01-08-2007, 12:02 #1
Probleem met xbox live via switch (omschrijving in engels.... copy van xbox.com forum
I connected my 360 to my inet-cable up stairs... which works properly... but I cant seem to get my xbox live running. Now here is the <mod REMOVED - do not attempt to bypass the word filter> up part. (die mods toch eh)
I tried entering all my networking values manually... maybe my networking switch was doing some strange stuff and it didn't give me an ip or something.... so... let's do it manually..... frustrating enough... it does not work... although the ip I entered is accepted (same as pc downstairs with a value of +2) but the DNS can't be resolved....
strange huh.... than look at this.... I coppied all of the parameters of my working pc downstairs.... shut down the comp... shut down the modem and switch..... activated my modem and switch again... left the pc off.... than entered all of the copied values..... now in my opinion a DNS server can't detect if the I/O signal is comming from a real pc or an xbox right.... with all the values my comp uses to succeed in getting internet filled in in my xbox connect settings..... IT STILL FALES......
GHOST IN THA MACHINE .... right??? riiiiiiight???
If anyone got some helpfull info.... thanks alot!!
Wil er wel effe bijzeggen dat ik zeker ben dat men kabel naar behoren werkt... en mijn xbox heeft altijd op inet gedraaid.. maar dan via een host pc... nu hangt hij zoals boven beschreven rechtstreeks aan de switch..... iemand suggesties? tnx
So what they call me "The HappyMan".... Aint nothing nice about me!!
01-08-2007, 12:51 #2Member
- 13/10/02
- Lembeek
- 853
- 2/3
Er bestaat een probleemthread voor dit soort zaken.. probeer in deze thread je vraag te stellen. cu
Xbox Live Gamertag: Tonic BE
PSN: TonicBEno votes
01-08-2007, 19:48 #3Member
- 10/08/05
- hasselt
- 5,543
- 144 (100%)
- 17/25
heb dat ook al meegemaakt ...eerst ne nieuwe switch gaan halen...bleef disconecten toen bleek dat als je de telefoon uittrok alles normaal werkte ..nu gaf de telefoon kortsluiting.
01-08-2007, 23:56 #4Member
- 04/11/03
- Hofstade
- 8,885
- 25 (100%)
- 8/8
hoeveel apparaten gebruiken een ip adres en hoeveel ip's heb je?
If the doors of perception were cleansed, everything would appear to man as it is: Infiniteno votes
