Page 1 of 3 123 Last
    MorGo7h's Avatar
    29 (100%)
    CS:S > High FPS cfg + Cvar?
    Kspeel sinds dit weekend terug css, na 15maand terug begonne. Alsk nu war wil spele op een server met Cvar reset hij al mn grafix :/ Normaal heb echt geen detail, nu dus wel...
    Iemand een idee hoe dak mijn low gfx kan houde op een server met cvar erop?
    mn config:
    Code:
    // netcode
    rate 25000
    cl_cmdrate 100
    cl_updaterate 100
    cl_interpolate 1
    cl_interp_ratio 0.01
    cl_interp 0.01
    cl_interp_all 0
    cl_allowdownload 0
    cl_allowupload 0
    cl_downloadfilter nosounds
    cl_dynamiccrosshair 0
    cl_lagcomp_errorcheck 1
    cl_lagcompensation 1
    cl_resend 2
    cl_showfps 0
    cl_smooth 1
    cl_smoothtime 0.01
    cl_timeout 9999
    fps_max 101
    net_maxfragments 1280
    sv_alternateticks 0
    sv_unlag 1
    cl_restrict_server_commands 0
    //GFX
    cl_c4dynamiclight 1
    cl_ejectbrass 0
    cl_phys_props_enable 0
    cl_phys_props_max 0
    cl_ragdoll_physics_enable 0
    cl_ragdoll_collide 0
    cl_showsplashes 0
    con_enable 1
    fog_enable 0
    fog_enable_water_fog 0
    fog_enableskybox 0
    r_rainradius 0
    r_rainsplashpercentage 0
    r_rainsimulate 0
    r_rainalpha "0"
    r_rainalphapow "0"
    r_raindensity"0"
    r_rainlength "0"
    r_RainProfile "0"
    r_rainradius "0"
    r_RainSideVel "0"
    r_rainspeed "0"
    r_rainwidth "0"
    mp_decals 4096
    cl_ejectbrass 0 // _disables shells flying out of guns_
    cl_forcepreload 1 // _forces preload to help increase performance_
    cl_phys_props_enable 0 // _disables trash and cans etc_
    cl_phys_props_max 0 // _disables trash and cans etc_
    cl_ragdoll_physics_enable 0 // _disables dead animations and bodies_
    cl_show_splashes 0 // _disables splashes when in water_
    fps_max 60 // _caps FPS_
    mat_antialias 0 // _disables antialiasing_
    mat_forcean
    mat_bloomscale 0
    mat_hdr_level 0
    mat_bumpmap 0 // _disables bumpmapping_
    mat_clipz 1 // _disabled non visible object rendering_
    mat_fastnobump 1 // _faster bump mapping_
    mat_fastspecular 1 // _fast specular lighting_
    mat_mipmaptextures 1 // _texture quality decreases with distance_
    mat_picmip 4 // _lower texture quality--set between 0 and 4_
    mat_reducefillrate 1 // _reduces shader fill rate_
    mat_specular 0 // _disables specular lighting_
    mat_trilinear 0 // _disables trilinear filtering_
    mat_wateroverlaysize 16 // _lowers water quality_
    mat_dxlevel 81 // _kakapipi:)_
    mat_vsync 0 // _disables vertical synchronization_
    mat_forceaniso 0 // disables AF
    muzzleflash_light 0 // _disables muzzleflash_
    r_avglight 0 // _disables average lighting_
    r_cheapwaterend 1 // _worse water rendering_
    r_cheapwaterstart 1 // _worse water rendering_
    r_drawdetailprops 0 // _disables detail props_
    r_drawmodeldecals 0 // _disables decals on models_
    r_dynamic 0 // _disables dynamic lighting_
    r_eyes 0 // _removes eyes from player models_
    r_lightaverage 0 // _disables average lighting_
    r_lightinterp 0 // _disables light interpolation_
    r_renderoverlayfragment 0
    r_lod 3 // _adjusts model quality--set between -5 and 5_
    r_rootlod 2 // _lower overall game detail level_
    r_shadows 1 // _set to 0 to disable shadows (not recommended)_
    r_teeth 0 // _removes teeth from player models_
    r_waterforceexpensive 0 // _disables high-quality water_
    rope_averagelight 0 // _disables average lighting on ropes_
    rope_smooth 0 // _disables antialiasing on ropes_
    rope_subdiv 0
    rope_wind_dist 0 // _disables wind effects on ropes_
    cl_downloadfilter "nosounds" // _disables annoying sound downloads_
    jpeg_quality 100 // _high quality screenshots_
    mat_monitorgamma 1.6 // _maximum ingame brightness_
    sv_forcepreload 1 // _forces preload to help increase performance_
    mat_trilinear "0"
    mat_disable_bloom "1"
    r_DoCovertTransitions 1
    r_dopixelvisibility 0
    r_drawdetailprops 0
    r_drawflecks 0
    r_dynamic 0
    r_eyeglintlodpixels 0
    r_eyegloss 0
    r_eyemove 0
    r_eyes 0
    r_flex 0
    mat_shadowstate 0
    r_shadowmaxrendered 16
    r_shadowrendertotexture 1
    // blood
    cl_show_bloodspray 1
    violence_agibs 1
    violence_hgibs 1
    violence_hblood 1
    violence_ablood 1
    show_bloodspray 1
    //Graphische tweaks
    fps_max 101
    showhitlocation 1
    jpeg_quality "100"
    budget_show_history 0
    // blood
    violence_agibs "1"
    violence_hgibs "1"
    violence_hblood "1"
    violence_ablood "1"
    cl_show_bloodspray "1"
    show_bloodspray "1"
    // cross
    cl_crosshaircolor "5"
    cl_dynamiccrosshair "0"
    cl_scalecrosshair "1"
    cl_crosshairscale "8000"
    cl_crosshairusealpha "1"
    crosshair "1"
    //radar
    cl_radartype "1"
    cl_radaralpha "200"
    // grafiek commands
    net_graph "0"
    // voice en sound options
    bgmvolume 0
    dsp_enhance_stereo 0
    dsp_slow_cpu 1
    dsp_spatial 40
    dsp_speaker 50
    dsp_volume 2
    dsp_water 14
    snd_digital_surround 1
    snd_flushasync
    snd_mixahead 0.1
    snd_musicvolume 0
    snd_noextraupdate 1
    soundscape_flush
    suitvolume 0
    volume 2
    voice_forcemicrecord 0
    r_mmx "1"
    r_sse "1"
    r_sse2 "1"
    bind "0" "slot10"
    bind "1" "slot1"
    bind "2" "slot2"
    bind "3" "slot3"
    bind "4" "slot4"
    bind "6" "slot6"
    bind "7" "slot7"
    bind "8" "slot8"
    bind "9" "slot9"
    clear
    echo "MorGo7h's config loaded"
    echo "[G]ood [L]uck - [H]ave [F]un"
    Fractal Design R6 -- Intel Core i7 8700k @ 5.0Ghz -- Asus Hero X -- Corsair Vengeance 16GB -- MSI Gaming X 1080 TI @ 2040Mhz/1000mV-- Corsair RM850x (2018) -- Custom water loop
    Samsung 970 EVO 500GB -- Samsung 850 EVO 500GB -- Seagate Barracuda ST500DM002 -- Acer XB271HU (165hz 1440p IPS)
    Corsair K70 -- Zowie FK2 -- Steelseries QcK heavy -- Sennheiser HD598 + Modmic 4.0
    drunkenbullet's Avatar
    autoexec @ alleen lezen ?
    MorGo7h's Avatar
    29 (100%)
    Quote Originally Posted by drunkenbullet View Post
    nee keer probere, maar der word nix in mn cfg verandert dusja
    Edit: Da werkt dus ni..
    Gsus^!'s Avatar
    Bassevelde
    Kerl gij ebt wel e vree zwak pc'tje, dien cfg es uitgetest ma die graphics vent =s
    Tomorrowland
    |2AiD's Avatar
    cl_interp_ratio moet gwn op 1 btw gelovek.... mja zBlock laat de meeste shit nie door
    Frg^'s Avatar
    Schaffen
    mat_picmip 2 en r_lod -1
    en dan hebde denkek geen problemen meer
    MorGo7h's Avatar
    29 (100%)
    Ty, kgaat sebiet is gaan testen.
    EDIT: Werkt dus niet... Mn grafix staan weer gewoon... Vroeger nooit last mee gehad en na 15 maand speelk terug en tis al fucked??
    MorGo7h's Avatar
    29 (100%)
    Quote Originally Posted by Gsus^! View Post
    M'n pc is zwaarder dan die van u Ik speel gwn liever op low gfx...
    Gsus^!'s Avatar
    Bassevelde
    jah zou kunne ma het rare is bij mij, ofda ik nu op heel hoge graphics speel of op heel lage, mn fps blijft hetzelfde...
    Tomorrowland
    C0re's Avatar
    Sleidinge(Gent)
    tis gewoon nie mee mogelijk om op superlow gfx te spelen omdat die een voordeel kan geven tov anderen.. (train , geen wielen etc.. )
    Gsus^!'s Avatar
    Bassevelde
    Ahzo, want als ek soms alles op high graphics zet krijg ek dan zelfs meer fps
    Tomorrowland
    MorGo7h's Avatar
    29 (100%)
    Quote Originally Posted by C0re View Post
    Verkloot mss gans css... goe bezig steam... Kga wel een ander spel gaan spele :/
    Gsus^!'s Avatar
    Bassevelde
    css ftw nog altijd maarja gewoon wachten op nieuwe pc deze zomer ....
    Tomorrowland
    BrollyTL's Avatar
    Kapellen
    css ftw
    the ignorance
    ReQ^ :: DeFiance :: Dio :: My Musheen :: Dommel ::
    Frg^'s Avatar
    Schaffen
    wa ge ook kunt doen is via ati tray tools(als ge ati hebt) uwen picmip low te zetten en in uw cfg dan wel mat_picmip 2 dan blijfde toch diejen mat_picmip 4 eiglijk hebbe
