rank 2) will now increase the radius of Divine Hymn properly.
    • Priest: Inner Focus will now properly increase the critical strike chance of the talent Penance.
    • Rogue: Deadly Poison Rank 8 will now do less damage than Rank 9.
    • Shaman: Totem of Wrath tooltip updated to reflect that it affects all crit chance and indicate that it increases Spell Power (instead of just damage).
    Currently playing: Rocket League - Overwatch
    Shyheim's Avatar
    Dilbeek
    17 (100%)
    kut, ziet er nog ne serieuze patch uit... wordt weer wachten tot vanavond om in te loggen zeker?
    edit:
    Racial
    * Shadowmeld: The cooldown will now start on use instead of on break.
    woot, super
    ze zouden die "every man for himself" racial van humans ook mogen veranderen imho, de cooldown NIET laten sharen met PVP trinket net als "will of the forsaken"...
    Vorda's Avatar
    Tijd om terug van men pala naar men rogue te gaan..
    edit: ik weet dat de hotfix voor jotw er al was, maar heb niet gespeeld sinds dan
    Shyheim's Avatar
    Dilbeek
    17 (100%)
    mjah, rogue is nu volledig dé 1v1 class geworden... zouden in principe alles kunnen pakken nu ze ook nen disarm hebben :/
    Fatalix's Avatar
    Turnhout
    12 (100%)
    Quote Originally Posted by LessThanJake View Post
    alsof dat al niet was.
    lollerpop cd's.
    done.
    -13 December 2004-
    Æro's Avatar
    Deurne
    Quote Originally Posted by tekn0w!z View Post
    Dees is er weeral over eh zeg. Misschien eens overwegen om een niet crit-relient class te spelen aangezien mijn crits bijna lachwekkend worden.
    Quote Originally Posted by Fatalix View Post
    lollerpop cd's.
    done.
    True,...
    Maar, ne rogue zonder cd's => lollerPop=> rogue dood ja
    Shyheim's Avatar
    Dilbeek
    17 (100%)
    Quote Originally Posted by Æro View Post
    heheh
    chance dat mijn moonkin ni teveel crit-afhankelijk is... het enige wat mijn crits met zich meebrengen is reduced casting time
    zou da ook een effect hebben op de dot dmg? mana drains,..?
    wel klote moest het niet zo zijn... allemal gelijk voor de wet imo -.-
    Gunstn's Avatar
    torhout
    19 (100%)
    Druids
    * Druid talents points have been refunded. Players will need to visit a class trainer to relearn spells and abilities.
    Lap da word weer is zoeken achter mijn build ^^
    123
    MetalG's Avatar
    Dendermonde
    41 (100%)
    ik speel niet meer maar dat is wel de boemz :P
     iMac 27" late 2015, HP zbook 14" - Xperia Z3 16GB Black
    Sony A35 + Tamron 17-50mm 2.8
    Piekatsjoe's Avatar
    Klerken
    Sigh, en nu dak just weer graag op m'n pala begon te spelen -,-.
    PSN: Piekatsjoe
    blackman's Avatar
    aartselaar
    Amai, wat een nerf voor paladins. Mjah, het was wel te verwachten.
    EDIT: Hey, die open arena outside orgrimmar is wel leuk gedaan!
    (sorry als die hier al langer staat, maar ik merk hem nu pas op.)
    Piekatsjoe's Avatar
    Klerken
    Enige problemen die ik ondervond tijdens het spelen was de insane burst damage & 't feit dat we ver niet oom gingen..
    Soit, 'k baseer mij momenteel op al het gewhine op de blizzard fora, moet het zelf nog ondervinden . Maar als't zo zal zijn pre 3.x patch, zal ik m'n mage wel verder lvlen..
    PSN: Piekatsjoe
    Tempest's Avatar
    Olen City
    Great, nu gaan alle classes diek voor deze patch vermorzelde met mijn pala allemaal op zoek gaan naar pala's om af te maken, TOF ZE
