    temse
    CS1.6/CZ > config fout... (traag rechts/links lopen bij et schuin lope)
    yo gamerz
    ik heb al enkele keren mijn config moete verwijdere omdat ik namelijk zeer traag naar rechts/links loop terwijl ik rechtdoor loop.. da's vreselijk irritant..
    weet er iemand aan wa da ligt??
    Fraggie's Avatar
    Post eens je config. Heb je het ook in lan games? Speciaal keyboard?
    temse
    // This file is overwritten whenever you change your user settings in the game.
    // Add custom configurations to the file "userconfig.cfg".
    unbindall
    bind "TAB" "+showscores"
    bind "ENTER" "+attack"
    bind "ESCAPE" "cancelselect"
    bind "SPACE" "+jump"
    bind "'" "+moveup"
    bind "*" "name The%Infused%Gamer%.%Davidof"
    bind "," "buyammo1"
    bind "-" "waypoint menu"
    bind "." "buyammo2"
    bind "/" "+movedown"
    bind "0" "slot10"
    bind "1" "slot1"
    bind "2" "slot2"
    bind "3" "slot3"
    bind "4" "slot4"
    bind "5" "slot5"
    bind "6" "slot6"
    bind "7" "slot7"
    bind "8" "slot8"
    bind "9" "slot9"
    bind ";" "+mlook"
    bind "=" "ivpbotmenu"
    bind "[" "invprev"
    bind "]" "invnext"
    bind "`" "toggleconsole"
    bind "a" "+moveleft"
    bind "b" "buy"
    bind "c" "+rze_duck"
    bind "d" "+moveright"
    bind "e" "+use"
    bind "f" "impulse 100"
    bind "g" "drop"
    bind "h" "+commandmenu"
    bind "j" "amxmodmenu"
    bind "k" "+voicerecord"
    bind "l" "showbriefing"
    bind "m" "chooseteam"
    bind "n" "nightvision"
    bind "o" "buyequip"
    bind "p" "say /checkpoint"
    bind "q" "radio3"
    bind "r" "+reload"
    bind "s" "+back"
    bind "t" "impulse 201"
    bind "u" "messagemode2"
    bind "w" "+forward"
    bind "x" "radio2"
    bind "y" "messagemode"
    bind "z" "radio1"
    bind "~" "toggleconsole"
    bind "UPARROW" "+forward"
    bind "DOWNARROW" "+back"
    bind "LEFTARROW" "+left"
    bind "RIGHTARROW" "+right"
    bind "ALT" "+strafe"
    bind "CTRL" "lastinv"
    bind "SHIFT" "+speed"
    bind "F1" "autobuy"
    bind "F2" "say <<::Msn: David_robbrecht@hotmail.com::>> "
    bind "F3" "say <<::S::>> <<::E::>> <<::L::>> <<::A::>> <<::M::>>"
    bind "F4" "say_team <<::Cover Me !. I'm Planting the BOMB::>>"
    bind "F5" "snapshot"
    bind "F6" "say_team [ak-47/m4a1]-[vesthelm/vest]-[sgren/hegren/flash/flash]"
    bind "F8" "deagle; secammo; use weapon_knife"
    bind "F9" "sgren; hegren; flash; flash; use weapon_knife"
    bind "F10" "vesthelm; vest; use weapon_knife"
    bind "F11" "amx_cmdmenu"
    bind "F12" "say_team RAAK IETS!!!!!"
    bind "INS" "+klook"
    bind "DEL" "name 1+1=2"
    bind "PGDN" "+lookdown"
    bind "PGUP" "+lookup"
    bind "END" "centerview"
    bind "MWHEELDOWN" "invnext"
    bind "MWHEELUP" "invprev"
    bind "MOUSE1" "+attack"
    bind "MOUSE2" "+attack2"
    bind "MOUSE3" "say /gocheck"
    bind "MOUSE4" "rze_helm"
    bind "MOUSE5" "rze_all_gren"
    _cl_autowepswitch "0"
    _snd_mixahead "0.1"
    ati_npatch "0"
    ati_subdiv "0"
    bgmvolume "1.000000"
    bottomcolor "6"
    brightness "1"
    cl_allowdownload "1"
    cl_allowupload "1"
    cl_backspeed "1000"
    cl_cmdbackup "2"
    cl_cmdrate "101"
    cl_corpsestay "0.000000"
    cl_crosshair_color "250 250 50"
    cl_crosshair_size "small"
    cl_crosshair_translucent "1"
    cl_dlmax "128"
    cl_download_ingame "1"
    cl_dynamiccrosshair "0"
    cl_forwardspeed "400"
    cl_himodels "0"
    cl_idealpitchscale "0.8"
    cl_lc "1"
    cl_logocolor "#Valve_Orange"
    cl_logofile "lambda"
    cl_lw "1"
    cl_minmodels "1"
    cl_radartype "1"
    cl_righthand "0"
    cl_shadows "0"
    cl_timeout "35"
    cl_updaterate "101"
    cl_vsmoothing "0.05"
    cl_weather "0"
    con_color "0+0+0"
    console "1"
    crosshair "1.000000"
    fastsprites "0"
    fps_max "100"
    fps_modem "0"
    gamma "3"
    gl_dither "0"
    gl_flipmatrix "0"
    gl_fog "1"
    gl_monolights "0"
    gl_overbright "0"
    gl_polyoffset "0.1"
    hisound "1"
    hpk_maxsize "0"
    hud_capturemouse "1"
    hud_centerid "1"
    hud_draw "1"
    hud_fastswitch "1"
    hud_saytext_internal "1"
    hud_takesshots "0"
    joystick "0"
    lookspring "0.000000"
    lookstrafe "0.000000"
    m_filter "0"
    m_forward "1"
    m_pitch "0.022"
    m_side "0.8"
    m_yaw "0.022"
    model "gordon"
    MP3FadeTime "2.0"
    MP3Volume "0"
    mp_decals "10.000000"
    name "pillamp"
    net_graph "3"
    net_graphpos "2"
    net_scale "5"
    r_bmodelhighfrac "5.0"
    r_detailtextures "0"
    s_a3d "0"
    s_automax_distance "30"
    s_automin_distance "2"
    s_bloat "2.0"
    s_distance "60"
    s_doppler "0.0"
    s_eax "0"
    s_leafnum "0"
    s_max_distance "1000"
    s_min_distance "5"
    s_numpolys "200"
    s_polykeep "1000000000"
    s_polysize "10000000"
    s_refdelay "4"
    s_refgain "0.4"
    s_rolloff "1.0"
    s_verbwet "0.25"
    sensitivity "1.650000"
    skin ""
    spec_autodirector_internal "1"
    spec_drawcone_internal "1"
    spec_drawnames_internal "1"
    spec_drawstatus_internal "1"
    spec_mode_internal "4"
    spec_pip "0"
    suitvolume "0.250000"
    sv_aim "0"
    sv_voiceenable "0"
    team ""
    topcolor "30"
    viewsize "120.000000"
    voice_enable "0"
    voice_forcemicrecord "1"
    voice_modenable "0"
    voice_scale "2"
    volume "0.380000"
    setinfo "_vgui_menus" "1"
    setinfo "_ah" "1"
    setinfo "" "1"
    +mlook
    exec userconfig.cfg
    __________________________________________________ _______
    heb een normaal toetsebord ... nu is het in orde alleen bij het achteruit schuin lopen is het probleem nja test maar( dit is heaton config )
    grtz
    Fraggie's Avatar
    bind "c" "+rze_duck" -> kan je die alias eens posten?
    setinfo "" "1" -> zegt me niet veel
    cl_timeout "35" -> moet dat zo hoog?
    jXLll's Avatar
    heb ik ook wel is gehad.
    wat voor processor heb je?want ik had dat en dat kwam omdat ik een celeron processor heb met 128 kb cash
    Atticus Finch's Avatar
    Oz
    Quote Originally Posted by jXLll
    en daardoor ga je traag zijwaarts lopen in games. Lijkt me nogal vergezocht .. enfin, al een geluk dat het zo ne rijke cpu was eh.
    th43ns's Avatar
    12 (100%)
    cl_forwardspeed 800 ;-)
    Fraggie's Avatar
    Quote Originally Posted by thaens
    Standaard laat de server maar 400 toe, en ik weet niet meer welk sv_ cmd het is dat dit regelt. Ik dacht zelf dat het in één of andere update verwijderd was owv abuse.
    temse
    k thx
    Fraggie's Avatar
    Hoe heb je het nu opgelost als ik vragen mag?
    th43ns's Avatar
    12 (100%)
    sorry voor de late reply, ma ligt toch aan die forwardspeed hoor fraggie.
    Heb da ook keer gehad nadat ik op zo een soccerjam server gespeeld had...
    Groeten
    mudvAyne's Avatar
    Volgens mij moet da aa die forwardspeed liggen ze
    HxC
    candycrash's Avatar
    St.-Niklaas
    cl_forwardspeed/backspeed/sidespeed zorgen voor deze problemen
    het is totaal niet nodig die aan te passen, is enkel handig als je de sv settings kunt veranderen wat dus niet zo is
    als uw sidespeed hoger of geljk is aan uw forward speed zulde merken dat je plots anders gaat bewegen bv latere of snellere strafe snelheid of zelfs een late reactie dat het lijkt alsof je lag hebt
