    Den_John's Avatar
    Temse
    38 (100%)
    3.03 Open Edition - Revision C
    download: http://forums.maxconsole.net/showthread.php?t=46034
    Changes in OE-C:
    - AVC videos bitrate limit patched. The firmware limited the bitrate of avc videos to only 768 Kbps.
    OE now forces the limit to be 16384 Kbps. (Note: this doesn't mean than the psp can handle such a high bitrate;
    this means than they won't show error. I don't know which is the real maximum bitrate than the psp can handle at
    full speed).
    - Speed of OE boot is now ~3 seconds faster than previous versions. (without plugins).
    - Cpu speed of XMB can now be changed.
    - Wifi can now work at 333 Mhz.
    - Added access to flashes 0 and 1 via usb in the recovery menu, based on the great idea of USBSSS by Booster.
    Note that writing is enabled, so this is intended only for advanced users that know what they are doing in each moment.
    (It is not a great idea to change anything from the kd folder).
    Because of this addition, the rest of flashing options were removed.
    - PSP isos can now be deleted as any normal memstick games. (also the size of the iso now shows fine when you press triangle->information).
    - When formatting memory stick, GAME150, GAME303 and ISO directories will be automatically created.
    - Changes in internal HEN core:
    * If a EBOOT.PBP with a plain DATA.PSP had a data.psar, modulemgr took as size of the executable the size
    of data.psp+data.psar. Fixed. (this fix enables psx games to have plain data.psp without causing a memory error).
    * Added a couple of patches found by Tyranid. One allows syscalls instructions to be used in kernel mode
    without causing a crash. The other allows sceKernelQueryModuleInfo to work with sceInit and previous modules.
    aub heren/dames
    Tah_b00nz0r's Avatar
    limburg
    ge moet u psp wel terug helemaal flashe nat schijnt dus dxar file make en upgraden
    psn :: zjerre
    USA Roadtrips blog :: click here
    Den_John's Avatar
    Temse
    38 (100%)
    huhu maar moeilijk is dit niet hoor; je kan natuurlijk ook wachten tot er iemand een easy installer uitbrengt
    GaaRa-'s Avatar
    Sint-Niklaas
    71 (100%)
    ik kan niet veel van de verbeteringen bevestingen omdat ik ze niet gebruik maar mijn psp boot degelijk wel sneller dan dervoor
    Say goodbye,
    As we dance with the devil tonight
    BB~
    BrollyTL's Avatar
    Kapellen
    Quote Originally Posted by Den_John View Post
    al gebeurd 10 minuten na nieuws was die er al ofzo
    net gebruikt, nu 3.03 oe-c
    ReQ^ :: DeFiance :: Dio :: My Musheen :: Dommel ::
    polleke's Avatar
    Ternat city ...
    Quote Originally Posted by BrollyTL View Post
    link: http://www.pspwereld.be/modules.php?...ewtopic&t=2488
    hmm zit niet direct iets bij waarvoor ik wil upgraden, voor filmen te zien gebruik ik mijn gp2x welke avi files (xvid / divx) zonder enige moeite aankan zij het wel in een 320x240 resolutie (max van het scherm).
    protnie's Avatar
    Zwevegem
    Kem ook de easy installer gebruikt vanop psp-media.nl en zit nu ook op 3.03 OE-C maar men boot is nu terug de originele Alles staat nog in de juiste mappen enzo want heb daar niets aan veranderd
    Den_John's Avatar
    Temse
    38 (100%)
    Quote Originally Posted by protnie View Post
    gewoon even terug diene cintro file (config of wat er ook naar flash0 geschreven wordt) in het flash zetten en da zou normaal terug moeten werken aangezien diene 3.03oe-c format doet met flash0 voor hij die gaat wegschrijven
    protnie's Avatar
    Zwevegem
    Ik deed het zonder in flash te schrijven
    Latinos's Avatar
    Bonheiden/Leuven
    Ik heb zojuist ook geüpdate.
    Toch wel ne zalige gast ze, diene dark_alex
    <lat!nos>
    Den_John's Avatar
    Temse
    38 (100%)
    ge gaat toch altijd wel iets in het flash (0 of 1, maakt ni uit) moeten schrijven zoda hij diene boot vanop mem stick leest wnt hoe kan die psp anders weten dat hij andere boot moet gebruiken?
    polleke's Avatar
    Ternat city ...
    Quote Originally Posted by joyrider View Post
    ik vind het veel sneller opstarten toch een goeie reden om up te graden.
    en ja, een nieuwe versie is altijd wel 'beter' dan een oudere versie. 'hopelijk' minder bugs, etc ...
    GaaRa-'s Avatar
    Sint-Niklaas
    71 (100%)
    idd, het is zoals polleke zegt, niet zozeer omwille van kleine bugs eruit al dan niet maar het komt maar al te vaak voor dat mensen zich afvragen ofdat het bv. mogelijk is om ineens van oe-A naar oe-C te gaan zonder B. Indien je elke update doet, moet je daar niet zozeer mee inzitten. =)
    Say goodbye,
    BB~
    BrollyTL's Avatar
    Kapellen
    de max van het scherm is 480*272
    en nu kan je (al even sinds revisie b) deze resolutie vanuit xmb afspelen
    daarvoor konde da alleen via pmpfiles en de bijhorende speler
