Page 1 of 3 123 Last
    DagothUhr's Avatar
    Izegem
    [News] Saitek announces Saitek X52 Pro (DROOL)
    Saitek heeft zn paradepaardje geupgrade en het ziet er goed uit.
    http://www.saitekusa.com/usa/prod/x52pro.htm
    All the features of the X52 combined with premium engineering and advanced Multi-Function Display (MFD) for real flying interaction.
    * 2 dedicated MFD buttons and 2 rotary dials with in-built buttons to control additional game functionality
    * MFD displays data directly from games, including Radio Stack info from Microsoft Flight Simulator 9 and 10
    * Software Development Kit included for creating game-specific programs to interact with the MFD
    * Choice of red, amber or green button illumination
    * lluminated buttons and MFD - ideal for low light environments
    * Throttle unit illumination varies depending on throttle position
    * Enhanced MFD backlighting
    * Improved cable management system
    ::: Joystick ::
    * Precision centering mechanism, non-contact technology on X and Y axes and constant spring force reduce free play, improve control and increase durability
    * 2-stage metal trigger; 2 primary buttons in 1 convenient position
    * 4 fire buttons including missile launcher with spring-loaded safety cover for instant access
    * Conveniently positioned metal pinkie switch provides shift functionality to double up on programmable commands
    * 2 X 8-way Hat Switches
    * 3D rudder twist
    * 3-position rotary mode selector switch with LED indicators
    * 3 spring-loaded, base-mounted toggle switches for up to 6 programmable flight commands
    * 5-position handle adjustment system to suit all hand sizes
    ::: Throttle ::
    * Progressive throttle with tension adjustment, detents for afterburner and idle
    * 2 fire buttons
    * Scroll wheel with built-in button
    * Mouse controller / hat switch with left mouse button
    * 8-way hat switch
    * 2 x rotary controls
    * Smooth-action slider control
    * Clutch button initiates ‘safe mode’ to allow on-the-fly profile selection, or to display button functionality without activating
    Benieuwd hoeveel dit hebbedingetje zal kosten ?
    Proud fan of the elders scrolls
    DagothUhr, son of DagothUr
    Choco Party....good good
    BlueSkyraider's Avatar
    Kluisbergen
    29 (100%)
    allé ,kweet al voor wat ik al geld opzij ga zetten
    Mijn wishlist wordt steeds groter
    "Er zit in iedereen wel een Dude87!" - gizmo_1987
    "Ik wil gewoon vuile E30's te kakken zetten" - ComputerVISTA
    FroFro's Avatar
    Delft
    YES ! IK WIST DA IK MOEST WACHTE WANT DA ER IETS NIEUW GING KOME
    Zieter ook professioneler en duurder uit imo
    eindelijk nen handige MFD
    DagothUhr's Avatar
    Izegem
    De X52 Pro gaat ongeveer 199,85 Euro kosten en zal vanaf november beschikbaar zijn in speciaalzaken voor flight simulator producten of direct via Saitek.
    MFD
    En de release zal midden november zijn.
    SilentSpring's Avatar
    Damme
    200 ballen voor ne stickske...
    En zeggen dat ik de 54€ van mijne afterburner 2 al meer dan genoeg vond.
    Soit, voor de echte simmers is da wel de moeite. Maar voor iemand als ik die es ne flightsim speelt alsk tijd en goesting eb is da veel te duur.
    allez, laatste keer dak gevlogen heb is van ne goeien week of 2 geleden dusja. Als da maar is om sporadisch te gebruiken gak geen topmateriaal kopen
    Anorag's Avatar
    ola ! heb nu al dik jaar mijn Saitek X52 ... nog niets aan , alle deadzones zijn nog 0 ... eigenlijk in perfecte staat ... mss verkoop ik de X52 wel voor 50% van de huidige prijs ... dan moet ik iet minder betalen voor nen X52 pro... maar kans dat ik hem koop is wel groot ! ziet er wel geil uit !
    die MFD gebruikte ik nu eigenlijk alleen maar om te zien welke profile ik geload had! en op welke mode ik stond ... voor derest vond ik die nogal nutteloos alhoewel ik ook wel es keek hoe laat het was... maar das eerder pretbedervend als je beseft dat je weer uurtje ouder bent!!!
    dus LANG LEVE SAITEK X52 PRO
    FroFro's Avatar
    Delft
    Mja, 200 euro, X52 is ook 150 maar vind ge voor 90
    Anorag's Avatar
    alhoewel ik nu juist denk... je ziet de frequenties dat je gebruikt , ja en dan je kan ze toch nie veranderen dus eigenlijk is dien MDF weer nie echt zooo handig ! op den duur zullen we gwn die radioshack openen en nie meer kijkn naar da MFD'tje ... maar toch zalk hem kopen ze !
    FroFro's Avatar
    Delft
    wrrm da gij em koopt snap ek ni, ge hebt al nen X52 Das wa decadent e ^^
    Kluisbergen
    29 (100%)
    Anorag heeft duidelijk een luxeprobleem
    Stevow's Avatar
    Wellen
    sweeeet :-)
    ~==>Don't come between the Nazgûl and his prey <==~
    sneax's Avatar
    tof om op te geilen maar echt nodig heb ik het niet, ik ben maar ne sporadische joystick gebruiker
    vind er te weinig goei spellekes voor kzou graag meer games gelijk freelancer hebben me vliegen en knallen en force feedback langst alle kanten en ewa arcady
    safir Thom4s
    Eagle-Eye's Avatar
    Koksijde
    Heb net m'n X52 gekocht, en moet deze dus niet hebben. Zoals Anorag zegt, zie ik het nut ook niet echt dat die radio stack op je MFD staat.
    @ BlueSkyraider: Anorag heeft inderdaad een luxeprobleem, als ge ziet dat hij dikwijls maar met z'n vingers moet knippen en hetgeen hij wil al praktisch voor zijn neus zal staan... *jealous-mode off*
    Leaving area and frequency... | Flight Ops Officer of Belgian Virtual Tigers
    If you don't return with blood and mud on your aircraft, you were flying too damn high.
    passero's Avatar
    Drongen
    ik was net van plan om me een X52 te kopen... mss beetje wachten...
    Ik hoor m'n vriendin al denken...
