    marle's Avatar
    1.4.1 beta changelog + (dowload links)
    Enkel de changelog is gegeven.
    momenteel zoeken ze naar servers voor de patch optezetten.
    Dus tegen vanavond of morgen zal die avaible zijn.
    Quote Originally Posted by SyncError;
    Quake4 1.4.1:
    * new movemement code on angled surfaces (pm_slidevelocity and pm_powerslide)
    * LG knockback 6->11, fire rate 0.05->0.04, damage 8->7, max cells 400->300, range 768->736
    * LG & GL crosshair .dds files updated (with correct versions)
    * fixed player corpses warping to spawn locations
    * net_clientRepeaterDelay added for Q4TV
    * RG starting ammo 5->7, ammo box 10->7, max ammo 25->35
    * fixed pixelization of all crosshairs, added 2 new ones
    * allow backslash in say text, \o/
    * spectators can now use teleporters
    * unprotected r_displayRefresh
    * removed health/armor adjustments from g_handicap; now affects players damage output only
    * model specfic sound code to allow unique sound sets be defined for each model
    * several OpenAL sound fixes
    * assume private networks are LAN servers; net_forceInternet can be used if they aren't
    * allow mods to alter engine level cvar flags
    * added si_fps 'Tickrate' to server browser hover info
    * new lagometer code, increased performance and works with r_useSMP
    * force pro skins option added to Game Options GUI
    * unlocked g_gunX, g_gunY, g_gunZ cvars
    * added g_weaponFovEffect
    * gun position option added to Game Options GUI
    * fixed some item pickups not being viewable by Q4TV
    * new size for megahealth simpleItem
    * pure check for Q4TV added
    * fixed NextWeap/PrevWeap when scrolling through several weapons at once
    * fixed broken firing animation for viewers
    * projectile explosions/impacts are always predicted correctly now; gives much better feedback to the player when lagged
    * fixed the need to toggle console before entering a password
    * shaderParm support added for model renders in GUIs (allows for mods to display brightskins dynamically in GUIs)
    * net_challengeLimit increased from 15 to 30 seconds to minimize timeouts during loading of an addonpak
    * free gameclient/bot slots for bots removed
    * net_clientPrediction archives
    * jump / crouch animation added for players crouched in midair
    * prevented DeadZone triggers from being called in other gameTypes, which caused memory corruption
    * added snaps to GUI sliders
    * added chat support for Q4TV
    * made use of smaller data types to decrease network traffic
    * increased limit of possible viewers for Q4TV
    * fixed missing respawn sound with g_simpleItems
    * recordNetDemo now works for Q4TV
    * fixed stuck hums
    * fixed issues with switching to addonpaks via the Admin GUI
    * s_useDeferredSettings default changed to 0
    * clear new dict and save/restore serverInfo cvars when doing a reloadEngine for spawnServer
    bron: http://www.esreality.com/?a=post&id=1364626 .
    Ik vind er ni zoveel speciaal aan.
    Alleen voor de nieuwe movemement ben ik benieuwd.
    --= download links for quake4 1.4.1 =--
    - http://q4files.escapedturkey.net/qua.../...-1.4.1.exe
    --= download links for Q4max 0.78a =--
    - http://www.quakeunity.com/file=2455
    FoRCe's Avatar
    Ieper
    2 (75%)
    extra info Q4MAX078a:
    * Notes for version 0.78a (03 Apr 07)
    add: Q4 beta 1.4.1 compatibility - this version of Q4Max does not run on Q4 beta 1.4.0 or lower.
    add: cg_railstyle 3 adds a new rail effect similar to the SP Gladiator rail.
    add: You can now preview team/enemymodel colors in the GUIs.
    add: A few extra cvars saved into profiles : cg_predictmg/sg/rg, g_gunx/y/z, hud_multipovstyle, g_favoriteList
    chg: GUIs for vertexlight/forceambient and other lighting options made clearer.
    chg: Removed the "aligned" crosshairs, 1.4.1 has better crosshairs that do this.
    chg: cg_blood 0 now disables blood, but replaces it with spark effects.
    fix: Some explosions not displayed when directly hitting players if cg_blood 0.
    fix: You can now turn g_feedscorebot back on, Q4 1.4.1 fixes the segfault / access violations that were occuring.
    fix: Changing si_fps on a live server restarts the map at the proper tickrate instead of going crazy.
    fix: Switching povs as a spectator sometimes didn't work, and/or caused projectiles to disappear. Also related, scoreboard would stick open, and various other issues as a spectator.
    fix: Tourney mode client crash on player disconnecting.
    FoRCe's Avatar
    Ieper
    2 (75%)
    Lashknife's Avatar
    Boechout
    wel nice dat ze dat in beta's releasen, kan een goeie result aan feedback info opleveren.
    Spijtig dat het nog gene final is, maar denk wel dat ik deze eens ga laten installen op een van de telenet servers.
    Visit www.holysh1t.net and http://tv.holysh1t.net and join #qlpickup.eu for Quake Live CTF (and TDM) pickup!
    marle's Avatar
    Quote Originally Posted by Lashknife View Post
    inderdaad, ik dacht eens clean instal van quake 4 te doen met de final patch.
    zodang dat ik van al die overbodige filles af ben.
    Maar dat zal dan voor later zijn.
    (hopelijk wachten ze niet te lang meer).
    Natuurlijk kan dit alleen maar een verbetering zijn voor de final patch.
    die normaal in de paats van de beta moest komen.
    Dus oftewel gaat er nog nieuwe stuff komen, of doen ze nog aan een paar bugg fixes. En moetten we niet te lang wachten.
    Althans ben ik blij dat id nog zoveel moeitte wilt doen.
    Lashknife's Avatar
    Boechout
    idsoftware heeft altijd moeite blijven doen met patchen uitbrengen (zie maar naar de heel late 1.32c mini patch laaaang na 1.32)
    Alsook een goeie customer binding als ge uw games goed support (Blizzard doet dit ook)
    En op moment hebben ze al helemaal niks te verliezen met qw:et dat eraan komt en een concurrent voor menig teambased fps vormt.
