    c&c 3 werkt niet HELP ME AUB!!!!!!!!!!!!!!!!!!!
    ik heb nu al op 3 pc's c&c 3 probere te spelen maar het werk niet ik geef hieer effe men pc gegevens
    System Information
    Time of this report: 6/7/2008, 15:50:29
    Machine name: PACKARDBELL
    Operating System: Windows Vistaâ„¢ Ultimate (6.0, Build 6001) Service Pack 1 (6001.longhorn_rtm.080118-1840)
    Language: Dutch (Regional Setting: Dutch)
    System Manufacturer: Packard Bell NEC
    System Model: IMEDIA 5036
    BIOS: BIOS Date: 10/14/05 11:33:06 Ver: 08.00.09
    Processor: Intel(R) Pentium(R) 4 CPU 3.06GHz (2 CPUs), ~3.1GHz
    Memory: 958MB RAM
    Page File: 708MB used, 1473MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 10
    DX Setup Parameters: Not found
    DxDiag Version: 6.00.6001.18000 32bit Unicode
    DxDiag Notes
    Display Tab 1: The file SiSGRV is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
    Sound Tab 1: No problems found.
    Sound Tab 2: No problems found.
    Sound Tab 3: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: SiS 651_661FX_741_760_760GX_M661FX_M661MX_M741_M760_M7 60GX
    Manufacturer: SiS
    Chip type: SiS 661FX Rev 01
    DAC type: Internal
    Device Key: Enum\PCI\VEN_1039&DEV_6330&SUBSYS_E0121631&REV_00
    Display Memory: 61.5 MB
    Dedicated Memory: n/a
    Shared Memory: n/a
    Current Mode: 1280 x 1024 (32 bit) (60Hz)
    Monitor: Generic PnP Monitor
    Driver Name: SiSGRV
    Driver Version: 6.14.0010.3653 (English)
    DDI Version: 9
    Driver Attributes: Final Retail
    Driver Date/Size: 2/17/2005 17:28:02, 861696 bytes
    WHQL Logo'd: No
    WHQL Date Stamp: None
    Device Identifier: {D7B71ED9-2070-11CF-C47B-18C0A1C2CB35}
    Vendor ID: 0x1039
    Device ID: 0x6330
    SubSys ID: 0xE0121631
    Revision ID: 0x0000
    Revision ID: 0x0000
    Video Accel: ModeMPEG2_D ModeMPEG2_C ModeMPEG2_A ModeMPEG1_A
    Deinterlace Caps: n/a
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description: Speakers (Realtek AC'97 Audio)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: PCI\VEN_1039&DEV_7012&SUBSYS_E0121631&REV_A0
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: RTKVAC.SYS
    Driver Version: 6.00.0001.6285 (English)
    WHQL Logo'd: Yes
    Date and Size: 3/25/2008 21:15:30, 4137312 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    ik hoop dat deze info voldoen is om te weten wat er scheelt en als er een error komt is het de volgende
    zorg er voor dat directx9.0c of hoger aanwezig is (heb 10 dus) voldoet de videokaart een de eisen en zorg er ook voor dat de hardwarematige acceleratie is ingeschakelt
    Greenie's Avatar
    dat is gewoon een bug van TW
    je moet gewoon de 1ste maal manueel te patchen
    (eventueel eerst nog met een van de eerste patches die uitkwam en hem dan automatisch te laten patchen)
    ps: laat die info in je vraag eerst achterwege, tenzij er niemand je kan helpen met je error alleen
    Quote Originally Posted by DarkMess View Post
    dus wat moet ik nu juist doen eerst 1 van de oudste patches nemen en dan hem late update als ik het goed begrijp
    Greenie's Avatar
    je kan gewoon rechtstreeks de laatste versie proberen
    maar moest dat niet werken: eerst een oude
    heb die ook nog gehad, maar dat was toen de eerste weken van TW
    en ik meen me te herinneren dat ik eerst een oude moest patchen omdat de nieuwe niet lukte
    (maar dat zal wel niet meer het geval zijn)
    hey ik laat je weten of dat het werkt
