Thread: Auctioneer mod
    cope's Avatar
    Auctioneer mod
    ik scan alles op AH,op wat moet ik dan clicken om het te kunnen bekijken ?
    moet ik dan ni normaal gezien een lijst krijgen van wat een goede koop zou kunnen zijn ?
    Vulcy's Avatar
    is Auctioneer dan al geupdate voor 2.0?
    cope's Avatar
    jah,kheb er 1 gevonden dat perfect lijkt te werken ?
    ook enig advies hoe geld te verdienen voor epic mount zonder professions ?
    waar/wat grinden
    auctioneeraddon.com
    enkel den beta is beschikbaar, nog niet de officiele release
    en cope : http://norganna.org/wiki/Auctioneer
    An "auctioneer run" always starts with a scan of the AH. After the scan has finished, you should search the auctions for bargains under the proper auctioneer tab on the bottom side of your auction window. At first we will always search the bid section. Auctioneer will list potentially profitable auctions that are about to end. As said above, at the beginning stick to herbs, or other stuff you know that has low or zero deposit. For each auction, auctioneer will give you the stats in the tooltip window.
    "Buyout median", and especially "Suggested price" are the values you should compare to the bid you will have to give. If the profit seems reasonable (deducting deposit and an estimate of, say, about 10% AH-tax) and you can afford the bid, then bid. You can do this in principle for as many auctions as you have money for the bids, but in practice it is a good idea to only pick the most profitable, and NEVER go all-in. This means, never spend all your money at once. Always keep some money safe. This is for several reasons - first, you may encounter a better offer in a later run and want to bite your ass that you have no money left. Secondly, it is never a good idea to risk all your money.
    kdenk da ier insta wa ge zoekt..
    Spacewide's Avatar
    Turnhout
    37 (97%)
    Ik veronderstel dat je het doel van Auctioneer compleet mis hebt.
    Om duidelijke marktprijzen te hebben van items die je bezit of whatever, moet je enkele scans uitvoeren. Zo word er een algemeen image naar je computer gekopieerd van de huidige markt op jou server.
    Je krijgt een gemiddelde Bid en Buyout te zien per item of stack.
    Als je een item wil kopen, bijvoorbeeld "Nexus Crystal", dan zoek je natuurlijk via Search en je krijgt bijvoorbeeld het volgende:
    1Nexus Crystal - 8bid / 11bo
    1Nexus Crystal - 8.45bid / 11.75bo
    3Nexus Crystal - 27bid / 30bo
    Als je met je muis over Nexus Crystal gaat, zie je toch bv.:
    Seen 187 times
    100%bo 13.55
    9.88bid / 12.48bo
    De Nexus Crystal die nu in AH zitten, zijn dus goedkoper dan de gemiddelde marktprijs?
    Als je op de tab Post Auction klikt en je plaatst een Nexus Crystal erin. Dan zie je alle huidige Crystals met hun prijzen, zo kan je makkelijk een item posten, net onder de huidige prijzen.
    Goud verdienen is toch super eenvoudig?
    Er zijn tal van plaatsten waar droprate hoog, waar monsters lage hitrate hebben.
    Azshara is een van de best gekende plekken.
    - Als ik een newbie een rare zie verkopen, tracht ik hem zover te krijgen dat hij het verkoopt voor weinig geld.
    Je doet hier niets mis mee hé!
    - Doorzoek Auction house naar items onder de huidige marktprijzen.
    Goedkoop opkopen en duur verkopen is de boodschap.
    Waag je kans op www.wow-pro.com
    Asrock Z87 Extreme4, Corsair ax860W psu, Intel i5-3570K, GTX970, 2*4GB Corsair Vengeance PC3-12800, SSD500GB EVO 850 + 2TB HDD,
    NZXT N450 -- Dell Ultrasharp U2412M
    cope's Avatar
    welke plek is goed voor een 56 lock ? ashzara is toch -50 plek ?
    blackman's Avatar
    aartselaar
    hmm, felwood,winterspring,en da één van ahn-qiraj zouden denk ik wel al mogelijk zijn op uw lvl.
    INSERTYN
    cope's Avatar
    ik grind die ghosts in winterspring,wnnr ik klaarb en zal ik wel lvl 57 zijn.
    is silithus dan plek om tot 60 te grinden ? en dan aan 800g geraken terwijl ik grind ?
    Cervantes's Avatar
    Kontich
    31 (97%)
    Post is dien beta-auctioneermod aub! :-)
     2SCHAEFERSON ¤ WWW.2SCHAEFERSON.BE ¤ PORTFOLIO & ART 
     COUNTERSTRIKE ¤ VICTORY-GAMING.COM ¤ SCHROETKOMMANDO 
     WORLDOFWARCRAFT ¤ LVL 90 TAURENWARRIOR ¤ LVL 90 UNDEADPRIEST 
    apex^'s Avatar
    Horebeke
    22 (100%)
    scroll naar boven -_-
    Cervantes's Avatar
    Kontich
    31 (97%)
    kzie gene link naar de DOWNLOAD van auctioneer?
    blackman's Avatar
    aartselaar
    Quote Originally Posted by Cervantes View Post
    http://auctioneeraddon.com/dl/AuctioneerOnly/
    daar vanonder =)
    INSERTYN
    original's Avatar
    Quote Originally Posted by cope View Post
    ashzara is goed voor gold yeh, silithius ook en ook handig om te levelen
    EPL is ook nice om te levelen .. ook leuke missions, net zoals winterspring
    ook nice en rustig is deathwind pass .. ogres (zuidoostelijk, SE)
    en hoe ik mijn lock gepowerleveld heb (ze droppen wel rommel dus je gaat er geen fortuinen aan verdienen): ga vanaf 56-57 naar de burning steppes .. daar staan bvb voor de ingang van blackrock mountain een troepje elite dragonkin .. pull zo 1 draakje en zie dat je je felhunter uit hebt .. tegen dat ie gepulled is moet je er minstens 3 dots op hebben staan en wanneer ie te dicht komt gewandelt fear je em .. zo blijf je em fearkiten en dotten (af en toe een shadowboltje of iets dergelijks ertussen) tot die domme draak dood is
    je gebruikt je felhunter omdat sommige van die draken een antibuff op je gooien die je heel kwetsbaar maakt voor hun damage, die dispell je gewoon met je felhunter indien nodig
    vanaf je het wat gewoon bent vliegen die gewoon neer en dat telt toch aardig op tegen 1000xp rested of 500xp unrested per beestje
    iets verderop zijn er ook van die draakjes en daar is het wat rustiger, aan de ingang van BRM is nogal veel verloop van vijandige facties
    ik vond dit super want de meeste mensen die je willen backstabben tijdens het levelen zijn toch rogues en die fear je gewoon rustig de lava in .. gene zwans .. misschien 10 keer gebeurt ofzo lol
    langs de andere kant ben ik ook veel geholpen door vijanden ... ze laten je initeel damage doen en dan beginnen zij bvb te rooten als het druids zijn of te taunten als het ne warrior was ... dan is het easy en leg je het beest in 1,2,3 neer .. jij krijgt de XP en de loot en het vijandige char mag het beestje skinnen a win-win situation !
    ik kan eerlijk zeggen dat ik mijn laatste 3 levels gepowerleveld ben door vijandige allies
    een ander truukje om EN zwaar te levelen EN AD rep te krijgen EN mooie loot te grinden is om in de WPL naar de laatste cauldron te gaan (dat boereveldje met die grote kookpot in het midden), die heeft de hoogste level undeads/ghosts en die droppen heel mooi (en respawnen als zot), silver/runecloth en de occasionele weapon/armordrops .. ook al enkele keren purple gehad ja
    nu als je die missions aan de overgang tussen trisifal glades en WPL hebt gedaan en je een vitrious focusser hebt gekregen dan gaat er regelmatig een item droppen dat als je er 4 van inlevert samen met een runecloth en nog iets (dat je koopt bij de npc in trisifal glades) dan krijg je per keer je dat doet 50 ADrep en 600xp bij .. (je levert ze in door op die grote kookpot in het veldje te klikken en is eindeloos repeatable
    ik ken geen andere plaats in wow die en xp geeft voor de mobs die je slayed en nog eens continues extra XP en AD rep geeft ...
    voor de 60's onder ons iets wat je kan proberen (ik heb dit wel nog ni getest he, ik dacht er gewoon terloops aan): wil je als eerste level 61 zijn in TBC ??? grind dan honderden van die questitems (voor ADrep) en steek ze allemaal weg ... de dag dat tbc er is lever je ze gewoon allemaal tegelijk binnen: bam level 61 op 10 minuten (aan 600xp per 4 ingeleverde items)
    cheers
