Thread: Char transfer
    Exclamation Char transfer
    Vraagje:
    Mijn broer en ik speelden al heel lange tijd op zelfde account enzo. Maar nu gaat hij z'n eigen account kopen, kan hij z'n char overzetten op die account? en moet je hiervoor betalen of is dit gratis?
    Thx
    Frans_tsoenamie's Avatar
    voor zover ik weet ,niet . en ik ben er vrij zeker van
    Hip-hop is supposed to uplift and create, to educate people on a larger level and to make a change.
    jer's Avatar
    zou mogelijk moeten zijn als je broer zijn account dezelfde owner is als jouw account, dus gewoon dezelfde naam/adres/emailadress etc
    Guild Wars 2
    Sloth's Avatar
    Tongeren
    tis 20 € en
    Can I transfer characters from one account to another?
    Yes, you can transfer characters not just between realms but also between accounts. However, you may only request character transfers from one account where you are the owner to another account where you are the owner. Any attempt to transfer a character from an account where you are not the owner could be considered a violation of the World of Warcraft Terms of Use and could lead to Blizzard taking disciplinary action against your account, including, but not limited to warnings, temporary account suspension, or permanent account suspension, as determined by Blizzard.
    To initiate a transfer between two of your accounts, you will need to specify the account name associated with the account you wish to transfer your character to, and answer the secret question for the destination account Please contact our billing department directly if there are any problems with your transfer.
    Who is eligible for account to account transfers?
    Transfers between accounts are only allowed between one account where you are the owner to another account where you are the owner. To initiate an "account to account" transfer, you will have to answer the secret question for each account, and the last name of each account holder must match.
    Why is it set up that way?
    Blizzard takes the integrity of its game and its account ownership very seriously. To this end, the sale of characters and accounts is expressly against the World of Warcraft Terms of Use. The restrictions on account-to-account transfers were developed specifically with this in mind.
    Can I give one of my characters to a friend or guild mate?
    No. You are only allowed to transfer a character to an account where you are the original registered owner.
    Overpelt
    Quote Originally Posted by jer View Post
    idd zoals jer zegt moet maken da alle account info dezelfde is anders gaat het niet, en het is niet gratis, kost 20euro per char denk ik
    meer info
    https://www.wow-europe.com/character/
    Main: Destroyer 80 Paladin
    Alts: Atomizer 72 Mage <> Drakos 80 Warrior <> Cenarian 72 Druid
    Sprits's Avatar
    Reet
    81 (100%)
    ik heb het al gedaan
    tis 20€ en de achternaam van beide accounts moete hetzelfde zijn
    en ge moet de geheime vraag van beide accounts ook invulle
    Funk$t@r's Avatar
    Balen
    gewoon extra account kopen (via gamersloot.net ofzo)
    account aanmaken met zelde naam op zelfde adres
    email moet niet hetzelfde zijn (voornaam ook nie)
    dan gewoon transferen via de site (20 euro)
    Lust brings Envy..
    FurtiveDuck's Avatar
    Dit is inderdaad idem aan een character van realm verranderen. Je moet dezelfde procedure doorgaan.
    Je logged in Wow-Europe.com, daar dan Payed Charactered Transfer. Daar kan je dan vanalles kiezen. Dit kan wel alleen maar worden betaalt met Mastercard of Visa.
    Starrk's Avatar
    33 (97%)
    In de FAQ staat alle nodige info.
    Als deze toch blijkt verkeerd te zijn, stuur me een PM-pje.
