    [Shadowcat]'s Avatar
    Koningshooikt
    Fortify skill spell: waar?
    Ik heb al alle npc's afgelopen in de magesguild die spells verkopen. Heb ook al de chapels of the Nine afgelopen.
    Maar nergens vind ik iemand die een fortify skill spell verkoopt. Wel fortify attribute maar geen skill.
    Weet er iemand welke npc dit verkoopt? Het zou normaal gezien moeten bestaan want met mijn eerste char kan ik een item enchanten met fortify skill. Alleen weet ik niet meer hoe ik hier ben aangeraakt.
    "Qui non est hodie eras minus aptus eriti" -Ovid
    Unkn0wn's Avatar
    Berlijn
    Is inderdaad moeilijk te vinden,
    Hoe dan ook:
    The Fortify Skill effect is special since a spell with this effect cannot be bought anywhere in Cyrodiil. However there are many other ways to get access to it. You can make all Fortify Skill spells if you have any Fortify Skill, -- through a native ability due to a birth sign, a race or a quest reward. For example, Fortify Skill spells can be obtained by:
    - acquiring Greater Powers from Doomstones.
    - completing the Origin of the Gray Prince quest, (constant effect reward).
    - completing the Whodunit quest for the Dark Brotherhood. The bonus reward, Night Mother's Blessing, is a constant effect fortify of various skills.
    - completing the Daedric quest for Nocturnal. The Fortify Skill ability is only available when you keep the quest reward, The Skeleton Key, in your inventory.
    - completing the quest from the official Bethesda mod, The Thieves Den. Several Fortify Skill spells are then available for sale.
    - becoming a Vampire. Vampirism gives access to both Fortify Skill and Fortify Attribute effects.
    Although Fortify Skill spells are very useful, they do not in general provide any skill perks. For example, if you boost your Security to 100, all of the tumblers will go up slowly, but if you fail and break the lockpick, they will still drop. There are exceptions:
    Armorer: a boosted skill of 100 effectively makes repair hammers unbreakable
    Mercantile: a boosted skill of 75 or over will allow you to invest in a shop (this is likely to be a bug rather than a feature).
    Note: Fortify Attribute spells are already readily available for sale throughout Cyrodiil from many spell vendors. Only Fortify Skill spells are unavailable for sale.
    of dus hier met een mod:
    http://www.tessource.net/files/cache/1861.html
    Hope it helps
    Koningshooikt
    Aha, thx man
    Nu weet ik hoe ik met mijn andere char aan een fortify skill spell ben gekomen. Kheb daar namelijk al de dark brotherhood quests gedaan
    En kheb met deze char nu ook de mogelijkheid om fortify skill spells te gebruiken, net mijn skeleton key verkregen
