    confessions's Avatar
    [CoD2] PB OS priveleges
    Als ik cod2 server join (met pb aan dan) krijg ik steeds volgende PunkBuster foutmelding.
    RESTRICTION:
    inaderquate O/S privileges
    Het gaat om een gekochte versie van et spel en als ik kijk naar de verwijzing naar het Operating System zie ik het prob niet want k'heb Win XP en ik ben zelf admin dus er is geen sprake van beperkte rechten ofzo.
    Alvast bedankt
    >.< ^^ +_+ ยด_` :')
    massief's Avatar
    Gent/Oosterzele
    -1 (0%)
    gebruik search es, da kan ook veroorzaakt worre door spyware etc
    MajorWintersEC's Avatar
    Tongeren
    Zorg dat je ingelogd bent als admin.
    Als dit het geval is:
    Resolution: User not using a windows Admin account or spyware\malware has changed the policy. Use Look2MeDestroyer & vx2finder(126) to remove malware and restore the policy
    XP Home Users
    Instructions:
    Download and Run Look2MeDestroyer
    Close all windows before continuing.
    Double-click Look2Me-Destroyer.exe to run it.
    Put a check next to Run this program as a task.
    You will receive a message saying Look2Me-Destroyer will close and re-open in approximately 1 minute. Click OK
    When Look2Me-Destroyer re-opens, click the Scan for L2M button, your desktop icons will disappear, this is normal.
    Once it's done scanning, click the Remove L2M button.
    You will receive a Done Scanning message, click OK.
    When completed, you will receive this message: Done removing infected files! Look2Me-Destroyer will now shutdown your computer, click OK.
    Your computer will then shutdown.
    Turn your computer back on.
    Download and run this: vx2finder msg126
    Click the "Find VX2.betterinternet info" Button
    If there are NO files listed in the bottom box, go on to the last step. (Choose Restore Policy)
    If the VX2finder finds the adware files, (it is usually 3 random named dll files)
    Select by checking box in front of file or files.
    Press 'Delete These Files'.
    The program will delete all files but one that will be deleted on reboot. Allow pc to reboot, or manually reboot.
    Run VX2finder again
    Press 'Guardian.reg'. If greyed out, skip
    Press 'User Agent'. If greyed out, skip
    Press 'Restore Policy'.
    Note: In the top box. If you see the following:
    Files Found---
    Guardian Key--- is called:
    User Agent String---
    This is Normal, not adware, nothing was found. Go straight to Restore Policy
    Resolution Failed... Click Here
    XP Pro Users
    NOTE:you can also use xp home method
    Instructions:
    Log in as an Administrator.
    Go to START...RUN...typeecpol.msc <hit enter>
    -or- Go to START...SETTINGS....CONTROL PANEL...ADMINISTRATIVE TOOLS...LOCAL SECURITY POLICY
    This will open up the Local Security setting window.
    Expand the Local Policies folder and select User Rights Assignment.
    This will bring up a list of security settings for the computer.
    You will need to add the user that will be launching the game to have the following privileges.
    -Debug Programs
    -Load and unload device drivers
    -Manage auditing and security log
    -Modify Firmware environment values
    -Profile Single Process
    This is done by double clicking on the setting and then the "Add User or Group" Button.
    You can either type the user or group name into the field or click on advanced to select from a list.
    If you select advanced, you may need to click on the "Object Types" Button and make sure all 3 boxes are checked.
    Then click "OK". Click on the "Find Now" Button to generate a full list of all users and groups on the system.
    Highlight the user you want to add the rights to and click "OK".
    Keep clicking "OK" untill you are back at the Local Security Settings window.
    Repeat this process for the rest of the list.
    Go to Start...Run...Type:compmgmt.msc
    Choose Local Users and Groups
    Choose Groups
    Open Administrators on the right column
    Add your user name than you logon to windows with, and choose check name.
    Note: It should underline and add <pc name or domain>\<your user name>
    Choose Apply and OK
    Close Computer Management
    Note:If the user is logged in while making changes, the user must be logged out and back in for the changes to take effect, or Reboot PC.
    2000 Users
    You need to go to Administrative Tools \Local Security Policy Security Settings\Local Policies\User Rights Assignment
    You need to add your Windows Profile User name to the following
    Debug Programs
    Volunteer Community Manager
    America's Army Project Office || Youtube channel
    K2-Solutions
    Quote Originally Posted by confessions
    RESTRICTION:
    Alvast bedankt
    ey
    ik heb precies het zelfde probleem maar als ik mijn spel aan een collega gaf en die instaleerde hem op zijn pc gaf hij die error niet dus ik vind het raar dat die dat bij mij wel doet. en ik ben admin van pc, originele game, PB is up to date, en nog krijg ik het dus kan iemand ff helpen hiermee.
    gr.
    Springfield's Avatar
    izegem
    al eens post 3 eens gelezen? -_-_-_--_--_--_-_-__-____--_--_-
    Online since 2002
    dat wel maar nog niet geprobeerd i.v.m. te wienig schijfruimte
    en ik probeerde eerst fia iemand anders zijn pb versie te krijgen (bij hem deed ie het wel gewoon)
