Thread: Et : Wsaeacces
    Scissor's Avatar
    Et : Wsaeacces
    Hey,
    heb net ET gedownload en 'k krijg geen connectie met masterserver
    heb m'n firewall al is proberen uitzetten, maar maakt niets van verschil
    in de console staat : Net_sendpacket WSAEACCES
    iemand die raad weet?
    siL-'s Avatar
    leuven
    Quote Originally Posted by Microsoft
    • Translation: Permission denied.
    • Description: An attempt was made to access a socket in a way that is forbidden by its access permissions. For example, this error occurs when a broadcast address is used for sendto but the broadcast permission is not set by using setsockopt(SO_BROADCAST). Another possible reason for the WSAEACCES error is that when the bind (Wsapiref_6vzm.asp) function is called (in Microsoft Windows NT 4 .0 Service Pack 4 [SP4] or later), another program, service, or kernel mode driver is bound to the same address with exclusive access. Such exclusive access is a new feature of Windows NT 4.0 SP4 and later, and it is implemented by using the SO_EXCLUSIVEADDRUSE option.
    Weet niet direct een oplossing. Probeer eens een reinstall.
    currently playing for Team-YoYoTech
    crossfire.nu profile
    #9lives.et server admin
