Thread: Lego star wars
    hummel's Avatar
    Diepenbeek
    79 (99%)
    Lego star wars
    ik zit dus vast in dit spel(ik schaam me dood )
    episode VI level 2
    je zou daar op het schip 2 "stroomgenerators" kapot moeten schieten met een gun dat vanvoor op het schip staat, maar 1 van die 2 wilt nie kapot gaan ?
    kan iemand me hier mee helpen
    MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports) - 2,3 GHz Intel Core i5 - 256 GB - 8 GB 2133 MHz LPDDR3 - Intel Iris Plus Graphics 655 1536 MB
    H_ans's Avatar
    Muizen
    211 (100%)
    http://db.gamefaqs.com/computer/dosw...r_wars_2_b.txt
    "Smash the railing to the north, then battle 3 waves of gamorreans and guards.
    Head to the blue grate and smash it to get a push box. Push it to the power
    generator and then head past the generators. Battle 2 waves of more stuff,
    then push the other push box into the other side of the power generator. The
    boxes will explode and then the generator will be open. Switch to 3PO and
    activate the panel on the other generator to expose it. Jump on top of the
    generator and jump again to grab the blue piece, then grab all the others in
    this area. Blast the big box on the raised part, then drop down. Run through
    the tunnels and get up to the top. Pull the lever to open the door, blast the
    other door, then push the block to the stairs. Switch to Luke and build the
    stairs on the north side, use the force to make a ramp, then walk up to the
    higher level. Shoot the 3 waves and grab the studs. Destroy all the rails and
    the boxes and the covers on the ladders. Build the grapple pad that came out
    of one box, then switch to a blaster character. Grapple up to get more studs.
    Use the force on the ladders on the sides, then use the force on the ladders
    in the middle. Use the force once more to make a ramp up."
    hummel's Avatar
    Diepenbeek
    79 (99%)
    ik heb het ook al opgezocht op gamefaqs maar het lukt gewoon niet
    die 2e generator wilt niet kapot
    hummel's Avatar
    Diepenbeek
    79 (99%)
    is er nu niemand die da spel aant spelen is ???
    help me eens ffs
    Elfish's Avatar
    Quote Originally Posted by hummel View Post
    help me eens ffs
    use the force
    Bellerophon's Avatar
    Herent
    74 (96%)
    Ik ga er me van 't weekend met de vriendin mee bezig houden. Ik hou je op de hoogte.
    "Never underestimate the bandwidth of a truck full of tapes hurling down the highway"
    Andrew S. Tanenbaum
    There is no place like 127.0.0.1::1
    hummel's Avatar
    Diepenbeek
    79 (99%)
    kweet nu nie of da een grapje is maar the force kan dus niet gebruikt worden in dit stukje waar ik vastzit
    the_god's Avatar
    Oostende
    had dat probleem ook, gewoon de andere eerst kapot schieten (die die niet kapot gaat) en dan pas die 2de
    hummel's Avatar
    Diepenbeek
    79 (99%)
    tis dus de linkse die niet kapot gaat bij mij he ?
    hmm zal eens proberen daar eerst op te schieten dan ja
    Elfish's Avatar
    idd, 't was maar een flauwe grap
    hummel's Avatar
    Diepenbeek
    79 (99%)
    thx voor de gouden tip dat ik eerst die andere generator moet kapot schieten
    is waarschijnlijk een bug een in de game
    btw ik raad deze game aan, aan iedereen, zeer fun
    Dennoman's Avatar
    Heist-o/d-Berg
    107 (98%)
    En daar hebt ge nu... 2 dagen op vastgezeten?
    ~ "You don't see faith healers working in hospitals for the same reason you don't see psychics winning the lottery." ~
    hummel's Avatar
    Diepenbeek
    79 (99%)
    kheb die level 3 keer opnieuw gespeeld ofzo maar schoot altijd eerst die rechtse kapot
    dus ja, nie mijn fout he
