Thread: Final Fantasy 3 (Friend Codes)
06-05-2007, 11:49 #1
Misschien leuk als je uw friendcode wil posten.
Zou deze graag online testen en enkele nieuwe dingen unlocken:
How to obtain access to secret dungeon:
In the Nintendo DS version of FFIII, there is a secret dungeon that contains a secret boss harder than the last boss, in order to obtain access:
1)Send a total 7 mails to another PC (one or multiple) using Mog Net.
2)Send 4 mails using Mog Net to the NPC: The 4 Elderly
3)Send 4 mails to King Arusu and after reading the fourth one, you'll unlock a quest
4)Go ride on the airship that can go underwater
5)Head for the floating island and once finding it, go exactly east..
6)You will eventually see a shadow in the waters, once you do go underwater to enter the cave
7)Soon after entering the dungeon, you will meet the secret boss
*This boss is notorious and mean. It does a total of 4 attacks per sound and also uses Meteo. Please be at a very high level before attempting this fight.
How to obtain secret job: Onion Swordsman
Back in the original Famicom FFIII, Onion Swordsman was the first job you start as (unlike Freelance from the DS version), but you can play this job in the Nintendo DS version as well by unlocking it. Onion Swordsman is one of the most powerful jobs with the Onion Equipment + past level 90's.
How to obtain:
1)Register someone elses's (or multiple) communication ID under Mog Net.
2)Send message to another PC 7 times
3)Send and receive 4 messages from Topapa, on the fourth one you will receive a message to do a mini-quest.
4)Go to Ur (First town in the game)
5)Talk to Topapa
6)Go to the cave up north of the cave
7)At the drop hole, you will have an event and then will be proceeded to fight 3 bombs
8)After the battle, you will obtain a piece of crystal, which will unlock Onion Swordsman
Grtz
15-05-2007, 21:59 #2
ah okay ik zal je eens adden
mijn friend code is btw: 150423752661
18-05-2007, 18:42 #3Member
- 19/07/02
- belgie
- 61
friend coed is : 266387728894
Kill One,
MURDERER,
Kill Ten,
SERIAL KILLER,
Kill'm All,
YOU'RE GODno votes
26-05-2007, 20:23 #4
k ik heb je geadd
30-05-2007, 09:24 #5
ik krijg ff3 binnenkort , hoe werkt dit net?
30-05-2007, 14:08 #6
je gaat online met je ds in final fantasy door middel van tegen een moogle te praten. Als jij mijn friendcode accepteerd en ik de jouwe kunnen we mails sturen naar elkaar.
Door middel van die mails kun je bovenstande stuff unlocken.
03-06-2007, 16:33 #7
Ik zou maar wat rondsturen als ge uw mannekes hun stats wilt maxen.
Als ik een guide mag geloven dan heeft Onion Knight de max HP en max MP growth.
Anyway mijn code is: 369 468 357 012Last edited by Blood_Raven; 03-06-2007 at 16:41.
04-06-2007, 00:49 #8Member
- 06/04/03
- Aalst
- 306
Mijn friendcode = 068 820 913 099
En heb iedereen hier geadd maar ik krijg error bij de code van Blood_raven.no votes
04-06-2007, 11:50 #9
Raar, ik zit wel op de US servers.
Kan de fout daaraan liggen?no votes
04-06-2007, 12:53 #10Approved 9liver
- Mechelen
- 3,990
- 0/37
ik zal die van mij strax posten, eerst wa verder trainen (mannekes zitten nu lvl 40)
This signature is a lie!
04-06-2007, 18:29 #11
Hehe heb juist Onion Knight
(mannekes level 21)
Juist eens opgezocht. Onion knight stats beginne pas extreem te worde vanaf lvl 93
Daar gaat mijn tactiek om zo rap mogelijk 9999 hp te hebbe
04-06-2007, 19:48 #12Approved 9liver
- Mechelen
- 3,990
- 0/37
Fc: 5197-9262-8293
05-06-2007, 16:04 #13Member
- 06/04/03
- Aalst
- 306
Hoe komt het dat iedereen die ik toegevoegd heb nog steeds in het grijs staan? Ik kan nog steeds geen mails versturen naar iemand 'far away'.
09-06-2007, 01:25 #14
kweet niet, ik ga af en toe eens op mognet om te zien of ik mails ontvangen heb, doen jullie dit ook, mss moeten we dit doen om in de friend list te geraken
goddie is added woohoo
09-06-2007, 21:06 #15
voilla ze ik heb men onion knight
, mensen vergeet ook geen mails naar topapa te sturen eh
Battousai
