21-03-2007, 14:20 #1
CS:S > kan met geen bots meer spelen
21-03-2007, 15:34 #2Member
- 04/02/04
- Turnhout
- 778
- 1/1
2 threads voor zo iets, gebruik snel google, ik heb al verschillende antwoorden gelezen, deze bv:
Here you go.
Download and play the Source Dedicated Server (under Steam and then Tools). Create a game in Source Dedicated Server and shut it down once it's up. Then go to the folder Steam/SteamApps/(youraccountname)/source dedicated server/bin and copy the steamclient.dll into the folder Steam/SteamApps/(youraccountname)/(whatever game you want to play)/bin . The game will then load up correctly. I hope Valve releases an automatic patch for this soon, its a very common problem.// Qck //no votes
23-03-2007, 15:40 #3
een duidelijke uitleg van het probleem zou ook op z'n plaats zijn...
Intel Core 2 Quad Q9650 3.0Ghz :: 2 x 2GB Kingston 800MHz DDR2 Non-ECC CL5 :: Club3D HD 4870 X2 :: HP LP2065 :: Razer Lachesis :: Logitech G15 :: Razer Barracuda AC-1 & HP-1
For a gaming ACE, there is only one space.
Old Age Pensioners :: OAP IRC Channel :: XFire Profile :: Public CS:S Serverno votes
23-03-2007, 17:53 #4Member
- 17/02/06
- Aalst
- 710
23-03-2007, 18:19 #5
ge kunt niemeer met bots spelen
en het probleem is..
who needs bots?#xlnt - Bottelare Westsideno votes
