Page 1 of 4 1234 Last
    ShenmueDragon's Avatar
    Lightbulb Vraagje over mijn pc!!!
    ik heb dus Age of conan gekocht(zalig spel)
    maar ik speel momenteel op minimum en heb een test gedaan op can you run it.
    en dit krijg ik voor Recommendend.
    CPU
    Recommended: Core 2 Duo E6600 or equivalent
    You Have: 2 processors running - Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    PASS
    System RAM
    Recommended: 2 GB
    You Have: 2.0 GB
    PASS
    Operating System
    Recommended: Windows Vista
    You Have: Microsoft Windows Vista Home Premium Edition, 32-bit (Build Service Pack 16001)
    PASS
    Video Card
    Recommended: 512 MB DirectX 9.0c Graphics Card with Shader 2.0 support (NVIDIA GeForce 7900 GTX or equivalent)
    You Have: Radeon X1600 Series ()
    FAIL:
    Sorry, your video card does not meet this recommended requirement.
    Upgrading to a more powerful video card will make all your applications look better. Click the 'We Recommend' button to see some great options.
    Video Card Features - Minimum attributes of your Video Card Video RAM:
    Required - 512 MB , You have - 1.2 GB
    Video Card 3D Acceleration: Required - Yes , You have - Yes
    Video HW Transform & Lighting: Required - Yes , You have - Yes
    Vertex Shader Ver.: Required - 3.0 , You have - 3.0
    Pixel Shader Ver.: Required - 3.0 , You have - 3.0
    Video Card Driver Version (DirectX)
    Your driver version number is: 7.14.10.567 FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
    Sound Card
    Recommended: Yes
    You Have: Luidsprekers (Realtek High Defi PASS
    Sound Card Driver Version
    Your driver version number is: 6.0 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
    Free Disk Space
    Recommended: 30 GB
    You Have: 395.0 GB PASS
    DVD
    Recommended: Quad-speed (4x) DVD-ROM drive
    You Have: ATAPI DVD A DH16A1L PASS, but the Speed could NOT be analyzed.
    dus failed omwille van mijn 3de kaart.
    maar wat ik niet goed snap heb ik in het rood gezet.
    Heb ik een kans of moet ik een andere kaart kopen en de welke dan?,
    Dank je
    Drez's Avatar
    gent
    61 (100%)
    en welke videokaart heb je exact. (+ specs)
    Ik ben een lekker wijf.
    www.dexyd.nl / www.dexyd.be
    t511413's Avatar
    waas
    idd daar heb je wel gelijk oO alles voldoet en is meer dan het nodige volgens de test
    tekn0w!z's Avatar
    Getwood
    11 (100%)
    Alles voldoet aan de recommended specs, behalve uw videokaart (voldoet aan minimum specs).
    Currently playing: Rocket League - Overwatch
    daarom kan ik erniet aanuit
    ik heb een radeon x1600 se maar dubbel
    Required - 512 MB , You have - 1.2 GB Video Card 3D Acceleration: Required -Yes , You have - Yes
    dat snap ik niet goed
    Drez's Avatar
    gent
    61 (100%)
    dan vat dat systeem dat gewoon niet. en voldoed je pc dus ruimschoots aan de reccomended.
    ik denk dat het rating systeem gewoon niet om kan met 2*512 mb = 1024
    dat zal kunnen
    maar alles ik alles op medium zet in het spel dan schokt ook alles
    en ik zal alles open kunnen spelen??
    tekn0w!z's Avatar
    Getwood
    11 (100%)
    Alles op high niet, medium zal doenbaar moeten zijn
    dan ga ik dat instellen se
    gisteren gedaan maar slechte framerate
    effe met de instellingen googelen
    zijn er dan instellingen dat je mijn kan kan aanbevelen??
    zaols op welke resolutie
    scherm is 1680 bij 1050
    Drez's Avatar
    gent
    61 (100%)
    trail and error
    wat bedoel je daarmee aub??
    Drez's Avatar
    gent
    61 (100%)
    proberen en tweaken tot je het beste evenwicht gevonden hebt.
    op elke pc werken die instellingen toch net anders. Begin zo hoog mogelijk en verlaag de instellingen steeds een beetje, net zo lang tot je zelf het evenwicht gevonden hebt tussen graphics en performance.
    nog wat sleutelen he
    in iedergeval dank je voor je hulp
