Thread: Een purging probleem :)
25-08-2006, 21:16 #1
Today I was in BG (X bg ftw... at least for beeing in alot) against a shaman. I learned to know purge very well today. Every time I tried to put up soc he just purged it in a milisec. I wasnt able to keep even 1 up for longer then a sec. He just purged all the time, all my buffs and dmg was gone. I hardley had dmg left and healing was interupted all the time by earthshock. As i waited to heal a bit with my hammer of justice i found myself dead fast as the stunresist helped the orc again... i felt like an idiot beeing powned like this... my devine shield allow me but also him to have some time to heal... My dmg was ZERo as he used 1h with shields. In what kind of way is a paladins spells usefull to himself if a class can just remove it all the time making you swing a 0 dps noobstick? I used more mana trying to put up my soc then doing dmg with it
A shaman gimps a palading complete but i cant find a way to gim a shaman back... oh wait i can cast BOF on a party member against ground binding totem
ow purge right
Any hints? cause right now the only way to kill a good shamaan is to crit him 15 times in a row just by my big axe, if he doesnt heal ofc...
Is this whine? sure it is and i would like to change it in shaman whine
Hopelijk geen prob da het in engels is
INTEL I5 2500K @ 4,6Ghz // GA-Z68X-UD3H-B3 // ASUS Nvidia GTX560Ti // Corsair Vengeance 2 x 4GB @ 1866Mhz // Samsung 830Series 128Gb SSDno votes
25-08-2006, 21:36 #2
lvl1 seals > purge..
heal en optijd cancellen => eartshock vo niks => heal
frostshock => heal want cd op es
en anders moet ge ma gaan lopenLast edited by SecondAccount; 25-08-2006 at 21:44.
25-08-2006, 21:42 #3no votes
25-08-2006, 21:52 #4Approved 9liver
- 23/12/04
- 2,606
- 66 (100%)
- 1/4
25-08-2006, 21:55 #5
well leg het mij dan is uit of staat l2p voor geluk heben met crits en hopen dat den andere u niet raakt en da ge alles resists...
25-08-2006, 22:39 #6Member
- 29/08/04
- 3,110
- 0/28
25-08-2006, 23:35 #7Member
- 27/08/02
- Bogaarden
- 319
- 16 (100%)
gewoon lvl 1 seals gebruiken, shaman zal dan wel sneller oom zijn.
26-08-2006, 00:06 #8Member
- 26/02/05
- Wellen
- 858
- 14 (100%)
- 1/2
btw tomalik wants to kill u ergo ;D
26-08-2006, 00:14 #9Member
- 21/02/03
- Kessel-Lo
- 3,918
- 1/1
nee, l2p is in dit geval doen wat secondaccount zegt
2handerke boven halen
bubble poppen voor wat ongestoord schade uit te delen
stun voor u eige te heale. ok, orc resist da al wa meer ma toch ni altijd en dan komde weer uit bij de shaman om de tuin leiden
trouwens, na ne ES kunde toch terug healen, da interrupt ma da silenced ni eh
26-08-2006, 00:31 #10Member
- 11/03/05
- Brussel
- 5,018
- 80 (98%)
shamans vs paladins zijn idd vervelend..
ikzelf ben dus pala en vandaag had ik weer veel moeite om een shaman neer te halen. zat wel bezig met 1H waardoor hij altijd op het nippertje kon healen.. uiteindelijk gewoon voor z'n heal stun en het is opgelost
26-08-2006, 00:32 #11
Gank je ook badlands windrider met je pally? Jo.
26-08-2006, 03:01 #12
De pally melkt dattie geen dps kan doen... *grin*
26-08-2006, 03:18 #13Approved 9liver
- 19/07/02
- murp
- 12,819
- 2 Post(s)
- 0/317
paladins > shamans any day :|
When in trouble, fear or doubt, run in circles, scream and shoutno votes
26-08-2006, 04:03 #14Approved 9liver
- 09/11/03
- Genk
- 2,595
- 34 (100%)
- 3/45
Earth Shock
Instantly shocks the target with concussive force, causing 517 to 545 Nature damage. It also interrupts spellcasting and prevents any spell in that school from being cast for 2 sec.
Tenzij de pala my helemaal outgeared (t2+),oh, en alsk oom ben, verlies ik zelden met een shield.no votes
26-08-2006, 14:11 #15Approved 9liver
- 28/12/05
- Stabroek
- 845
- 0/3
qft
En 2sec silence is echt niets, vergleken met mage counterspell (dat doet paladins pas de das om
). En daarbij, als er een seal active is, dan mag je zoveel eartshocken als je wil, die seal wordt niet gesilenced.
De enigste paladins die echt 'deadmeat' zijn voor shamans, zijn die paladins met 2k-3k mana pool, die nie weten wa judgement of wisdom is.-_-Thrasheffect !no votes
