22-08-2007, 12:27 #1Approved 9-lifer
- Boechout
- 3,081
global account reset!!! woensdag 22/8
http://www.etqw.com/en/news/872-Impo...r-Beta-players!
go read.
int kort: vandaag account reset, dus account bye bye. Oud profiel verwijderen, nieuw maken met de key die je reeds hebt.
maw: je kan je account name wijzigen ook
opgelet: wat dit doet met je config, geen idee, eventueel eventjes een backupje nemen van je autoexec (als je die hebt aangemaakt) anders is de kans groot dat je mss al je controls moet gaan herzetten.Visit www.holysh1t.net and http://tv.holysh1t.net and join #qlpickup.eu for Quake Live CTF (and TDM) pickup!no votes
22-08-2007, 17:13 #2
Dan kan ik eindelijk mijn newbie stats eens verbeteren
Normaal krijgt elke beta-tester hier een mail van...What is needed on this planet is a massive shift in consciousness.
Religon - the root of all evil ?!
22-08-2007, 19:51 #3Approved 9liver
- 18/04/03
- Hasselt
- 14,855
- 23 (100%)
- 12/79
is allang gebeurd dat is de mail wat hierboven onderstaat
he wipe is currently scheduled for this coming Wednesday (August 22, 2007) at 10pm GMT (5pm EST) at which point you will no longer be able to play unless you re-create your account in the manner described below. The statistics are also going to be reset that day.
YOU CAN STILL PLAY THE BETA.
Follow these steps to re-create your account
1) The accounts database is reset. Your in-game account will no longer work.
2) Start the Enemy Territory: QUAKE Wars beta client. On the login screen, delete your in-game account.
3) Retrieve your beta license key from FilePlanet. It can be found both in the email you were sent after signing up or the beta and under My Account -> Beta Keys Archive on the FilePlanet website.
4) Back in the beta client, go to “Create User” and select “Create new online account”. Put in your account name along with your beta license key and click “Finish”.
5) That’s it! You’re all set and ready to dive back into the Enemy Territory: QUAKE Wars beta.
Access your FilePlanet beta keys archive here: http://www.fileplanet.com/betas/keydisplay.aspx
Thanks for your participation, and please enjoy the rest of beta.
-The Enemy Territory: QUAKE Wars Teamno votes
22-08-2007, 20:21 #4
ik heb geeneens die key opnieuw moeten ingeven :/
23-08-2007, 01:12 #5Approved 9-lifer
- Boechout
- 3,081
ik ook ni?
alle vooruit dan
mss hebben ze da maar voor de zekerheid gezegd
TEUT, account reset 0:44 hierLast edited by Lashknife; 23-08-2007 at 01:45.
23-08-2007, 01:15 #6Member
- 12/02/03
- Genk
- 1,747
ik moest da wel doen
pfff, BF2 hier i come
zzz ...no votes
23-08-2007, 01:28 #7
Unknown Error alsk probeer in te loggen (na account te hermaken). Op ETQW forums nog mensen met da probleem precies
23-08-2007, 14:45 #8Super Moderator
- 25/08/02
- Kempenzoon
- 11,766
- 8 Post(s)
- 17/225
hier was het deze morgen ook van dattum. Blijkbaar zijn mijn configs (grafisch) wel bewaard...
nuja, op grote server is het spel me toch wat te buggy
24-08-2007, 17:27 #9
Ik zie niet in waarom mensen dit als negatief beschouwen, gewoon even je beta key opnieuw invullen en verderspelen
je bedoelt laggy? schuld van je eigen pc/settings
ik zie niet in waarom er opeens (meer) bugs zouden zijn op een grote server
28-08-2007, 09:28 #10Member
- 12/02/03
- Genk
- 1,747
ik heb net het tegenovergestelde gevoel
sinds de reset gaat alles bij mij stukken beter
alsof ik het licht gezien heb
400+ xp meer regel dan uitzondering nu
zzz ...no votes
28-08-2007, 12:56 #11
bij mij is het echt buggy, ik schiet echt op maar echte op de ventjes e en kheb geen 1 hit. Tis niet te doen. Als ik zo aim in ET gelijk dak doe in ETQW haal ik zeker 50 % acc, maar in ETQW echt niet te doen.
29-08-2007, 10:13 #12Approved 9-lifer
- Boechout
- 3,081
exoz, er zijn mss nog andere parameters, maar probeer eens net_clientprediction 0 ipv de default 20 (vind ik toch wel veel), desnoods in stappekes van 5 aftellen.
29-08-2007, 13:37 #13
en wa doet da precies? kga eens proberen zi thx voor de tip al
is er ergens een site waar al die parameters staan en wat ze precies doen?no votes
