    Fanatix's Avatar
    74 (99%)
    CS:S > Hoe krijg ik mijn fps hoger?
    Ik heb 2,4 ghz pentium 4, 1024 ddram en 9700 radeon ik haal toch niet meer dan 30fps. Wat kan ik hieraan doen? Kan ik nen patch downloaden da mijn fps hoger krijgt ofzo, graphics mogen van mij gerust wa minder zijn alst maar vlotter draait.
    Bartleby Gaines: Remember that time we had to steal my mom's birth control pills?
    Sherman Schrader: Yeah, and then Lizzie was born.
    Bartleby Gaines: It's worse than that.
    Japser's Avatar
    melle
    13 Post(s)
    Code:
        * Huge fps winst:
          Verlagen van je Direct X. Hoe lager je Direct X zet, hoe minder visuele effect je nog zal zien in het spel
    // Launch options: -console -heapsize 524288 -dxlevel 81 -nojoy -noipx -w 1280 -h 1024 -noforcemparms -noforcemaccel -noforcemspd refresh -75
    // If the configs doesn't work for you, change the DXlevel!!
    // Last update: 6/27/2006
    // Boxed shadows are now fixed.
    // Couple of new mat commands and the "black box" bug has been fixed.
    // Specs:
    // AMD 2800+ 2,3mhz
    // Nvidia geforce 6800LE
    // 1024mb (333DDR)
    // Stress test FPS 200,40
    //net settings
    cl_allowdownload 0
    cl_allowupload 0
    cl_cmdbackup 2
    cl_cmdrate 101
    cl_downloadfilter "nosounds"
    cl_interp 0.01
    cl_interp_all 0
    cl_interpolate 1
    cl_lagcomp_errorcheck 1
    cl_lagcompensation 1
    cl_resend 1.5
    cl_smooth 1
    cl_timeout 25
    cl_updaterate 101
    rate 25000
    //graphics settings
    cl_drawmonitors 0
    cl_ejectbrass 0
    cl_forcepreload 1
    cl_phys_props_enable 0
    cl_phys_props_max 0
    cl_ragdoll_collide 0
    cl_ragdoll_physics_enable 0
    cl_show_splashes 0
    cl_wpn_sway_scale 0
    fog_enable 0
    fog_enable_water_fog 1
    fog_enableskybox 0
    fps_max 101
    func_break_max_pieces 0
    gl_clear 0
    mat_antialias 0
    mat_bloomscale 0
    mat_bumpmap 0
    mat_clipz 1
    mat_compressedtextures 1
    mat_diffuse 1
    mat_disable_bloom 1
    mat_fastnobump 1
    mat_fastspecular 1
    mat_filterlightmaps 1
    mat_filtertextures 1
    mat_forceaniso 0
    mat_forcehardwaresync 0
    mat_hdr_enabled 0
    mat_mipmaptextures 0
    mat_monitorgamma 1.6
    mat_parallaxmap 0
    mat_picmip 2
    mat_reducefillrate 1
    mat_softwarelighting 0
    mat_softwareskin 0
    mat_specular 0
    mat_trilinear 0
    mat_vsync 0
    mat_wateroverlaysize 16
    mp_decals 50
    muzzleflash_light 0
    props_break_max_pieces 0
    props_break_max_pieces_perframe 0
    r_3dsky 0
    r_avglight 0
    r_avglightmap 0
    r_cheapwaterend 1
    r_cheapwaterstart 1
    r_decal_cullsize 0
    r_decals 50
    r_dopixelvisibility 0
    r_drawbatchdecals 0
    r_drawdetailprops 0
    r_drawflecks 0
    r_drawmodeldecals 1
    r_dynamic 0
    r_eyes 0
    r_flex 0
    r_lightaverage 0
    r_lightinterp 0
    r_lod -8
    r_modellodscale 0.1
    r_occlusion 0
    r_propsmaxdist 5000
    r_radiosity 4
    r_rainalpha 0
    r_rainalphapow 0
    r_raindensity 0
    r_rainlength 0
    r_rainprofile 0
    r_rainradius 0
    r_rainsidevel 0
    r_rainsimulate 0
    r_rainspeed 0
    r_rainsplashpercentage 0
    r_rainwidth 0
    r_renderoverlayfragment 0
    r_rootlod 3
    r_ropetranslucent 0
    r_shadowmaxrendered 20
    r_shadowrendertotexture 1
    r_shadows 1
    r_teeth 0
    r_waterdrawreflection 0
    r_waterforceexpensive 0
    r_worldlightmin 0
    r_worldlights 0
    rope_averagelight 0
    rope_collide 0
    rope_shake 0
    rope_smooth 0
    rope_smooth_enlarge 0
    rope_smooth_maxalpha 0
    rope_smooth_maxalphawidth 0
    rope_smooth_minalpha 0
    rope_smooth_minwidth 0
    rope_subdiv 0
    rope_wind_dist 0.01
    //sound settings
    snd_flushasync
    soundscape_flush
    //cpu settings
    r_3dnow 1
    r_mmx 1
    r_sse 1
    r_sse2 1
    //misc settings
    budget_show_history 0
    con_enable 1
    showhitlocation 1
    texture_budget_background_alpha 9999999
    texture_budget_panel_height 0
    texture_budget_panel_width 0
    overview_health "1"
    //Duckjump
    alias +cjump "+jump; +duck"
    alias -cjump "-jump; -duck"
    bind "space" "+cjump"
    Fanatix's Avatar
    74 (99%)
    En waar moet ik dat precies ingeven?
    JezuS^'s Avatar
    nee maar het kan wel zijn dat je nog instellingen moet veranderen, die commends moet je ingeven Deze Computer > Prog files > Steam/Valve > Steamapps > CS:S > u account en dan gwn daar zieje cfg. en dan maakte da dor in in zo een mapke
    ~ Pentium 4 3.00 Ghz ~ Nvidia 7600 GT ~ Kingston 1024 MB ~ Creative Audigy 4 Pro ~ Sennheiser PC160
    De REDBOX-account van ruikie werd verwijderd.
    Fanatix's Avatar
    74 (99%)
    Als ik dat daar ingeef start mijn cs zelfs niet
    sneax's Avatar
    Met alles op LOW en andere settings afgezet (behalve filtering op 'trilineair') hebt ge nog steeds maar 30fps? Vsync ook afleggen. Ik bedoel in Video settings eh.
    Resolutie 800*600?
    safir Thom4s
    DX2's Avatar
    Kruibeke
    Ge moet nen autoexec.cfg maken met kladblok (achteraf extensie veranderen in .cfg uiteraard) en dan die code bovenaan erin plakken/typen. Da bestand plak je in uw 'cfg' -map.
    Dan typte in console: exec autoexec.cfg
    En dan misschien CSS herstarten.
    Speel best ook op de aan te raden instellingen.
    Lees ook de FAQ eens. Staat veel zinnigs in.
    ^MystiQ's Avatar
    18 (100%)
    Ik geef u ene tip threadstarter, laat die zogezegde fps verhogende configs achterwege. Khad in plaats van een fps winst, een fps verlies.
    En plots crashte men css en dan hebbek weer default config gedaan en alles was opgelost
    PineMangoes's Avatar
    Bredene
    Kzou die config niet gebruiken, je systeem zou meer dan voldoende moeten zijn om in dx9 mode te draaien. Met die config ziet 't spel er slechter dan 1.6 uit.
    Ik draaide dat met m'n 9800pro op 1024x768 makkelijk met alles open (2x AA), dus moet 't met jouw 9700pro in principe niet veel slechter gaan.
    Denk dat de schuldige hier vooral je cpu is, counterstrike: source vréét cpu power. Probeer 'm te overclocken naar 2,8 ofzo en je gaat direct 40-50 halen.
    C0re's Avatar
    Sleidinge(Gent)
    Quote Originally Posted by PineMangoes View Post
    css heeft zware updates achter de rug
    ^MystiQ's Avatar
    18 (100%)
    De boosdoener is je grafische kaart, zonder enige twijfel, ik heb eens nieuwe drivers geinstaleerd ( want khad ook maar 30 fps ) en nu haal ik met gemak 60-70 en op sommige maps 90 enzo
    sneax's Avatar
    Quote Originally Posted by C0re View Post
    mijn computer met R9800pro heeft nog altijd evenveel fps als int begin, gemiddeld 80 vaak 100+ en als minimum 50
    volgens mij is het eerder omdat de mensen hun computers voller en voller met spyware geraken, de vele driver updates, geknoei (wordt soms ook wel 'tweaken' genoemd), oude drivers van alle hardware behalve 3d kaart, niet geupdate windows, virussen, 'opstartitems' veel te groot, antivirus laten opliggen etc... ik kan maar verder gaan, de problemen stapelen zich op, de fps daalt maar het ligt natuurlijk aan de valve updates de nieuwe mappens als militia en inferno zijn zwaarder ja maar buiten dat en het ietspiepietsie meer ram van de verschillende player models is er ni veel verandert
    safir Thom4s
    haatsmurf's Avatar
    Sint-Niklaas
    Quote Originally Posted by sneax View Post
    Er is al genoeg onderzoek naar gedaan, en source is zwaarder als in het begin. Mensen smijten source er af, updaten niet (spelen dus zoals bij oorspronkelijke versie) en doen een stresstest. Laten dan updates binnenkomen en spelen met huidige versie en halen beduidend minder fps in stresstest.
    sneax's Avatar
    Quote Originally Posted by haatsmurf View Post
    sorry maar stresstest geeft een volledig verkeerd beeld
    de stresstest belast de cpu helemaal niet, enkel de gpu (zie: vuur, shader'blokken', camera's etc... - geen physics geen ingewikkelde architectuur)
    ik heb op mijn P4 2.6gighz met R9800pro 1gig ram in de stresstest 99fps
    met mijn core2duo E6600 2gig RAM en x1600 gpu (= +/- r9800pro) heb ik ook in de stresstest 100fps
    niet echt betrouwbaar, ingame wordt de cpu vooral belast, de stresstest heeft met in-game niet veel te maken
    safir Thom4s
    Japser's Avatar
    melle
    13 Post(s)
    Quote Originally Posted by Math'ke View Post
    juist getest
    30 a 40 fps meer me da scriptje , ziet er wel minder goe uit idd
    voor te pubben zouk het zonder scriptje doen , als ge echt wilt warren dan zouk me scriptjes werken
