Thread: [BF2SF] Fout bij installeren.
11-12-2006, 21:02 #1Member
- Erpe-Mere
- 10,644
- 306 (100%)
- 0/16
http://www.madgamer.be/fout.JPG
Dit is dus de fout.
wat is hier de oplossing van ?
BF2 full patched installed.
Patch dus herinstalleren.
sorry.Last edited by Gamer; 11-12-2006 at 21:12. Reason: found solution.
11-12-2006, 21:24 #2
Problem - Mods/bf2/shaders/lightning.fx not found
Cause - Possible bad install/patch
Fix - First Try applying the latest full patch from http://www.ea.com/official/battlefie.../downloads.jsp
If that doesn't work, Move your BF2 folder from my documents and put it on your desktop and repatch. If that still fails, goto;
C:\Program Files\EA GAMES\Battlefield 2\mods\bf2
Exact Shaders_client.zip into the
C:\Program Files\EA GAMES\Battlefield 2\mods\bf2\shaders
Folder and see if that helps.no votes
