28-07-2008, 13:05 #1Member
- 26/02/03
- Binderveld
- 485
[Priest] The infamous 5 second rule.
Ik ben op het moment een priest aant levelen tot 70, ik level als shadow maar op 70 ga ik direct holy. Nu ik heb Elitist-Jerks al eens bezocht en dit vond ik : http://elitistjerks.com/f31/t17086-p...pendium_2_3_x/
Nu het probleem is dat ik het volgende niet zo heel goed begrijp. Ik weet wat het is, wat het doet, dat het er is (zelf getest) maar kweet ni zo goed hoe ge het kunt omzeilen.
Random Terms Used
OO5SR : Outside Of 5 Second Rule
I5SR : Inside 5 Second RuleQ: How do I take advantage of spirit?
A: This is basically an experience thing, but take the talents Inner Focus and Holy Concentration, and start using /stopcasting macros (more info on the UI forum). Stop your casts anytime the tank does not need your heal, and start another one. Timed properly, this can get you full 5 second ticks OO5SR, which is worth a lot of regen.
Using a Holy concentration proc chained into an Inner Focus together with /stopcasting can easily give 15-20 seconds Oo5SR, while still landing two max-rank GH:7 heals. The third heal will terminate the II5SR time, but actually gives one final tick at full regen because of cast time.Q: How do I take advantage of spirit?
Cheating the 5 Second Rule
Priest regen is all about cheating the 5 second rule. Blizzard's 5 second rule is currently set so that upon completion of a spell which *costs mana* (the critical factor), you enter a 5 second period (II5SR) where you regenerate mana at a reduced rate. This rate is dependent on your talent choices (Meditation = 30% regen II5SR in 2.3.0; 15% in 2.2.2) and upon your gear choices (3-piece Primal Mooncloth = 5% regen II5SR).
Given that priests gain so much regeneration from spirit, the typical difference between a regen tick II5SR and OO5SR is approximately 3x. It can range from 2x on the low-end (Mp5-heavy gear) to 4x on the high-end (spirit-heavy gear). In any case, a tick OO5SR is worth 2+ II5SR.
So how to cheat the rule?
Firstly, Inner Focus is a guaranteed way to exit the 5SR, since it makes your next cast "free" of mana, and hence does not trigger the rule. Typical sequence is something like:
- top up your tank target
- wait 2 seconds
- hit Inner Focus
- start /stopcasting GH:7 until heal is actually needed
- start a new heal -- when it lands, you re-enter the 5SR
If the tank is not getting owned, and if you are not the solo healer on that tank, you should be able to get 7-10 seconds OO5SR before the 2nd heal lands.
You can do exactly the same thing with Clearcasting, although it's a little harder to lead up to it, as Clearcasting is a random chance proc.
There are two trinkets in the game which can aid in this method of play. The first is [Bangle of Endless Blessings], an annoying drop from Botanica (I say annoying because in 18 runs, it refused to drop for me, so I hate it). The second is a drop from Lurker Below in SSC, [Earring of Soulful Meditation]. Both have a 2-minute cooldown Use-Effect which increases your spirit by an amount for 15 seconds.
Thus, if your Inner Focus happens to be up at the same time as your trinkets, and you get a Clearcasting Proc, your sequence should be something like:
- wait 2 seconds (to get close to the end of your current 5 seconds)
- hit your trinket Use Effect
- start casting GH:7, use /stopcasting, land it before the Clearcasting Proc falls off
- hit Inner Focus
- repeat GH:7 /stopcasting
- start a mana-costing heal, enter the 5SR as it lands
You can easily get a full 15 seconds of trinketed regen by doing this, which results in approximately (with Earring and 500 spirit raid buffed) 2000 mana. This varies depending on how much Mp5 and spirit you have, but it's worth around the same as the low-end of a mana pot.
Additionally, if you use ItemRack as an addon, you can use a Script to switch in spirit-based weapons while you do this for a little more oomph. This can also be done manually with a bit more work.I have a macro which goes something like:
/script EquipSet("Regen");
/use Earring of Soulful Meditation
Dus :
-Wat zijn stopcasting macro's
-Hoe kan ik nu precies en effectief alles uit men spirit halen?
-Wat als er nu iemand hard gehit wordt en ik dus snel moet healen?
Dank bij voorbaat.HIER zou ik niet op klikken!no votes
28-07-2008, 13:27 #2Member
- 8,143
- 3/42
stopcasting macros zijn macros waarbij je u cast stopped
Eigenlijk moet je constant aan het casten zijn, en indien je target uiteindelijk geen heal nodig heeft cancel je je cast en begin je direct een nieuwe.
zodoende ben je eigenlijk altijd snel genoeg om de tank te healen als hij een grote hit krijgt en doe je geen onnodige overheals.Recedite, Plebesno votes
28-07-2008, 13:35 #3Member
- 26/02/03
- Binderveld
- 485
Ahzo, maar hoe werken die dan.
keb darjuist een macro gemaakt
en die werkte niet./cast heal:2
/stopcasting
(ben level 32 atm)Last edited by DFS; 28-07-2008 at 13:36. Reason: quotes werkten niet.
28-07-2008, 13:44 #4Member
- 16/06/05
- Oostkamp
- 2,950
- 5 (100%)
- 5 Post(s)
- 0/15
het zou me ten zeerste verbazen moest je spell zo heten, makkelijke manier op een spell in je macro te krijgen is
-eerst '/cast' typen
-spatie
-shift ingedrukt houden en rightclick op de spell die je wil gebruiken (in je spellbook, denk niet da klikken op je bars werkt)no votes
28-07-2008, 13:45 #5Member
- 28/08/02
- Anywhere
- 2,191
- 2/2
stopcasting macro's zijn useless sinds 2.4 (afaik)
het komt er gwn op neer om u gheal of andere heal te cancelen als u tank topped is zoda ge OO5SR blijftpewpew signo votes
28-07-2008, 13:47 #6Member
- 11/04/05
- 2,222
Is die stopcasting shit wel nodig? Ik Jump gewoon effe omhoog als ik cast wil interupten.
28-07-2008, 13:49 #7Member
- 11/04/05
- 2,222
een vd laatste patchen hebben ze idd die stopcasting useless gemaakt.
althans dat hebben ze me altijd gezegd ik speel altijd meelee.
uwe heal cancelle als tank het niet nodig heeft is vrij logish he...
mana verspillen is ni echt aan te raden
28-07-2008, 13:50 #8Member
- 28/08/02
- Anywhere
- 2,191
- 2/2
stopcasting is voor server/client latency te ontwijke maar zoals gezegd is da sinds 2.3 of 2.4 amper te merken
btw nzr het is beter om te moven ipv te jumpe omda een jump langer duurt eer ge terug kunt castepewpew signo votes
28-07-2008, 13:52 #9Member
- 26/02/03
- Binderveld
- 485
Ok merci, nu kan ik idd men heals casten van welke rank dan ook.
Keb er ook /stopcasting aan toegevoegt, maar nu kan ik die macro nietmeer gebruiken. ook niet als men target low hp is.
Hmm dus het is nutteloos? Kmoet gewoon zelf zien?
Ma hoe kunde dan eigelijk gegarandeerd uit die 5sec rule blijven. En as ge nog tips ebt fzo, altijd welkom.Last edited by DFS; 28-07-2008 at 13:53. Reason: Reply
28-07-2008, 13:53 #10
stopcasting voor u spell zette:
/stopcasting
/cast Greater HealHoist Your Colours High!no votes
28-07-2008, 13:58 #11Member
- 26/02/03
- Binderveld
- 485
28-07-2008, 13:58 #12Member
- 28/08/02
- Anywhere
- 2,191
- 2/2
alles sta praktisch uitgelegd hierboven ...
het is nie de bedoeling da ge altijd OO5SR blijven he, anders is u tank down
het is gwn een handig trucje als priest om mana te regene wnr u tank topped is.
om nu een vb te geve in een 5 man instance:
Wanneer de tank op 50% is cast ge een gheal zoda hij terug topped is. Daarna telt ge tot 2 en cast ge innerfocus, nu wacht ge gewoon totda u tank genoeg hp heeft verlore om terug te heale. 5SR wordt alleen getriggered als ge iets cast da mana gebruikt dus door innerfocus te gebruiken krijgde een free heal + geraakte in de 5SR = free mana.pewpew signo votes
28-07-2008, 14:05 #13Member
- 26/02/03
- Binderveld
- 485
Dus stel tank is 50%
ik doe GH rank 3.
dan tel ik 1-2
dan inner focus
en dan wacht ik tot de tank weer op 50%
en dan doe ek weer GH rank 3?HIER zou ik niet op klikken!no votes
28-07-2008, 14:08 #14Member
- 28/08/02
- Anywhere
- 2,191
- 2/2
is 1 van de mogelijkheden om OO5SR te raken ja, maar hangt allemaal af van de situatie
pewpew signo votes
28-07-2008, 14:13 #15Member
- 26/02/03
- Binderveld
- 485
Hebt ge mss nog een voorbeeld?
