Page 1 of 6 12345 ... Last
    Sprits's Avatar
    Reet
    81 (100%)
    Leaked Patch Notes 1.12 + real one!
    Wrs weer fake ma anyway
    ze zegge da ong 80% er van zal kloppe!
    Curse-Gaming (Fake Patch Notes)
    *edit*
    Dees zijn de echte
    thnx to Phantom3000 (de testrealm patch is er al)
    - World of Warcraft Public Test Patch 1.12.0
    Cross-Realm Battlegrounds
    - For the first time in the history of World of Warcraft, you will be
    able to face off against players from other realms in the
    Battlegrounds. PvP Battlegrounds link Alterac Valley, Warsong Gulch,
    and Arathi Basin so that players from several realms will be
    combined into one huge matchmaking pool. Replenish your mana,
    sharpen your blades, and get ready for some brand-new challengers!
    World PvP
    - The stage is set for intense, objective-based land battles as Horde
    and Alliance vie for control over important strategic positions and
    resources around Azeroth. Head out for Silithus and Eastern
    Plaguelands to engage the enemy on the field!
    General
    - Threat Reduction Effects
    This system has been redesigned to eliminate inconsistency in how
    the effects work. Previously, some were additive (for example: 30%
    reduction + 20% reduction = 50% reduction) while others were
    multiplicative (30% threat reduction multiplied by 20% threat
    reduction equals 44% threat reduction). They are now all
    multiplicative. This also prevents unpredictable behavior when the
    total reduction percentage was equal to or greater than 100%.
    - Haste and Slow effects
    Previously Haste and Slow effects worked inconsistently, with spells
    working differently from weapons, and hastes and slows not acting as
    inverses of each other. We have revised the system so that all haste
    and slow effects work the same way, and haste and slow percentages
    perfectly cancel each other out (30% haste and 30% slow combine to
    no change). As a result, we had to change the tooltip numbers on all
    spell haste effects, and on all melee and range slow effects. The
    numbers in the tooltips are different, but the game functionality
    is unchanged (other than slight rounding errors). Those tooltips
    that changed will now display larger numbers than they used to
    display. Conceptually, haste values indicate how much more of that
    activity you can perform in a given time. 30% melee haste means 30%
    more swings in a given time. Slow values indicate how much longer an
    activity takes to complete. 30% slow means an action takes 30%
    longer to finish. For those interested, the new haste and slow
    effects work mathematically in the following way. Each effect
    separately multiplies the attack timer of your weapon or casting
    time of your spell. They are multiplied in sequence (order doesn't
    matter) and the final result is the attack timer or casting time.
    The multipliers use the following equations:
    Haste effects: multiplier=1/(1+percent/100)
    Slow effects: multiplier=1*(1+percent/100)
    As an example, a 50% haste generates a multiplier of 0.666; a 50%
    slow generates a multiplier of 1.5. If they are multiplied together
    the result is 1. A 50% haste on a 3.0 speed weapon makes it 2.0
    speed, resulting in you getting 30 swings per minute instead of 20
    swings per minute: 50% more swings. A 50% slow on a 3.0 casting time
    spell generates a casting time of 4.5. It took you 50% longer to
    finish casting the spell.
    - The deserter debuff will now continue to expire even while you are
    offline.
    Druids
    - Barkskin: The tooltip has been changed to 25% due to the haste
    effect change.
    - Ferocious Bite: The Book of Ferocious Bite (Rank 5) now drops
    somewhere in the world.
    - Furor: This talent now works correctly with Cat Form again.
    - Improved Shred: The discounted cost for Shred will now be displayed
    correctly even when you are not in Cat Form.
    - Rip: Lesser potency Rips will no longer overwrite greater potency
    ones.
    Hunters
    - Spirit Bond: This ability will now be correctly reapplied when you
    resurrect in a battleground and your pet is polymorphed or otherwise
    unable to act normally.
    Mages
    - Arcane Missiles: It is no longer possible to cast this spell on an
    evading mob. In addition, the animation will now stop when the
    target is dead.
    - Arcane Power: It is no longer possible to gain the benefit of this
    spell and Power Infusion at the same time by careful timing.
    - Frost Armor Chilled effect: The tooltip has been changed to 100% due
    to the haste effect change.
    - Ice Armor Chilled effect: The tooltip has been changed to 100% due
    - Polymorph: This spell will now be removed when a player leaves a
    battleground. This prevents some bugs involving polymorph from
    occurring.
    - Evocation will no longer be usable while silenced.
    Paladins
    - Divine Shield: The tooltip has been changed to 100% due to the haste
    effect change.
    Priests
    - Mind Control: The tooltip has been changed to 25% due to the haste
    effect change.
    - Psychic Scream: This spell now uses the same resistance checks as
    the Warlock spell Fear.
    Rogues
    - Due to significant talent changes, Rogues will have all talent
    points refunded and can be respent. Training costs for all talent
    spell replacements have been significantly reduced.
    - Eviscerate: Manual of Eviscerate (Rank 9) now drops somewhere in the
    world.
    - Garrote: The damage from this ability has been increased
    approximately 50%.
    - Relentless Strikes: This ability will no longer trigger when your
    finishing move does not hit your target.
    - Sap: Enemy rogues will now always lose stealth when you Sap them.
    Shaman
    - Grounding Totem: This totem will no longer absorb multiple effects
    from Entrapment in a 10 second period.
    - Windfury Totem: The weapon enchantment from this totem will now only
    trigger off normal melee swings. This means abilities such as
    Sinister Strike, Mortal Strike, and Hamstring will no longer trigger
    the Windfury Totem.
    - Reincarnation should now display the cooldown timer when used.
    - Chain Heal - After the initial target is healed, the healing effect
    will jump to the most damaged target (by absolute health) within
    range. In addition, if a raid member is the initial target it will
    look for valid raid targets to jump to rather than non-raid targets
    as a priority, making it consistent with group targeted Chain Heals.
    Warlocks
    - Cripple (Doomguard): The tooltip has been changed to 45% due to the
    - Enslave Demon: The tooltip has been changed to 40% due to the haste
    effect change.
    - Health Funnel: This spell will now work correctly on low-level
    enslaved demons.
    - Howl of Terror: This spell now uses the same resistance checks
    as the Warlock spell Fear.
    - Siphon Life will now properly gain a benefit from Shadow Mastery.
    Warriors
    - Flurry: The text on the tooltip has been corrected to indicate it
    triggers on all types of attacks.
    - Shield Slam: This ability will sometimes no longer remove more than
    one beneficial effect from the target.
    - Sword Specialization: This ability can no longer trigger off of
    itself.
    Items
    - +30 Spell Damage Enchantment: Fixed a bug with this enchantment
    which was preventing it from benefiting healing spells.
    - Blade of Eternal Darkness: The triggered effect from this weapon
    will no longer occur when the spell being cast has its effect broken
    by causing damage.
    - Blazefury Medallion: The triggered effect from this item will no
    longer break Gouge.
    - Bonescythe Armor: The Eviscerate bonus will no longer trigger when
    your Eviscerate does not hit your target.
    - Darkmoon Card- Twisting Nether: The dialog for this resurrection
    will now always reappear after the Spirit of Redemption effect has
    completed.
    - Eye of the Dead: Holy Shock now interacts properly with this item.
    - Ranged Elemental Damage: Our ranged combat system does not allow a
    ranged weapon to do a mix of Elemental (Fire, Frost, Arcane, etc.)
    and Physical damage. Many ranged weapons existed which were listed
    as doing Elemental damage and did not function properly (the damage
    was dealt, but was treated as Physical). All of those weapons have
    been changed to deliver the Elemental damage as a chance on hit
    effect. Hurricane was previously changed this way in 1.11. The
    following ranged weapons are also fixed in 1.12: Bow of Searing
    Arrows, Dwarven Hand Cannon, Heartseeking Crossbow, Dark Iron Rifle,
    Galgann's Fireblaster, Quillshooter, Shell Launcher Shotgun,
    Venomstrike, and Verdant Keeper's Aim.
    - Talisman of Ascendence: This item will no longer trigger from
    physical damage effects. In addition, if either of the buffs from
    the item are cancelled, they will both be cancelled.
    - Zandalarian Hero Charm: Item tooltip corrected to match the effect
    tooltip.
    - The Items that summon mounts have been changed in their color/
    quality. Items that summon normal mounts are now blue(superior)items
    and items that summon swift mounts are now purple(epic) items.
    - Fixed a bug that allowed you to use items which restored health or
    mana while you were already full health or mana.
    - Fixed a bug with the Jom Gabbar trinket which was causing it to
    trigger a category cooldown for a duration longer than intended.
    - Fixed a bug that prevented Arcane Missiles from being able to
    trigger the effect of Wrath of Cenarius.
    - Clarified the tooltips for the Stormshroud armor and Kalimdor's
    Revenge to explain that they deal Nature damage.
    - Fixed a bug that caused the Blooddrenched Mask to hide a character's
    hair.
    - Warbear leather now stacks to 20.
    Professions
    - Engineering: The damage from sapper charges can now be resisted.
    The overall DPS of the charges should not be significantly altered
    from what it currently is.
    - Engineering: Explosive sheep do fire damage instead of physical
    damage.
    Raids and Dungeons
    - Uldaman
    Reduced the number of Shadowforge Ambushers that attack after
    looting the quest chest.
    Shadowforge Ambushers are no longer elite.
    The respawn of the Stone Stewards has been changed to 2 hours
    (from 30 minutes).
    - Zul'Farrak
    The respawn of the 2 Troll/1 Basilisk patrollers should now be 2
    hours.
    Reduced the damage dealt by the Sul'lithuz Abomination and
    Sul'lithuz Sandcrawler.
    Dead Heroes are no longer elites.
    Theka the Martyr will now only remain immune to physical damage for
    30 seconds before reverting to normal.
    Antu'sul's Sul'lithuz Broodlings now only hatch 4 at a time and are
    significantly weaker.
    Witch Doctor Zum'rah will no longer call as many dead heroes to his
    aid when aggroed.
    Weegli Blastfuse now has slightly more hit points.
    Antu'sul's Warden no longer attempts to knock adventurers into
    Antu'sul's lair.
    Sandfury Cretins who engage the party during the pyramid event are
    no longer able to cast shadow bolt.
    - Mauradon
    Noxxious Scions will no longer spawn when you cleanse Celebrian Vines.
    User Interface
    - V key functionality has been improved in several ways.
    V key now shows summoned monsters (such as the gargoyles in
    Stratholme.)
    V key now shows both monsters and player enemies.
    V now shows enemies only (no longer shows friendly targets.)
    Shift-V now shows friendly targets only, not enemies (with a new
    bindable hotkey.)
    Control-V shows both friendly targets and enemy targets (with a new
    bindable hotkey.)
    - New floating combat text has been added to the game with a number
    of options. You can see when you take damage, when you are healed
    and how much, when you acquire and lose auras and much more. You can
    turn on the new options in the newly revised options screen.
    - The Need Before Greed and Group Loot countdown timers will now have
    a 3 minute countdown when there is a bind on acquire item on the
    corpse. This should allow a bit more time in making a decision to
    roll for an item.
    - Automatic Quest Tracking has been added to the game and is turned
    on by default. Any time you advance a quest by advancing one of the
    requirements, the quest information will appear on your screen for 5
    minutes before fading. You can turn this option off from the options
    screen.
    - There is now a confirmation dialogue when you attempt to disband
    your guild.
    Bug Fixes
    - Fixed a bug that caused some non-combat pets to be referred to as
    Minions instead of Pets. Mini Diablo however has escaped this fate
    and will continue to be referred to as a Minion.
    JohnDodger's Avatar
    Token systems have been implemented in Molten Core and Blackwing Lair. Tier 1 and Tier 2 Class Armor sets are now acquired like the Tier 3 sets are through turn-in quests. Bosses that previously dropped the armor have had their loot tables revised. In addition, new items that appeal to a greater variety of playstyles have been added to ALL raid instances as both quest rewards and drops!
    da's raar
    What is going on inside your mind ?
    Sprits's Avatar
    Reet
    81 (100%)
    Quote Originally Posted by JohnDodger123
    da's raar
    da zal wrs dus ne zekere procent van de overige 20% zijn
    Raukaris's Avatar
    Denderleeuw/Gent
    29 (97%)
    Shoot me now please.
    Funk$t@r's Avatar
    Balen
    bull-shit
    Lust brings Envy..
    Sint-Truiden
    --Group Dueling!
    Players can now hone their skills in PvP with the new Skirmish option! This option is available to players in a party, and can involve a maximum of five players per side.
    Geweldig Ma denk wel da t fake is. Of alleen da van die tier 1 en tier 2 drops, de rest ziet er wel nice uit
    Apple powerbook G4 17" || 1Gb Ram || ATI mobility radeon 9700 128 Mb ||
    Buggles LVL 70 Rogue- Proud member of DoY @ Draenor
    SuperstarDragon's Avatar
    de maan
    82 (100%)
    Mensen dit geloven jullie toch niet. Dit is gewoon puur fake. De patch notes zijn zalig maar Blizzard maakt niet zo goeie updates. Meer dan de helft wat erop staat zijn fixes waar mensen al meer dan een jaar en een dag om vragen en Blizzard gaat dat nooit fixen.
    donkey_thong's Avatar
    Heusden
    Ignore List has been expanded to hold 100 players.
    Desktop:: [click]
    Benches:: 3dmark'01 | 3dmark'03 | 3dmark'05
    Gamertag:: Shagoe
    Karre's Avatar
    Oost-Vlaanderen
    Dit is gewoon een droom patch, fake dus .
    Fatalix's Avatar
    Turnhout
    12 (100%)
    Geloof daar nooit zo veel van van die "leaked" crap enzo.
    Stukken er van zal wel waarheid in zitten, maar het meeste... :/
    -13 December 2004-
    SithCloud's Avatar
    murp
    Kweet hte eigenlijk niet, de meeste patch notes die ik al tegengekomen die zo uitgebreid zijn, waren voor zo'n 90 % correct Grappig hoe iedereen altijd "het zal weer fake zijn" roept, terwijl ik me meende te herinneren dat alle gelekte patchnotes van het afgleopen half jaar toch vrij ehhh dicht bij het uiteindelijke resultaat zaten^^
    When in trouble, fear or doubt, run in circles, scream and shout
    Dirty_Col's Avatar
    Ertvelde/Gent
    wishful thinking
    My Last.fm | Myspace | My Desktop
    "bruisend is in de eerste plaats al niet naturel, dus ik vraag mij al af wat voor een smeringe dingen erin zitten om dat water in de eerste plaats al te late bruizen" - Doem Draak
    The party leader or raid leader can now set a rule that players can not roll need on class specific items and other loot that they cannot use.
    overduidelijk fake
    Flare''s Avatar
    Pvp notes zijn wel veelbelovend, laat maar komen.
    -Phoen!x-'s Avatar
    Gent !
    (19:51:20) (+Ie|Cartina) Yeah, they are fake, blue post about it. If you read the entire notes you clearly understand it's fake ^^
