Thread: CS:S > config
    CS:S > config
    ik heb me deze week eens cs source aangeschaft. heb ene lange tijd cs 1.6 gespeeld. nu ziou ik graag mijn 1.6 script overzette naar source. maar het lukt me niet.
    mss dat jullie kunnen vinden wat er mis is?
    Code:
    bind "INS" "buy deagle;buy secammo"
    bind "HOME" "buy m4a1;buy AK47;buy primammo"
    bind "DEL" "buy primammo"
    bind "PGDN" "buy secammo"
    bind "PGUP" "buy awp;buyammo1;buyammo1"
    bind "END" "buy"
    bind "KP_HOME" "buy flash"
    bind "KP_UPARROW" "buy defuser"
    bind "KP_PGUP" "buy sgren"
    bind "KP_LEFTARROW" "weapon_hegrenade"
    bind "KP_5" "weapon_c4"
    bind "KP_RIGHTARROW" "weapon_smokegrenade"
    bind "KP_END" "pistol"
    bind "KP_DOWNARROW" "weapon_knife"
    bind "KP_PGDN" "weapon_flashbang"
    bind "kp_slash" "vest;vesthelm"
    bind "KP_INS" "+jump"
    bind "KP_DEL" "drop"
    bind "KP_PLUS" "buy vesthelm;buy hegren;buy flash;buy defuser;buy flash"
    bind "MWHEELDOWN" "lastinv"
    bind "MWHEELUP" "bestweap"
    bind "MOUSE1" "+attack"
    bind "MOUSE2" "+attack2"
    bind "mouse4" "weapon_knife"
    bind "MOUSE5" "+showscores"
    bind "PAUSE" "pause"
    alias bestweap "weapon_knife; grenades; pistol; shotgun; submach; rifle; auto"
    alias grenades "weapon_flashbang; weapon_smokegren; weapon_hegrenade"
    alias pistol "weapon_glock; weapon_usp; weapon_deagle; weapon_p228; weapon_elite; weapon_fiveseven"
    alias shotgun "weapon_m3; weapon_xm1014"
    alias submach "weapon_mp5navy; weapon_tmp; weapon_p90; weapon_mac10; weapon_ump45"
    alias rifle "weapon_ak47; weapon_sg552; weapon_m4a1; weapon_aug; weapon_scout; weapon_awp; weapon_g3sg1; weapon_sg550; weapon_galil; weapon_famas"
    alias auto "weapon_m249"
    dit heb ik in mijn config van cs geplakt. iemand enig idee waarom het niet werkt?
    Freekje's Avatar
    Baarle
    this "use weapon_x" ipv "weapon_x"
    rest emk geen idee van.
    Fraggie's Avatar
    Je hebt er wel een soep van gemaakt, je gebruikt bepaalde dingen door elkaar etc.
    Uit de FAQ:
    03. Scripting
    Buyscript:
    syntax: buy x
    bv: bind "x" "buy m4a1; buy ak47; buyammo1; buyammo1"
    Code:
    Pistols			Rifles		Equipment
      glock			  galil		  primammo //koopt alle kogels op
      usp			  ak47		  secammo
      p228			  scout		  vest
      deagle		  sg552		  vesthelm
      elite			  awp		  defuser
      fiveseven		  g3sg1		  nvgs
    			  famas		  flashbang
    Shotguns		  m4a1		  hegrenade
    ========		  aug		  smokegrenade
      m3			  sg550		  buyammo1 //koopt 1 clip
      xm1014		  		  buyammo2
    SMG			Machine guns
      mac10			  m249
      tmp
      mp5navy
      ump45
      p90
    Weapons:
    syntax: use weapon_x
    bv: bind "g" "use weapon_mp5navy"
    De namen zijn dezelfde als bij het kopen, gewoon use er voor zetten .
    Radio:
    Eindelijk moet niet meer zelf zorgen voor je radio binds:
    syntax: coverme
    Code:
    Radio1			Radio2			Radio3
    coverme			go			roger
    takepoint		fallback		enemyspot
    holdpos			sticktog		needbackup
    regroup			getinpos		sectorclear
    followme		stormfront		inposition
    takingfire		report			reportingin
    						getout
    						negative
    						enemydown
    Merk op, voor buyammo1 geen buy ervoor zetten.
    bedankt voor de hulp!
    nu werkt mijn buyscript al, maar ik krijg die aliases niet aan de praat.
    Code:
    alias bestweap "use weapon_knife; grenades; pistol; shotgun; submach; rifle; auto"
    alias grenades "use weapon_flashbang; use weapon_smokegren; use weapon_hegrenade"
    alias pistol "use weapon_glock; use weapon_usp; use weapon_deagle; use weapon_p228; use weapon_elite; use weapon_fiveseven"
    alias shotgun "use weapon_m3; use weapon_xm1014"
    alias submach "use weapon_mp5navy; use weapon_tmp; use weapon_p90; use weapon_mac10; use weapon_ump45"
    alias rifle "use weapon_ak47; use weapon_sg552; use weapon_m4a1; use weapon_aug; use weapon_scout; use weapon_awp; use weapon_g3sg1; use weapon_sg550; use weapon_galil; use weapon_famas"
    alias auto "use weapon_m249"
    kan je me hier nog even bij helpen? als ik ze gewon zo in mijn config.cfg zet verdwijnen ze.
    Fraggie's Avatar
    Waar zet je die aliasen?
    (liefst in autoexec.cfg (let op dat je er geen autoexec.cfg.txt van maakt), aanmaken als ze niet bestaat)
