    zdaan's Avatar
    Sint-Truiden
    CS1.6/CZ > kan geen 'new game' servers joinen
    ok, voor er domme opmerkingen komen ; sv_lan 0 is aangezet -,-
    wanneer ik probeer te joinen krijg ik een foutmelding : LAN servers are restricted class C (LAN).
    Mijn config ;
    PHP Code:
    // This file is overwritten whenever you change your user settings in the game.
    // Add custom configurations to the file "userconfig.cfg".
    unbindall
    bind
    "TAB" "+showscores"
    bind "ENTER" "+attack"
    bind "ESCAPE" "cancelselect"
    bind "SPACE" "+jump"
    bind "*" "snapshot"
    bind "," "buyammo1"
    bind "." "buyammo2"
    bind "0" "slot10"
    bind "1" "slot1"
    bind "2" "slot2"
    bind "3" "slot3"
    bind "4" "slot4"
    bind "5" "slot5"
    bind "6" "slot6"
    bind "7" "slot7"
    bind "8" "slot8"
    bind "9" "slot9"
    bind "[" "invprev"
    bind "]" "invnext"
    bind "`" "toggleconsole"
    bind "a" "+moveleft"
    bind "b" "buy"
    bind "c" "radio3"
    bind "d" "+moveright"
    bind "e" "+use"
    bind "g" "drop"
    bind "h" "+commandmenu"
    bind "i" "showbriefing"
    bind "j" "cheer"
    bind "m" "chooseteam"
    bind "n" "nightvision"
    bind "o" "cl_righthand 0"
    bind "p" "cl_righthand 1"
    bind "q" "weapon_flashbang"
    bind "r" "+reload"
    bind "s" "+back"
    bind "t" "messagemode"
    bind "v" "impulse 201"
    bind "w" "+forward"
    bind "x" "weapon_hegrenade"
    bind "y" "messagemode2"
    bind "z" "weapon_c4"
    bind "~" "toggleconsole"
    bind "UPARROW" "+forward"
    bind "DOWNARROW" "+back"
    bind "LEFTARROW" "+left"
    bind "RIGHTARROW" "+right"
    bind "CTRL" "+duck"
    bind "SHIFT" "+speed"
    bind "F7" "startmovie movie 30"
    bind "F8" "/gocheck"
    bind "F9" "amxmodmenu"
    bind "PGDN" "galil"
    bind "KP_HOME" "flash"
    bind "KP_UPARROW" "hegren"
    bind "KP_PGUP" "sgren"
    bind "KP_LEFTARROW" "famas"
    bind "KP_5" "usp"
    bind "KP_RIGHTARROW" "misc_helm"
    bind "KP_END" "deagle"
    bind "KP_DOWNARROW" "mp5"
    bind "KP_PGDN" "m4a1"
    bind "KP_ENTER" "ak47"
    bind "KP_INS" "awp"
    bind "KP_DEL" "defuser"
    bind "KP_MINUS" "buyammo2"
    bind "KP_PLUS" "buyammo1"
    bind "MWHEELDOWN" "go_slot2"
    bind "MWHEELUP" "go_slot1"
    bind "MOUSE1" "+attack"
    bind "MOUSE2" "+attack2"
    bind "MOUSE3" "+jump"
    bind "MOUSE4" "weapon_knife"
    bind "PAUSE" "pause"
    _cl_autowepswitch "0"
    _snd_mixahead "0.1"
    ati_npatch "0"
    ati_subdiv "0"
    bgmvolume "1.000000"
    bottomcolor "6"
    brightness "1"
    cl_allowdownload "1"
    cl_allowupload "1"
    cl_backspeed "400"
    cl_cmdbackup "1"
    cl_cmdrate "101"
    cl_corpsestay "600"
    cl_crosshair_color "50 250 50"
    cl_crosshair_size "auto"
    cl_crosshair_translucent "0"
    cl_dlmax "128"
    cl_download_ingame "1"
    cl_dynamiccrosshair "1"
    cl_forwardspeed "400"
    cl_himodels "0"
    cl_idealpitchscale "0.8"
    cl_lc "1"
    cl_logocolor "#Valve_Green"
    cl_logofile "smiley"
    cl_lw "1"
    cl_minmodels "1"
    cl_radartype "1"
    cl_righthand "1"
    cl_shadows "1"
    cl_timeout "35"
    cl_updaterate "101"
    cl_vsmoothing "0.05"
    cl_weather "1"
    con_color "255 180 30"
    console "0"
    crosshair "1.000000"
    fastsprites "0"
    fps_max "101.000000"
    fps_modem "0"
    gamma "3"
    gl_dither "1"
    gl_flipmatrix "0"
    gl_fog "1"
    gl_monolights "0"
    gl_overbright "0"
    gl_polyoffset "0.1"
    hisound "1"
    hpk_maxsize "0"
    hud_capturemouse "1"
    hud_centerid "1"
    hud_draw "1"
    hud_fastswitch "1"
    hud_saytext_internal "1"
    hud_takesshots "0"
    joystick "0"
    lookspring "0.000000"
    lookstrafe "0.000000"
    m_filter "1"
    m_forward "1"
    m_pitch "0.022"
    m_side "0.8"
    m_yaw "0.022"
    model "gordon"
    MP3FadeTime "2.0"
    MP3Volume "0.8"
    mp_decals "300"
    name "beeeeeeest"
    net_graph "0"
    net_graphpos "1.000000"
    net_scale "5"
    r_bmodelhighfrac "5.0"
    r_detailtextures "0"
    s_a3d "0.0"
    s_automax_distance "30"
    s_automin_distance "2"
    s_bloat "2.0"
    s_distance "60"
    s_doppler "0.0"
    s_eax "0.0"
    s_leafnum "0"
    s_max_distance "1000"
    s_min_distance "5"
    s_numpolys "200"
    s_polykeep "1000000000"
    s_polysize "10000000"
    s_refdelay "4"
    s_refgain "0.4"
    s_rolloff "1.0"
    s_verbwet "0.25"
    sensitivity "3.020000"
    skin ""
    spec_autodirector_internal "1"
    spec_drawcone_internal "1"
    spec_drawnames_internal "1"
    spec_drawstatus_internal "1"
    spec_mode_internal "2"
    spec_pip "0"
    suitvolume "0.470000"
    sv_aim "1"
    sv_voiceenable "1"
    team ""
    topcolor "30"
    viewsize "120.000000"
    voice_enable "1"
    voice_forcemicrecord "1"
    voice_modenable "1"
    voice_scale "2"
    volume "0.500000"
    setinfo "_vgui_menus" "0"
    setinfo "_ah" "0"
    +mlook
    +jlook
    exec userconfig
    .cfg
    dank bij voorbaad (^,^)
    AoD1's Avatar
    op welke ip range speelde?
    welke class c ip dus...
    fayen's Avatar
    Ternat
    voorbaad??? alé dan -_-
    Fraggie's Avatar
    Na sv_lan op 1 gezet te hebben heb je toch een mapchange gedaan?
    zdaan's Avatar
    Sint-Truiden
    kheb geen idee AoD1 -,-
    en Fraggie : dunno, maar andere mensen kunnen wel joinen dus ligt het daar ni aan (denkek toch ^^)
    en alsk er zelf ene wil opstarten valt cs gewoon uit
    AoD1's Avatar
    meestal staat sv_lan nog op 1
    cs eeft een probleem met een 172.x.x.x ip range.
    Dan gade die error krijgen.
    Als ge bv een 192.x.x.x ip range gaat gebruiken met sv_lan op 1 zou het geen probleem zijn.
    Kheb da probleem gehad op Lanscape.
    Kwas daar admin, en die gebruiken 172 ip range.
    Cs ziet da als "public" ip range & maakt er wa problemen rond
    zdaan's Avatar
    Sint-Truiden
    mja, andere mensen konden wel joinen, dus hoe kan ik het fixen ?
