10-08-2006, 05:11 #1
[FS X] Flight Simulator X Demo is er!
http://www.microsoft.com/games/fligh...downloads.html
Enjoy.
Rond 630 mb.
Inhoud :
light Simulator X Trial Version
The Flight Simulator X trial version includes two airports, three missions, and three different aircraft. All of the missions take place at St. Maarten in the Caribbean.
Missions:
Getting Started (Novice)
Plane: de Havilland Beaver DHC2
Details: Geared towards first time flyers, this step-by-step tutorial mission shows you how to get off the ground and up in the air so you can explore the ocean and island of St. Maarten. Of special note is the fact that the Beaver is a float plane so you won't have any runways to worry about. You'll be taking off and landing in the ocean.
Flour Power
Plane: AirCreation Trike Ultralight
Details: This mission has you behind the controls of an ultralight, a very easy to fly glider. The object of the mission is to drop sacks of flour attached to your ultralight onto various objects and targets scattered throughout the area surrounding St. Maarten. You'll be scored on both speed and accuracy. Try not to drop any flour on spectators or dolphins, as you'll be assessed a time penalty.
Caribbean Landing
Plane: Bombardier CRJ700
Details: The most challenging of the three included in the trial version, this mission will essentially be a take-off and landing of a Bombardier CRJ700 in a technically challenging airport. You'll need to manage air traffic chatter and surrounding AI planes efficiently to succeed.
http://wilma.vub.ac.be/~lhoste/fsx/shot.JPG
http://wilma.vub.ac.be/~lhoste/fsx/first-fsx-bug.JPG ik heb de eerste bug ontdekt
anyway, het gevoel zit goed bij mij, de cockpit is wel heel mooi om te zien, het water is speciaal en je kan auto's etc zien rijden
mss moet ik nog eens AA en AF aanzetten voor nog mooier beeld van de scenery (of een dx10 kaart kopen binnen paar maand?:P)
vlot spel, zeker de moeite!Last edited by FuLcRuM; 10-08-2006 at 14:16.
[BAD]Zillode-]5th[-qC-.teamBelgium
Belgian Armed And Dangerous (192645) - Stadion: [BAD]Clan Elysium - Reeks: V.60
10-08-2006, 05:31 #2Approved 9-lifer
- 23/07/02
- Turnhout
- 4,074
- 28 (100%)
- 1/8
Mja, ziet er mooier uit dan op mijn PC
Paar goeie puntjes waar ge geen last meer van hebt:
- menu's zijn sterk verbeterd, ge blijft dus nu niet ff hangen als ge alt drukt
- als ge perongeluk een panel versleept, nu kleven die aan de randen van u scherm
- een pak meer handige views en snel om uit te kiezen (gewoon ff rechterklikken)
Meer komt morgen want ben moe
BTW, misschien is het mijn computer hoor. Maar de texture van FSX kan je vergelijken met FS2004 en ground environment pro. Het water is natuurlijk een sterke verbetering maar op mijn systeem is dat niet actief omdat ik een oudere videokaart heb.no votes
10-08-2006, 12:42 #3Member
- 20/06/03
- Damme
- 10,724
- 0/28
watte, da valt nog mee.
met pc 1 uit mn sig (da amd systeem) zout dus zeker op medium moeten lukken dan?
morgen is m'n fs04 helemaal binnen, zal es zien hoe hoog dak daar kan gaan met mn settings.
kbegon al te vreze dat fsx nie ging draaien hier, zeker omdat in x-plane waar da graphics veel slechter zijn als fs04, alsk daar op mn custom scenery van munchen vloog begonnet al te schokken. aa staat nog nie eens aan dan.
10-08-2006, 13:11 #4Member
- 12/06/05
- Dendermonde
- 1,344
- 41 (92%)
- 1/1
Juist ff gespeeld.
Klein detail , je moet sp2 hebben of het werkt niet.
Valt te omzeilen door 1 kritische update wel te installeren en de service pack niet .
Welke weet ik al niet meer maar het is toch gelukt.
2de punt is dat ik alles op max dus ultra high kan draaien met een gemiddelde van 40 FPS.
Setup is : Athlon64 3700 , met 2x7800 GTx en 1 gigske ram.
Het is echt veel verbeterd , de sound ook vind ik.
Ze hebben precies wel een heel mooie lokatie uitgekozen voor de demo.
Jammer dat het geen MP demo is.
Veel toffe functies , zoals het behalen van allerlei medailles , ribbons , awards , ... iets zoals in Battlefield2 , de postcards is ook leuk als je missie volbracht hebt.
Een handige scrnshotmanager , enz...
Zeker uitproberen peeps , Cya all in the Sky near St-Maarten.no votes
10-08-2006, 13:19 #5Member
- 26/11/02
- Mechelen
- 1,427
- 4 (100%)
10-08-2006, 13:24 #6Approved 9liver
- 12/06/05
- Kluisbergen
- 8,348
- 29 (100%)
- 0/53
Ook met mijn specs zeer meevallende resultaten (zie xfire profile). Alles op ultra high buiten de traffic (medium high) en scenery en weather op gewoon high.
Opvallende veranderingen/verbeteringen:
* Je zit niet meer "fixed" in je vliegtuig, maar je bent een persoon die de traagheidswet ondergaat. Maw, als je vertrekt of remt of zo, waggel je vertraagt mee met de manoeuvres van je plane.
* Meer soorten views (byebye active camera en walk& follow
* Bewegende traffic (bootjes en auto's). Ze zijn nog wel wat buggy in de demo. Ik zie bv enkel een chassis rijden bvb bij sommige autootjes.
* Screenshotmanager (press "V")
* leuke cabincrew simulatie (check de 2e missie)
* voor de rest wat pinkybob zegt
Nu nog benieuwd hoe europa en zo eruit ziet, want ben die carieb nie gewoon en vind de kleuren nogal flashie
Een roll maken met de Baron is gelijk nogal onrealistisch (bug?), ofwel lag het aan mij
Conclusie: mijn 1 euro extra volumeblok was goed besteedt
"Er zit in iedereen wel een Dude87!" - gizmo_1987
"Ik wil gewoon vuile E30's te kakken zetten" - ComputerVISTAno votes
10-08-2006, 13:47 #7Member
- 12/06/05
- Dendermonde
- 1,344
- 41 (92%)
- 1/1
Ik heb gewoon 2 van de laatste hotfixes verwijdert.
Maar heb er al ergens een topic over gelezen , ik geloof op het simvation forum.
En inderdaad Blueskyraider op het einde van de runway bij St Maarten verdwijnen de wagentjes gedeeltelijk , maar dat is maar een detail.
voor de rest kan ik alleen maar zeggen THUMB UP en geniet er allemaal van , het gebeurt niet gauw dat wij eens een prachtige demo mogen spelen .
Ik vraag dan ook aan 1 van onze mods om dit als nieuwitem op telenet games newspage te zetten of te laten zetten.Last edited by FuLcRuM; 10-08-2006 at 14:08.
10-08-2006, 14:09 #8Approved 9-lifer
- 18/07/02
- Willebroek
- 8,362
- 124 (96%)
- 2/6
10-08-2006, 14:12 #9Approved 9-lifer
- 18/07/02
- Willebroek
- 8,362
- 124 (96%)
- 2/6
[News] Flight Simulator X Demo is er!
Bediscussieer hier de demo!
Enkele posts moved van de vorige thread
Last.fm
PSN: lennert1984no votes
10-08-2006, 14:15 #10
90%, waarom had ik het karakter niet om op te blijven, moest nog 50 min wachten
10-08-2006, 14:17 #11
Ik ben lichtelijk teleurgesteld; een mooi grafisch sausje maar qua gameplay niet echt veel verandering.
De ATC klinkt nog altijd even hakkelig als in FS2004, en de ground textures zien er niet echt super uit.
70 euro daarvoor afdokken? nee zenne.no votes
10-08-2006, 14:23 #12Approved 9-lifer
- 18/07/02
- Willebroek
- 8,362
- 124 (96%)
- 2/6
Hou wel met de volgende dingen rekening:
Het is en blijft een demo (denk aan de crapdemo van Lock On)
Het is een directx10 spel
FS als standaardproduct is nooit af
Tov FS2K4 is er al vééééél verbeterd
Last.fm
10-08-2006, 14:37 #13Member
- 13/04/04
- West-Vlaanderen
- 6,429
- 117 (99%)
- 3 Post(s)
- 0/19
Ik ga de demo waarschijnlijk niet downloaden, ik ga nog enkele maanden genieten van m'n lekkere FS9, want als ik zo de reacties lees ben ik nu beter af met mijn geaddoneerde (lol?) FS9 dan 700MB telemeter te gaan verspillen
If I can bicycle, I bicycle.
12x Sunpower X21-350 + Solaredge 3000 (226°, 50° helling) PVoutputno votes
10-08-2006, 15:04 #14Approved 9liver
- 28/11/03
- Drongen
- 6,665
- 5 (100%)
- 1/28
ik ga em vanavond downloaden en testen
Hopelijk kan je in de full makkelijk upgraden van 9 => 10 met behoud van add-ons ofzono votes
10-08-2006, 15:23 #15Banned
- 03/07/05
- Delft
- 7,074
- 8 (100%)
- 0/30
ik bezie den 10 als ne fresh start, dan gannek enkel nodige add-ons installe ^^ ge moet es zien wa ik nu allemaal heb
keiveel planes die ik noooit aanraak, kleine sceneries als Orca Island enz O.o
