    SephirothSnake's Avatar
    Sint Truiden
    44 (100%)
    CS:S > mani_admin probs
    Ik heb handmatig Mani_admin plugin geinstaleerd.
    In de console zijn er mani commands bij gekomen.
    Maar wanneer ik op a duw gebeurt er niks.
    In de console komt dan unknow command.
    k heb nogtans bind "a" admin gedaan in console.
    Op mijn vorige server downde en instalde mani automatisch....
    Iemand een idee wat ik mis doe?
    Sint Truiden
    44 (100%)
    En mijne rpgmod lukt ook al ni lol
    Dit krijg ik in console bij de start van de server:
    Using conprintf
    Loading Mani Admin Plugin 2006 V1.2BetaN RC2-12 VSP, www.mani-admin-plugin.com
    2252AF88 SDK PlayerInfoManager002
    0DE9730C SDK VEngineServer021
    0DEF0BE0 SDK GAMEEVENTSMANAGER002
    0D164D20 SDK VFileSystem012
    0E06386C SDK ISERVERPLUGINHELPERS001
    0E0254E4 SDK VEngineServerStringTable001
    0DE91C6C SDK EngineTraceServer003
    0DE940E0 SDK VEngineRandom001
    2251BB38 SDK ServerGameEnts001
    22510774 SDK IEffects001
    0DE975AC SDK IEngineSoundServer003
    2251BB3C SDK ServerGameClients003
    0DE907A0 SDK VEngineCvar002
    2251BB30 SDK ServerGameDLL003 => Upgraded to ServerGameDLL005
    0E068590 SDK VoiceServer001
    0E048C40 SDK SpatialPartition001
    Attempting to load [./cfg/mani_admin_plugin/language/language.cfg]
    Language to be used [english]
    Searching for game type [Counter-Strike: Source]
    Found gametypes for Counter-Strike: Source
    Game Type [Counter-Strike: Source]
    Message name Geiger index 0
    Message name Train index 1
    Message name HudText index 2
    Message name SayText index 3
    Message name SayText2 index 4
    Message name TextMsg index 5
    Message name HudMsg index 6
    Message name ResetHUD index 7
    Message name GameTitle index 8
    Message name ItemPickup index 9
    Message name ShowMenu index 10
    Message name Shake index 11
    Message name Fade index 12
    Message name VGUIMenu index 13
    Message name CloseCaption index 14
    Message name SendAudio index 15
    Message name RawAudio index 16
    Message name VoiceMask index 17
    Message name RequestState index 18
    Message name BarTime index 19
    Message name Damage index 20
    Message name RadioText index 21
    Message name HintText index 22
    Found base 22000000 and length 6557696
    Sigscan info
    A [222EF950]
    B [2229B0A0]
    C [22561D48]
    D [22576A6C]
    E [22148CF0]
    F [222EC580]
    G [222EA5B0]
    H Failed
    Time for read = [0.000279]
    Time for read = [0.000200]
    Steam ID Player Stats memory usage 0.000000MB with 0 records
    Name Player Stats memory usage 0.000000MB with 0 records
    Failed to open ./cfg/mani_admin_plugin/clients.txt
    Failed to load ./cfg/mani_admin_plugin/clients.txt
    maxplayers set to 32
    CSS:RPG Error: Failed to load a game interface
    nieldeckx's Avatar
    Turnhout
    Mani installeren zou ik persoonlijk eerst niet doen. Onze server, en een server van een vriend van mij crashte erdoor. En het was inderdaad een fout, stond op het forum.
    En als ge gewoon "admin" typt in console? Dan zou het menuke ook moete verschijnen.. Anders hebt ge denk ik iets verkeerds gedaan. Gewoon opnieuw probere me hulp.
    U rpg mod:
    Staat dat bestand goed op de server ?
    En nog succes ermee !!
    // Qck //
    Heusden-Zolder
    1 (67%)
    je zal wel paar bestandjes vergeten upteloaden zijn.. En install de 1.1 versie toch! Die beta van 1.2 zit nog vol fouten waardoor je server kan crashe..
    Herr_Trigger's Avatar
    Uzelf toevoegen als admin in clients.txt, anders werkt command/bind 'admin' niet.
    Check mani forum voor uitleg.
    Sint Truiden
    44 (100%)
    Using conprintf
    Sigscan info
    A [222EF950]
    B [2229B0A0]
    C [22561D48]
    D [22576A6C]
    E [22148CF0]
    F [222EC580]
    G [222EA5B0]
    H Failed
    Time for read = [0.000163]
    Time for read = [0.000155]
    Heap: 256.00 Mb
    Parsed 359 text messages
    execing config.cfg
    Clients is nu inorde maar nog steeds hetzelfde prob.
    oNt-'s Avatar
    mechelen
    Is dit de come back van sephiroth of droom ik :o
    //oNt
    Sint Truiden
    44 (100%)
    WTF heb jij het over?
    CK_'s Avatar
    sephiroth was ne vree populaire kerel die vroeger veel op het tn forum rondhing
    .(")_(")
    xytro's Avatar
    Loppem
    Quote Originally Posted by CK_ View Post
    Ik kon die gast best wel nog verdragen
    "Our car didn’t make the hill and it stopped in the middle of it, it was very dark there and we thought that we would die." - aPo!lo
    Sint Truiden
    44 (100%)
    Ahzo. Tja ben ik dus ni.
    Nog steeds het probleem....
    K zal alles nog eens van nul opnieuw doen.
    Sint Truiden
    44 (100%)
    mani werkt ondertissen, was de .vdf vergeten.
    Nu ng de rpgmod
    bleecker's Avatar
    brakel
    bij mij werkt die end of map vote niet en ik heb in mani_server.cfg alles goed gezet en tlukt niet
    en ik zou ook willen weten voor sounds op men server ze staan erop maar ze willen niet downloaden kloten he :Pen automatish downloaden staat ook op 1
    ^MystiQ's Avatar
    18 (100%)
    Bij mani moede toch gewoon op de say knop drukken en dan @menu en dan krijg ik ook mijn menutje hoor, peace of cake toch ?
    bleecker's Avatar
    brakel
    ik krijg ook menutje maar hij heeft mss de oude versie v1_1 ik heb v1_2 beta
