    Rutger's Avatar
    Turnhout
    CS1.6/CZ > via console
    Weet er iemand toevallig hoe je iemand kan unbannen via console want ik geraak op onze server niet meer geconnect via HLSW... Dan blijft er staan : Bezig met connecten...
    Fraggie's Avatar
    Removing Player From Ban
    If you want to remove a player from the banned list, use the "removeid <uniqueid>" in the console. And be sure to remove it from the server.cfg found in the directory of the mod you use for your serverif you placed it there as well.
    http://server.counter-strike.net/howto.html#kicking
    Bv CS openen:
    rcon_address 192.168.1.1
    rcon_port 27015
    rcon_password pwdke
    rcon removeid ..
    PiXeL's Avatar
    Hoe krijgt ge list van banned id's?
    Fraggie's Avatar
    Getting List Of Banned Players
    It is a good idea to keep a list of the users that you have banned permanently from your server. The easiest way to do this is to "writeid" at the console before you quit the server to write the banned user "uniqueids" to the banned.cfg for. You can then open up banned.cfg to see who all has been banned. Also, be sure to add "exec banned.cfg" to your server.cfg so that everytime the map changes or the server restarts, it will reban those uniqueid's.
    Zelfde site.
    PiXeL's Avatar
    En als er geen banned.cfg is..
