Thread: [deleted]
    [deleted]
    Guest
    [deleted]
    [deleted]
    nigel555's Avatar
    Zulte
    heb je de officile patch al geinstaleerd.
    Dat kan helpen.
    my litle place I call home!
    [deleted]
    Guest
    [deleted]
    [deleted]
    Utred's Avatar
    Sluit alle andere programma's.(msn en dieje zever) dat helpt ook al
    Weer een non-antwoord, of beter gezegd een utred-antwoord.
    Silverhawk's Avatar
    Westerlo
    47 (96%)
    Ik heb hetzelfde voorgehad. Verwijder Oblivion en herinstalleer het, dat helpte voor mij. Zorg dan ook dat je update naar de laatste versie
    Woutrageous's Avatar
    Bilzen
    Netwerkkabelke uittrekken helpt ook vaak, alsook SOUNDMAN.exe afsluiten
    En dit komt uit de README file:
    -Frequent Crashing possibly due to old system file
    Some users may experience frequent crashing due to an older system file. These crashes may be attributed to the 'mpeg2dmx.ax' file. Simply renaming the file to "mpeg2dmx.ax.old" may correct this issue.
    -Frequent Crashing possibly due to connected HP printer
    A program related to HP printers may cause Oblivion to crash. Before running Oblivion: Press Ctr-Alt-Del to bring up the task manager. Go to the Processes Tab. Right click on any process starting with the letters HP and select End. Running Oblivion at this point may have this issue corrected. Note: The PC will need to be restarted to reinitialize printing or imaging.
    -"FF" icons in the system tray
    Some users have reported having numerous "FF" icons in their taskbar during or after playing Oblivion. These icons are from a seperate video/audio decoder you may have installed in the past called "FFDShow." This program is processing the sound files for Oblivion, which some users have reported slows down the game, and can leave the icons in their system tray. Simply moving the mouse over those icons will get rid of them after you stop playing Oblivion. Uninstalling FFDShow can fix this, but it is NOT necessary. You can follow the steps below to tell FFDShow not to handle sound for Oblivion.
    Instructions for disabling the FFDShow for Oblivion without fully removing it:
    1. Click Start
    2. Click "All Programs" (or just Programs, depending on the version of Windows, whether they're using "classic," etc.)
    3. Go to the ffdshow folder.
    4. Click "Audio decoder configuration."
    5. In the left hand pane, click "Info & debug." This is the second entry in the list.
    6. In the right hand pane, near the bottom, find a check box labelled "Don't use ffdshow in:"
    7. Check that box, and in the text box underneath (it lights up when you check the check box), add "oblivion.exe" (don't include the quotes). If there is already something in that box, put a semi-colon ( ; ) after what's already there, and oblivion.exe after that. Do NOT use spaces, since ffdshow will think that's part of the filename. A valid entry would be "explorer.exe;oblivion.exe" (without quotes).
    8. Finally, click "Ok" and start Oblivion.
    What the deuce?
    el_sheep666's Avatar
    Sint-Niklaas
    zorgen dat je zeker minder dan 350 Mb werk geheugen hebt in XP, helpte bij mij al veel
    [deleted]
    Guest
    [deleted]
    [deleted]
    Silverhawk's Avatar
    Westerlo
    47 (96%)
    Het is dan ook een weinig voorkomend probleem. In zo'n gevallen heb je meestal pech dat er niet direct een complete fix voor bestaat. Probeer bovenstaande opties eens, als het werkt werkt het.
    Bilzen
    Tja, Oblivion is een crashgevoelig spel. Een afdoende oplossing bestaat r nie en gaat r ook nie komen denkk. Ik heb er mij al bij neergelegd, ma gelukkig duurt t heropstarten nie lang Gewoon vaak genoeg saven.
    What the deuce?
    ZeroTolerance's Avatar
    Temse
    30 (94%)
    oblivion is zeer gevoelig aan alles imo , het is spijtig genoeg ook wa geluk hebben.Sommige mensen crashen nooit , andere crashen constant.
    Silence the disCORD!
    [deleted]
    Guest
    [deleted]
    [deleted]
