Page 1 of 5 12345 Last
    Belgian Jupiler League '07-'08 V1 by FUB
    PES2008 - Jupiler League '07-'08 V1 for PES2008 by FUB
    (18.05.2008)
    For this patch I used the following patches as a base:
    -EvoPatch_2.0_OF
    -Adboard Pack1 for Pes2008 PC by DrDoooMuk
    -GDB v2
    -All_unlicensed_emblems packed by Dert
    http://rapidshare.com/files/11599143..._V1_by_FUB.zip
    extract the file with winzip or winrar
    Before installation: always make a back-up file!
    Thanks to Kitserver, AFS Explorer, GDB Manager and GGS
    This patch includes:
    -All 18 Jupiler League Clubs:
    --Anderlecht
    --Beerschot
    --Cercle Brugge
    --Club Brugge
    --Brussels
    --Charleroi
    --Dender
    --Genk
    --Gent
    --Standard Liège
    --Lokeren
    --Mechelen
    --Mons
    --Mouscron
    --Roeselare
    --Sint-Truiden
    --Westerlo
    --Zulte-Waregem
    -All unlicensed emblems
    -The logos of the Jupiler League
    -The Jupiler League replaces the Eredivisie
    -Eredivisie in Other League C
    -The League menu of the Jupiler League
    -All unlicensed and licensed kits
    -The kits of the Jupiler League
    -New adboards
    If you want to install other patches
    (boot packs, cup logos, league logos, balls...),
    it is possible to install this patches, but do this first.
    The Jupiler League should be installed in the end.
    The installation contains three elements:
    -The installation of the Option File (OF)
    -The installation of the League Menu
    -The installation of the kits
    Installation:
    1. Option File
    1.01 Copy the data from the map OF in your folder "...\My Documents\KONAMI\Pro Evolution Soccer 2008\save\".
    2. League Menu
    2.01 Unpack "AFS_Explorer_3.7.rar" from our patch.
    2.02 Open AFS Explorer, click on our left in the menu "file", than "Import AFS file...".
    2.03 Now we can see a window, we change "AFS Files" into "All Files" and search for "PES 2008\img".
    2.04 Than we click "cv_0.img" and waite a few seconds.
    2.05 There will be a warning "Missing descriptors information ...", we click "no" and than "yes", the data now will be loaded.
    2.06 Now we have to import our patch files, we click in the menu "action", than "Import folder...", wait a few seconds,
    than select the map "cv_0" from our patch.
    2.07 A warning "Do you want to rebuild the AFS File?" will appear, we click "yes", we have to give our new (rebuilded) file a name,
    we call it "cv_0_new.img", this file is big, there should be 1,5gb of free space on your disk.
    2.08 After some time "AFS regenerated successfully!" will appear, we click "OK".
    2.09 Another message "A new ASF file has been created..." will be shown, we click "no", we can now close AFS Explorer.
    2.10 Cut our new file "cv_0_new.img", Open the map "PES 2008" and search for the map "img", in this map
    we delete "cv_0.img" and paste our "cv_0_new.img", after that we change the name from "cv_0_new.img" to
    the standard name "cv_0.img".
    2.11 We do the same steps from 2. for cv_1 and rv_e, with ofcourse the names cv_1_new.img and rv_e_new.img
    3. Kits
    3.01 Unpack "kitserver-710h".
    3.02 Insert the map "kitserver" into the programmfolder "PES 2008".
    3.02 Install it.
    3.03 Inside the map "GDB" we change the map "uni" with the one from the patch,
    if there is no map "GDB" inside the kitserver folder it should be like this: "...\Programm Files\PES 2008\kitserver\GDB\uni".
    3.04 That's all!
    Lot's of fun
    FUB
    Vragen, Opmerkingen of lofwoorden mogen altijd gepost worden natuurlijk, ik zal ze zo snel en goed mogelijk proberen te beantwoorden
    Ik vind het schitterend dat er een option file is van de jupiler league. Maaris er ook een manier om dit op de ps3 te spelen?
    Neen, het is onmogelij dit over te zetten.
    De edit mode op de PS3 is voor velen een teleurstelling...
    Blanco's Avatar
    thuis achter mijne PC
    Ik had hem al gedownload en getest, prima werk hoor
    Wel enkele bugs opgemerkt maar ze verstoren het spelplezier niet.
    Zo staat er nog altijd Eredivisie ipv van Jupiler League (logo's zijn wel juist)
    En tijdens een Jupiler league had ik Huntelaar bij mijn topscorers staan wat Vlcek moest zijn. Defour heeft ook zwart haar in uw patch...
    Ma, kleine dingentjes, niks om zorgen over te maken, kweet best hoe moeilijk (en saai) die dingen zijn en hoeveel werk dat allemaal is.
    Stats zijn ook in orde al is daar altijd wel discussie mogelijk, he. Ge kunt niet iedereen content stellen. Ma de ploegen die in't echt "betonvoetbal" spelen doen het in PES ook, al vind ik de stats voor teamwork wat overdreven.
    Ben al blij dat er opvolging is.
    Ik heb niks meer gehoord van Zotn_Dre of Sphongle en ook ik had er geen zin meer in om aan een JPL patch te beginnen.
    ShPonGle's Avatar
    114 (100%)
    Quote Originally Posted by Blanco View Post
    nope klopt wij spelen idd geen PES meer sinds PES 5. een JLP zal er van onze kant dus noois meer van komen, tenzij het spel plots drastisch in positieve zin mocht veranderen, alhoewel dit enkel pas echt kan gebeuren wanneer de JL er door de makers zelf al in gestopt wordt.
    wel leuk dat er nu opvolging is, alvast veel succes toegewenst! die kleine dingetjes zijn btw zeer vlug op te lossen!
    namen op truitjes
    Beste FUB, alleen op de truitjes van de anderlecht en brugge spelers staan de spelersnamen. Ik begrijp dat het maken van een jpl patch erg moeilijk is en tijdrovend en dat je niet alles kunt voorizen.
    Is er een mogelijkheid dat ik ze zelf kan invoegen op de truitjes.
    Via de editfunctie van PES 2008 is me dat niet gelukt.
    Krijg ik aub een antwoordje?
    Groetjes en nog eens bedankt voor de geweldige patch van jou!!!
    Blanco's Avatar
    Dat weet ik wel toevallig hoe ge dat moet doen. Het werkt niet via editmode omdat kitserver in dit geval overruled
    - Ga in de kitserver/GDB/uni/Jupiler League folder.
    - Daar staan alle folders van de ploegen in de Jupiler League
    - Kies een ploeg waar je dat wil veranderen (bv: Beerschot)
    - Ga in één van de folders, het gaat als volgt:
    ga: goalkeeper kit homekit
    gb: goalkeeper kit awaykit
    pa: player homekit
    pb: player awaykit
    - Ga bv in ga-folder en open de config.txt
    - Daar zie je de lijn : name.location = off
    verander dit in één van de volgende mogelijkheden bv
    name.location = top
    of
    name.location = bottom
    als dat niet werkt probeer eens down
    - Save de config.txt en you're done! Althans toch voor die kit...
    Ge hebt dus wel nog wat werk...
    Biglia's Avatar
    Schitterend werk!
    pa: player homekit
    pb: player awaykit
    name.location = top
    of
    Inderdaad, en als name.location niet aanwezig is gewoon inplakken natuurlijk
    ploegen met namen op de rug: Anderlecht, Beerschot, Brugge, Genk, Liège, Mons
    ivm met naam van de league, eredivisie ipv jupiler league, eenvoudige redenen waarom dit niet is aangepast is omdat ik simpelweg niet weet hoe het aan te passen.
    Dus moest iemand hier meer over weten, gelieve het met ons te delen
    Biglia's Avatar
    Mijn vraagje hier eens opnieuw stellen aangezien ik slechts enkele Belgische ploegen in PES wil brengen.
    Probleempje met kitserver:
    ik heb destijds één van de superpatchen geïnstalleerd voo pes 2008. Nu blijf ik steeds de oude keepershirts (van de superpatch) houden als ik kitserver installeer. Das nogal frustrerend.
    Quote Originally Posted by Biglia View Post
    Enkel de keepershirts?
    Biglia's Avatar
    Quote Originally Posted by FUBU753 View Post
    Ja. Vreemd he?
    namen op truitjes
    wat bedoel je met inplakken?
    Ja. Vreemd he?
    normaal gezien moet kitserver volledig 'over' de img's werken.
    En dan is het nog veel eigenaardiger dat het enkel de keeperstruien zijn.
    Zijn de mapnamen van de keepershirts nog goed (ga en gb)?
    Check anders eens in de kitserver map bij config of dit bestand er nog
    volledig inplakt: 'dll = kserv.dll' en of kserv.dll nog aanwezig is.
    Anders misschien eens herinstalleren en de nieuwste versie (710m?) installeren.
