29-10-2006, 04:05 #1Member
- 21/02/03
- Kessel-Lo
- 3,918
- 1/1
PvP healing, hoe ga ik best te werk?
Mja, 'k heb dit al op de Blizz forums gepost maar tot nog toe niet bijster veel reakties, laat staan nuttige.
als't moet vertaal ik het wel maar ik heb een kop om te barsten en ik neem aan dat wow spelers wel een woordje engels kunnenWhat is in your own experience the best way to heal in pvp?
For myself I know that working with the raid units simply does not work. I either watch my surroundings and the eb and flow of the battle ingame or I watch my raid, but I can't do both.
Besides that, if I do feel I have the time to watch my raid, I often face the problem that I have to make a choice between players who are loosing HP, and it happens countless times that I select someone who happens to be out of range. By the time that I have selected a target that is in range, that target is dead.
Now I've resorted to having the healbars displayed in combat, this I find much easier to heal the people around me, but it somewhat distorts my view. added to wich, these bars can't overlap. So if I want to target someone - and in pvp people move around an awefull lot - and his health bar is about to overlap with someone else's health bar, they suddenly change positions and I once again select the wrong person. It often happens that they shift back and forth constantly because the players are close to eachother and moving around all the time, making it very ineffective to try and heal them.
So now I turn to you for suggestions
PS: thread op Blizz forums
29-10-2006, 06:01 #2no votes
29-10-2006, 10:29 #3Member
- 21/06/03
- Sanctuary
- 3,838
- 30 (100%)
- 2/17
mensen die zwaar geraakt zijn zullen meestel wel naar de achterlijn lopen dus als ge peeps ziet die weglopen van een battle -> bingo
Probeer u ook te verstoppen achter bomen, in struikskes, want als uw tegenstanders zien da er gehealed wordt moogde zeker zijn da gij public enemy number one wordt
Als ge een goe team ebt die ze dan van u kan afhouden -> winXboxLive: Cryotikxno votes
29-10-2006, 11:05 #4Member
- 23/07/03
- anvers
- 2,296
- 67 (99%)
gebruik healmod ?
( ik gebruik persoonlijk smartheal, in combinatie met macro )
29-10-2006, 11:07 #5
Ik persoonlijk werk in pvp met een emergency monitor die enkel mensen in een bep range toont (zet het meestal op max healing range +5yd). (google achter 'eemon addon' als je hem wilt)
Wat ook heel belangrijk is, maar wat je wel nooit tegenkomt in PuG is MT windows. Mijn MT windows (van oRA2) hebben een target of target target functie, zodat ik dus meteen kan zien wie aangevallen wordt door dat target dat eigenlijk dood moet (dus geselecteerd door de MA).
Last but not least, een tooltip addon (ik gebruik tinytip) die toont door hoeveel mensen je tooltip target (dus gewoon er over zweven is genoeg) geselecteerd is kan je ook snel duidelijk maken wie de klappen gaat ontvangen.
Enkel 1 en 3 kan je effectief in PuG's gebruiken though.no votes
29-10-2006, 15:30 #6Member
- 28/10/03
- 57
Yep inrange emergency monitor, ook vijand targetten en target of target is handig.
29-10-2006, 18:54 #7Approved 9-lifer
- 25/05/03
- Herzele
- 2,944
- 1/1
fade is your friend !
29-10-2006, 21:15 #8Member
- 21/02/03
- Kessel-Lo
- 3,918
- 1/1
tiny tip heb ik, en eemon heb ik net gedownload, thx
30-10-2006, 11:09 #9MemberyusPuteanus
- 01/07/02
- Puteanus Towers
- 2,938
- 1/3
en als ge ne priest zijt met Benediction: koop u op 't AH ne Withered Staff ( http://www.thottbot.com/?i=317 ) voor een sjiek en gebruikt die als ge rondloopt, in battle zelf kunde nog wapens veranderen.
zoals ik tegen m'n guildies al zei tijdens een potje PvP: "Nothing screams 'Kill me!' more then Benediction"
Lid van Pynnock Ridders Horstno votes
30-10-2006, 11:29 #10Approved 9-lifer
- 22/07/02
- 580
- 1/1
Ze gaan sowieso op u zitte als ge zit te healen, u staff constant switchen zal niet veel helpen...
Als je een priest bent en je wilt een pvp healer zijn, spec naar Power Infusion, zoekt u ne mage/warlock maatje en heal alleen u maat (en soms een keer iemand anders)no votes
30-10-2006, 11:54 #11MemberyusPuteanus
- 01/07/02
- Puteanus Towers
- 2,938
- 1/3
ja ok zodra 't gevecht begonnen is zijder daar ni veel mee natuurlijk, maar als ge zo tijdens 't rondrijden al wa kunt verbergen dat ge nen uberpriest zoals ik zijt, da helpt mss al wa
respeccen ganek nu wel ni doen, PvE is nog altijd 99% mijn ding
30-10-2006, 12:16 #12Member
- 28/08/02
- Anywhere
- 2,191
- 2/2
ja want u brains en los wa gebruiken is echt wel uber
ik gebruik gewoon CTraid voor te healen in pvp. Zie op voorhand wie er allemaal in u groep mee is zoda ge direct in CTra kunt selecteren.
Wa ge eventueel kunt doen is zorgen da ge een duidelijke overview hebt zoda ge ziet wie er hits krijgt en zo handmatig kunt selecteren. Wa ook helpt is een propere UI voor overviewpewpew signo votes
30-10-2006, 12:25 #13
Tja da's allemaal nogal pug hé. Deftige premades = party sticks together. Dus in premade ab zulde bv. hebben group1 stables, group2 GM, group3 LM (ik speel alliance hé, beste 3-cap voor horde zal farm, bs, LM zijn). Dan zet je healers in elke groep. Die groep blijft samen, en dan heal je gewoon uw party. Der zijn premades die na hun 3-cap gaan voor 5 3-mans (1 op elke site en 2 die roamen). Maar dan moet je gewoon je eigen group in de gaten houden, + de groep die je eventueel komt/gaat helpen (ventrillo report en je weet meteen welke groep naast jouw groep aan het defenden is). Die zullen, once again, allemaal dicht bij elkaar zijn. In WSG werk je meestal met een zerg groep, enkele attackers, en wat defenders. Een goeie premade zal deze in party's onderbrengen. Bv. Group1 (5 leden) zergs, group2 (3 leden) caps, group3 (2) defends. Dan heal je gewoon de groep waar je inzit. Het komt er altijd op neer dat je met een goeie groepindeling en wat basis-tactics je healing meestal kan reduceren tot group healing. En in goeie pvp zullen je teammates er alles aan doen om je in leven te houden met crowd control terwijl ze proberen de andere healers eerst neer te krijgen
Als je veel moet raidhealen en out of range errs krijgt in pvp dan is je premade toch wel fout bezig. Stick together
30-10-2006, 18:31 #14Approved 9-lifer
- 22/07/02
- 580
- 1/1
30-10-2006, 20:02 #15Member
- 4,323
- 27 (100%)
- 13/21
benediction = certain death in bg's..
kzal nooit ofte nimmer met benediction in bg's rondlopen, ook al zijde als priest hoofdtarget in bg's, met benediction rondlope gaat ganse raid sebiet voor u.
voor de rest gewoon spellalert, decursive & dergelijke..
spellalert om te weten wanneer targets heals krijge of shields & dergelijke, meteen dispellen dus. <- vijanden dispelle leert u ne goeie priest worde.. ge ziet maar weinig priests die functie op vijande gebruiken.
en tja decursive, ge moet zelf maar beetje 'feel' hebben in uw huidige situatie om te weten wat dringend dispelled moet worde & wat niet.// Mine i7 6700k @ 4.6Ghz 1.25v - EKWB Cooled // Asus Maximus VIII Formula // 32GB Corsair DDR4 3000 // EVGA 3080 FTW3 Ultra //
2x Samsung EVO 1TB SSD // Corsair AX860i // LG 34GN850 + Acer XB271HU // In Win 909
// Vriendin i7 7700k @ 4.8Ghz 1.28v - Noctua D15S // Asus Maximus VIII Hero // 16GB Corsair DDR4 3000 // MSI 1080 GTX Gaming X //
Samsung Evo 512GB - WD Livebook 4TB // Corsair AX750 // Dell S2716DG 144hz 1440p Gsync // Corsair 750Dno votes
