    kristofke_1's Avatar
    Geel
    [HL2] Portals in Half - Life 2 en de Episodes
    Het was eigenlijk te denken en nu is het zover: Iemand die het zinnetje "Now you're thinking with Portals" wat te letterlijk nam en ervoor gezorgd heeft dat je met het portalgun kunt spelen in de Half-Life 2 games (en alle ander source-based games).
    Werkwijze: (natuurlijk op eigen risico)
    • First off, backup up your entire Portal directory in a safe place. It’s the folder marked ‘portal’ in ..\Steam\steamapps\(your_steam_id)\. We, nor Valve, take any responsibility in the unlikely event of you hosing your game files. Worse comes to worse though, you could always just redownload.
    • Next, download and install, if you haven’t already, GCFScape. This handy program will allow you to access the cached game files for any Source-powered game, in addition to several other Steam games you may have downloaded.
    • Once that’s done, browse to the directory ..\Steam\steamapps\. There, you’ll see all the available GCF archives. We’ll start with Half-Life 2.
    • Open the GCF marked ‘half-life 2 content.gcf’ You’ll see a directory tree in the left pane. Click the box to the left of the folder marked ‘hl2’ to see the directory listing contained within it. Then, right-click ‘maps,’ select ‘Extract’ and extract the entire folder into the directory \Steam\steamapps\(your_steam_id)\portal\portal. This will merge it with the existing Portal map folder.
    • Do the same with the ’scenes’ folder
    • Fire up Steam and run Portal. When it’s done doing its thing, open up the developer console with ‘~’ (you may need to enable it under your keyboard options).
    • At the console, type ‘maps *’ to list all the available maps. Now that you’ve imported the Half-Life 2 maps, this will be a fairly lengthy list and some of the names, like citadel and canals, should seem familiar.
    • Type ‘map’ and then the map name to open that map. For instance, ‘map d1_canals_01’
    • When the map is done loading, pull up the console again and enable cheats by entering ‘sv_cheats 1’
    • To give yourself all weapons, including the portal gun, enter ‘impulse 101’
    • Depending on how far you got in Portal, you may need to upgrade the portal gun to fire both portals. Enter ‘upgrade_portalgun’ to do so
    • Go lay waste to some alien scum with the power of portals!
    FILMPJE: Klikkie
    BRON: http://www.primotechnology.com/2007/...life-2-portal/
    Ik heb het persoonlijk nog niet geprobeerd maar ga het toch in de loop van de week eens uittesten
    ~ DECAP BEAT MACHINE ~
    Insano's Avatar
    The Matrix
    Het ziet er wel leuk uit, maar uiteraard zijn de levels in HL2, ... niet gebouwd voor deze soort gameplay. Hopelijk in Episode 3 toch wel?
    "At the beginning of the Portal development process, we sat down as a group to decide what philosopher or school of philosophy our game would be based on. That was followed by about fifteen minutes of silence and then someone mentioned that a lot of people like cake."
    - Valve
    Oostkamp
    Vast wel, want men leg nu sterk de nadruk op dat Portal waarschijnlijk voorkomt in EP3...
    Ma ik heb gelezen dat de AI niet op de Portals reageert (zelfs niet als ze je zien via de portal) dus veel fun zal het mssn niet meer zijn.
    Insano's Avatar
    The Matrix
    Quote Originally Posted by RiskGhost View Post
    Jep.
    Dat is gewoon een kwestie van hoe de AI in HL2 is geprogrammeerd. In portal schieten de sentries wel door de Portals dus dat zal geen probleem zijn
    - Valve
    oNt-'s Avatar
    mechelen
    zou wel vetjes zijn als de portal gun in EP3 komt
    //oNt
    Holy Paladin's Avatar
    Oost Vlaanderen
    19 (100%)
    er gaat geen portal gun in ep3 komen,
    denk ik hee
    Oostkamp
    Goeie gedachte ik geef u geen ongelijk, maar vergeet niet dat het hier om Valve gaat he, en die gasten... die kunnen het onmogelijke mogelijk maken.
    Insano's Avatar
    The Matrix
    - Valve
    i386dx's Avatar
    Lokeren
    Gisteren al eens geprobeerd. Werkt met HL2, met EP2 niet (ep1 nog nie getest).
    Best wel leuk voor eventjes; zijn natuurlijk nog wat kleine bugjes aan verbonden.
